Front o2 sensors on a 2001 A6 2.7T TIP
Old Nov 30, 2006 | 09:55 AM
dawgs's Avatar
New Member
Default Front o2 sensors on a 2001 A6 2.7T TIP
Are the Audi one's the same as any of the one's sold by VW.......... that may be cheaper cost wise (even thought the same part)??? I know there's some x-over between Audi and VW parts (surprise-surprise). Has anyone looked into this for the 2.7T o2 sensors??
Old Nov 30, 2006 | 10:16 AM
dawgs's Avatar
New Member
Default Also, if you have one bad front o2............. code 1114
.............. is it recommended to replace both front sensors or does one only replace the faulty one. I'm getting conflicting advice.
Old Nov 30, 2006 | 03:07 PM
WhiteLightning's Avatar
New Member
Default Re: Also, if you have one bad front o2............. code 1114
Just replace the faulty one. There is no labor savings nor will it create issues. I have done this and have had this discussion with a very good tech.
Old Dec 1, 2006 | 09:09 AM
Truewit's Avatar
Default Re: O2 sensors
The equivalent VW sensors are part # 06a 906 262q. Prices for these jumped substantially a few months ago, but they're still cheaper than the Audi ones. The connector plugs are different, though. You can either switch the connector from your old sensor to the new one (by soldering wires somewhere between the plug and the sensor -- I'd be surprised if you could successfully dismantle a connector plug without destroying it in the process), or get an Audi plug, part # 3a0 973 334 and install it, making sure that the wires correspond to the arrangement on both plugs (there are four wires and each is numbered in the respective the plastic housing). Check the archive -- there's a pile of comments on O2 sensors and installation.
jes
Dec 9, 2016 08:18 AM
Choimis
2.7T V6 Discussion
Nov 16, 2011 08:42 PM
Truewit
10
May 6, 2005 02:14 PM
qfrog Ti20
12v V6 Discussion
Apr 6, 2005 03:12 AM
s4123
Apr 18, 2004 11:56 AM
