Follow up question. How do you add water to the battery?!
It's the original one -570cca "Maintenance free"
the green indicator is not visible anymore
thanx
2.8Q<ul><li><a href="https://forums.audiworld.com/a6/msgs/552459.phtml">thread from last night</a></li></ul>
thanx
access the battery, remove the caps over the holes, and add distilled water. Having a flashlight
helps you see the water level-Leave it about a half-inch below the top of the holes.
removed stickers, the cover that goes across will not come off
I'm to a point where i physically damaged the cover(more cosmetic than physical actually)
the cover goes all the way across the battery right?
I'm going to take a picture of it
You will see a gap between the battery cell cover..
and the battery itself. A small screw driver on the front and back or left and right side ..pry gently together and it will rise.
Still trouble...it doesnt want to rise at all :( what am I doing wrong?
One can clearly see where i tried to pry it.The cover is connected under the handles.(along the negative terminal)
<img src="http://pictureposter.audiworld.com/54346/img_0612.jpg">
<img src="http://pictureposter.audiworld.com/54346/img_0614.jpg">
Type of battery
<img src="http://pictureposter.audiworld.com/54346/img_0615.jpg">
Type of battery
What you want is to go to Autozone...
<center><img src="http://pictureposter.audiworld.com/63674/bat_1.jpg"></center><p>and for free they will test the battery. You can also check the date of install of the battery as it carries its own pro-rated warranty.
To open it up pry around the edge of each cover. Wher I marked your shot in red.
did the test in autozone...the URL is in my post
is it so difficult to pry it open? because i'm damaging the cover as you can see..right where you have it marked at the terminal.
test results are in the previous post<ul><li><a href="https://forums.audiworld.com/a6/msgs/552459.phtml">Link to old post with test results</a></li></ul>
thats funny...if i could only prop it open....
the thing is that the test showed good battery
how reliable the test is?who knows
the indicator (green dot on top of battery) is nowhere to be seen.what does it indicate? low fluid, low charge, not good battery? it's all fun
indicates the battery is not holding a charge.
There are many reasons for this. 1 of whic is as simple as you cables are dirty or not tight enough. So you can't get the car started nor can it recharge completly.
Check the terminals.
