Fault code 16538
Fault code 16538
Hello friends, my cars I got an error code 16538 and went to a different website but did not get it. Both are new sensors .
Are the white wires that are connected to the sensor heater before they start and should they have electricity when opening the switch?
16538/P0154/000340 - Ross-Tech Wiki
Ross tech wiki has good code info. Maybe wiring or connector issue.
Hello
One question , is it possible to use an oxygen sensor with the code 0258003772 in the audi C5?
I used this sensor code when the car is turned on and cold, I do not have an error code for 10 minutes, but after the warm up, the code 16538 appears.
Part number not compatible with 1998 Audi A6
Part Number: 0258003772
Of course, you could have done this research yourself.
From this website: https://www.boschautoparts.com/en/au...tID=0258003772
Fault code
Hello friend, the following error is related to the driver's position sensor or the passenger? Sensor b2 s1
