How to disable alarm system
Old 08-05-2008, 08:47 PM
  #21
Member
5speed6  v.2's Avatar
Default The alarm sytem is composed of multi components, each tied together..
..the Central Locking System, The Anti Theft System, The Ultra Sound Monitor (for the Interior) and the Starter System (for the Immobilizer.
This all spans across multiple fuses, and a relay (for the Starter Interlock).
Yes, it can be disabled, but unless you seriously know what you are doing, you should not attempt it.
I would recommend going to a local stereo/alarm shop in business for a while, and see if they will be willing to disable it for you or further diagnose it if you want to repair it.
Old 08-05-2008, 08:50 PM
  #22
Member
Default VAGCOM shows no faults due to nothing tripping the alarm, the module itself ..
...could very well be faulty, and therefore would not show up in a VAGCOM scan.
Old 08-06-2008, 12:51 PM
  #23
MP4.2+6.0's Avatar
Default If you give up, different ways to kill it without irreversible damage...
I think what is probably bugging you is the sound from your original post. Thus, just disconnect the (wimpy) horn that it uses by pulling the plug and taping up the wires. In the left rear fender area as I recall. Still leaves the lights flashing for a few minutes.
I also seem to recall that if you supress the locking chirp moise via VAG COM, that it also supresses the alarm horn.
Alternately in VAG COM, I think there is a coding setting to tell it the car has an alarm in the first place. Thus, I expect if you subtract out the bits that VAG COM tells you are for the alarm feature in general, it should get a software lobotomy so to speak.
If you do it any of these ways, it's fully reversible.
doobiesdaddy
2.7T V6 Discussion
08-07-2008 02:03 PM
doobiesdaddy
Audi allroad
08-04-2008 01:53 PM
Houpty
08-24-2004 04:35 PM
makoto
9
09-14-2003 07:27 PM
innocent:byStander
08-16-2001 03:32 PM
Quick Reply: How to disable alarm system
