Econ light stays on fault code 00819
Old Jun 11, 2008 | 04:07 PM
tslag's Avatar
New Member
Default Econ light stays on fault code 00819
Hello,
I have searched this forum but didn't find an answer to my question.
I have a 2002 A6 4.2. The econ light on the climate control will come on and stay on about 5 minutes into driving, meaning I have no A/C. I had the car VAG'd today and here is the fault:
00819 - High Pressure Sensor (G65)
29-00 - Short to Ground
I found the following article on Ross-Tech:
http://wiki.ross-tech.com/index.php/00819
The recommended solutions are:
00819 - High Pressure Sensor (G65): Signal too Low
Possible Symptoms
* Climate Control stuck in ECON Mode
Possible Causes
* Insufficient Refrigerant Pressure
* Wiring/Connectors from/to High Pressure Sensor (G65) faulty
* High Pressure Sensor (G65) faulty
Possible Solutions
* Check Refrigerant Pressure
o Check Measuring Value Blocks (MVB)
* Check Wiring/Connectors from/to High Pressure Sensor (G65)
* Check High Pressure Sensor (G65)
My question is:
Should I have the system checked for low refrigerant before replacing the sensor? The 29-00 Short to ground from the fault code makes me think the actual sensor may be bad. Has anyone had this same code before? Any suggestions?
Thanks in advance.
Old Jun 11, 2008 | 04:14 PM
4Driver4's Avatar
Tech Guru
Tech Guru
I'd say yes. Have the system checked.
Old Apr 28, 2019 | 04:59 PM
968racer's Avatar
What was the resolution to this?
alpinab7
VAG-COM Discussion
May 13, 2013 06:11 PM
Reggie
RS4 (B7 Platform) Discussion
Jun 10, 2010 09:25 AM
Im@wesome~ out!
Oct 16, 2007 06:13 AM
ado_dado83
Mar 23, 2007 08:01 AM
veteq
Nov 7, 2006 08:20 PM
