error code 17536 P1128
Hello,
Just had an audi mechanic around to have a look at the car. He put the car on VAG com and the lambda sensor was showing running too lean. when car held at 2k revs it was showing missfire on all cylinders.
new maf sensor fitted
all hoses checked and cleared of leaks.
not sure if this is relevent or not but i was parked with the car on a slope facing upwards and on idle car kept stalling i then managed to turn around and face down and car would idle without stalling.
could spark plugs cause this problem as dont know when they were last changed ? could it be fuel pump ? fuel filter ?
any suggestion much appreciated.
thanks
neil
Yes the mechanic told me that he found oil on the sparks, already replaced the valve casket, and yet the problem isn't solved, what happens with me is that the turbo air vacuuming sound get lower slightly until it dies completely.and by the way when I disconnect the Battery for a few minutes the car gets back to normal but it shakes for a around 20 seconds after starting the engine and after a few seconds the cat gets 100% normal, and after driving it for a few mile it dies again slightly.
I have also replaced two MAF sensors, Checked all vacuum hoses, and I don't know what else can I do.
Possible causes
- Faulty Mass Air Flow (MAF) sensor
- Low fuel pressure
- Vacuum leak on engine
- Faulty HO2S bank 1
