Headlight washer relay ?
Okay time for the latest project .. noticed the headlight washers were not working . Did a lot of searches and found out most people disable them anyway due to leaks .. But I would like to see if I can at least get them working ...
found was not geting 12 volts to washer pump even with the light s on and holding the nozzle for about 5 seconds .. checked the fuse and all was okay .. i suspected this anyway as all the other things on that fuse were working.
I read in the manual it as a fuse for the headlight washer realy .. anyone know where it is exactly so i can check it ? I imagine it is in a relay that is wired to the headlights so it wont come on without headlights .. worse case I will wire it directly but I think once I know where the relay is I will be on my way
Thanks
Thanks
Bit of an update .. dug up my schematics and it turns out I unpluged the wrong connector .. that was the level sense .. the othe r conectors look a real pain to get to . there is one tucked away .. it would be a real PITA to take the fender liner out just to check see if the pump is working and then order it . But i guess I have no other choice ..
sbh tuned
04-05-2004 10:34 AM
A. Udi
09-15-1999 09:25 AM
