Help Please! ABS Light on, OBD issue, Airbag light on and Park Brake light flashing!
#11
If it's the same p/n it's a plug and play.
#12
Here is what ross-tech has: http://wiki.ross-tech.com/wiki/index...ulltext=Search
depending on which version you have... also, did you rule out any bad wiring? lack of communication could also be due to bad connection right...?
#14
Ok thanks guys. I paid $200.00 it is the identical #. So should the lights go off as soon as i start it? or will I have to drive it a little? Rotate front tires? I dont have VAG-Com yet. I'm in Calgary, Canada, so it would take time to order from Ross-tech.
#15
Regarding abs codes, I would try disconnecting battery's positive for 10mins or so to reset and see if they come back. If they still come back (i.e. the lights), I am afraid vag-com is the only way to reset/clear them. And, you might even have to code it to your vehicle specifically... look on ross-tech wiki.
#16
No reprogramming needed. Why not rebuild yours? Some companies rebuild for well under $100. Otherwise, you will have the same situation with your unit from the autowreckers.
#17
Ok. So awesome thanks guys. I installed the ABS controller and by the time I backed out of the garage the ABS light and flashing parking brake light went out! So...one One more to go! AIRBAG light. not sure why its on!? I assume module from what I'm picking up here!? Is there anyway to reset or clear it without VAG-COM? Remember we I'm working on the kids car, 1999 Audi A6, 2.8L. Where is the AIRBAG module located? Will mine work to test it on the A6 off my '02 - S8? mine has the side curtain airbags of course, so not sure if it will work!?
#18
It sounds like these are common issues with the Audi A6! I have 2002 A6 wagon and my ABS light is on while the Parking Brake light flashes. I also have Check engine light (431 error code and front bank O2 sensor respectively). I had a P38 Range Rover and from what I recall an ABS pump replacement is VERY expensive. so this ABS controller did the trick?
#19
#20
Yes it did. I was able to get a AND control module with the pump for $200 out of a wrecker. If your going to keep the car for awhile you might want to get it rebuilt though as you don't know how long another used one will last. It was simple to change out just swapping the module and leaving the pump in. Both codes went away as soon as I moved the vehicle for test drive.
