Hazard Relay Help
Hazard Relay Help
This whole problem started when my turn signals stopped working. I replaced the hazard relay in the dash, however when I replaced this, the turn signals worked but were flashing at a much higher pace, also the hazard lights do not work nor do the corner lights flash when I lock/unlock the car. So I bought a new hazard relay from the dealer thinking that the first one was crap. Turn signals flash at normal rate, however, no hazards and no corner flashes when locking/unlocking. I am at my wits end to what it could be, any help would be greatly appreciated!
Bad turn signal stalk switch, hunch.
so what if you put your original back .. everything work excpet the signals ? sounds like you have 3 different set of symptoms with three different hazzard switches . is that correct ?
do the corners flash when you lock or unlock with your original relay ? if not that is the only thing in common with all three..
flashing rate depends on the resistive load provided by the bulbs .. i would be checking the corner lights for shorted wiring maybe or a damaged harness.
a911sc
09-07-2013 06:52 AM
DavidCX
09-20-2007 07:54 PM
