Help with a mysterious small coolant leak, here's the deal, details inside
Here are the symptoms: it only leaks a tiny bit over night. It does not leak during the day driving around, while at work as I can tell. It seems that when the entire engine fully cools down that the leak finally hits the belly pan and then the floor.
I STFA and from what I can find it may be the oil cooler.
ANY ideas will help. My warranty ends in 300 miles and I would like to fix it by then.
thank you all
The moron service facility should have used a dye tracer first thing.
Prime sources of leaks are the coolant reservoir itself...it often cracks on the bottom.
There is also a plastic coolant line (at least on my 2K 4.2) that hardens over time. Also multiple spring clamps that leak (and should be replaced with screw-type clamps).
Good luck.
thanks
