Help w/ crank lock tool 3242--is my part bad?
Link below to my original post w/ more detail.
If you have a 3242, do the threads look the same, all the way up the tool? On mine, about 1/2 way up, they change from "flattened out" or "knocked down" to pointy & sharp. In other words, the outside diameter of the threads increases, which may be the problem.
TIA
('01 2.7T)<ul><li><a href="https://forums.audiworld.com/a6/msgs/698178.phtml">shoulda been NEW not a reply</a></li></ul>
TIA
IT IS A PROBLEM. I had the same issue and i fixed it...
What i did was i used 120 grit sandpaper wrapped around it and kept spinning the tool in the direction that would keep the sandpaper wrapped around it. That flatened the threads to make it even all over. The raised part seems to be a manufaturing issue. After i did the sandpapering i used air to blow it and oiled the threads. After that it went in with no problem.
I just decided to fix it myself because i did not have the time for returns and stuff. Before i messed with it it would only go in a bit more than half way.
I bought mine on ebay together with the cam bar...maybe you did the same.
Got it in 2nd time around. Now its out and the threads look the same.
I'm now thinking it's designed that way. Shallow threads so it's easy to get started, deeper threads in the 2nd 1/2 to make sure it's tight fit when fully inserted.
Audi-Impaired
04-04-2003 12:26 PM
djillusion
07-16-2001 08:43 AM
NDA4
02-28-2001 08:23 AM
