HELP 18 codes /go to car wash,sprayed the engine bay gingerely-just the front and delicately around.
The car is now sputtering at idle only....runs ok at full throtle, but not a peppy... got the following codes
DTCs: 10/16/08 6:29 pm - 18 Faults:
2.7l V6/5VT G 0005
P/N: 4B0 907 551 K
Coding: 06612, WSC: 02325
17529 P1121 035
HO2S Heater Circuit, Bank 2 - Sensor 2: low
17548 P1140 035
Bank 2 - Sensor 2: internal resistance too large
17833 P1425 035
Evaporative Emmision (EVAP) canister purge Regulator Valve -N80: short to Ground
17880 P1472 035
EVAP Emission Control Leak Detection Pump (LDP) Circuit: short to Ground
17938 P1530 035
Intake Camshaft Control Circuit: short to Ground
17955 P1547 035
Turbo/Super Charger Wastegate Solenoid (A): low input/short to Ground
17697 P1289 035
Turbocharger recirculating Valve -N249: short to Ground
16486 P0102 035
Mass Air Flow Circuit -G70: Low Input
17865 P1457 035
Exhaust gas Temperature Sensor 2 -G236: open / short to B+
17861 P1453 035
Exhaust gas Temperature Sensor 1 -G235: open / short to B+
17525 P1117 035
HO2S Heater Circuit, Bank 1 - Sensor 2: low
17522 P1114 035
Bank 1 - Sensor 2: internal resistance too large
17523 P1115 035
HO2S Heater Circuit, Bank 1 - Sensor 1: low
17527 P1119 035
HO2S Heater Circuit, Bank 2 - Sensor 1: low
16544 P0160 035
O2 Sensor Circuit, Bank 2 - Sensor 2: No Activity Detected
16524 P0140 035
O2 Sensor Circuit, Bank 1 - Sensor 2: No Activity Detected
16518 P0134 035
O2 Sensor Circuit, Bank 1 - Sensor 1: No Activity Detected
16538 P0154 035
O2 Sensor Circuit, Bank 2 - Sensor 1: No Activity Detec
2.7l V6/5VT G 0005
P/N: 4B0 907 551 K
17529 P1121 035
17548 P1140 035
17833 P1425 035
17880 P1472 035
17938 P1530 035
17955 P1547 035
17697 P1289 035
16486 P0102 035
17865 P1457 035
17861 P1453 035
17525 P1117 035
17522 P1114 035
17523 P1115 035
17527 P1119 035
16544 P0160 035
16524 P0140 035
16518 P0134 035
16538 P0154 035
I'd disconnect the various electrical connectors (one by one) and blow then dry. Look for the
set of connectors by the MAF, and the one by the TBB, just for starters.
If you don't know how to disconnect them, it's easy: look for the silver metal locking wire, push it toward the body of the plug, pull on the plug.
Remember, disconnect these one at a time to be sure you reconnect them correctly.
sergeyk
12-06-2008 12:16 PM
PKmode
09-26-2006 05:25 AM
PKmode
09-25-2006 10:53 AM
PKmode
09-21-2006 08:09 AM
BLK01S4
15
08-02-2005 07:44 PM
