I'm beginning to think this whole break-in period stuff
Old 11-24-2001, 08:25 PM
ChrisS -2008 A6-4.2's Avatar
Default I'm beginning to think this whole break-in period stuff
is simply poppy-****, or left over notions from the 50's and 60's.
Porsche, for example dynos every engine before mating it with the chassis. Popular belief is that the engine is broken in before the car leaves the factory. 20 minutes run time tops.
Further supporting my cases is the whole oil change thing, 50's thinking change your oil every 3000 miles. How is it the Europeans run about a 9,000 mile program? 15,000 mile on a Porsche.
Somebody is blowing smoke somewhere- who?
Old 11-24-2001, 09:13 PM
New Member
Kent M's Avatar
Default I totally agree
1) THe car is under warranty...If it's gonna break, it will happen during the warranty. If it breaks after the warranty runs out, who cares...i will be driving my next audi.
2) About 6 mos ago, i went with my bro to pick up his 540i in munich. WIth the odomoeter reading "7" miles, we were travelling above 130mph...no worries then, no worries now.
simple enough.
Old 11-25-2001, 04:13 AM
New Member
Ga4.2's Avatar
Re: I totally agree-break it in the way you want to drive it.
Old 11-25-2001, 06:33 AM
Senior Member
Auto Union Jack's Avatar
It is more for the other components r/t Porsche.
Old 11-25-2001, 07:18 AM
Junior Member
4.2MingBlue's Avatar
I agree too. Run it hard right from the start!
Old 11-25-2001, 07:19 AM
New Member
Y2k_A6_2.7t's Avatar
Default I am mixed about it ...
On the oil change interval, I agree. I am comfortable with the 10k timeframe although I am running a 5k-6k interval on my 97 Jetta GLX.
I am careful about following the break-in directions though. I made the mistake with my Jetta of not following the directions. Now of course I understand that there are many variables but these are my findings.
My Jetta, I changed out to synthetic at 3k. I have a feeling the the rings did not seat properly as I consume a little oil (1qt/4k miles). As a point of reference, my 94 Passat GLX (which also has the VR6 engine) does not burn a drop of oil (with 185k miles I might add). I did follow the break in period as directed. Now this is not a real sample but the Jetta is the first car I did not follow carefully and it is the only one I have had that consumes oil (aside from my first car that I think was a two stroke engine it used so much oil).
Junior Member
Right on! My car will be gone by time warrenty is up!
Old 11-25-2001, 07:38 AM
AudiWorld Expert
2.7tDallas's Avatar
Air cooled Porsche's were one thing. Is there a different policy on the new watercooled ones?
Old 11-25-2001, 08:38 AM
Elder Member
Jon C's Avatar
Default Re: I totally agree
You guys are Exhibits A & B on why many people are wary of buying off lease/ used cars (which may be abused b/c the owner doesn't care, they won't keep it past warranty). Not saying you guys are abusing yours, but there is a bit of an attitude in that kind of view (screw the next owner down the line if it breaks, I had my fun under warranty)...
There are some legit reasons for break in periods, and I'm not sure comparing the Porsche break in technique to any other mfr. is necessarily valid, given the limited numbers and higher stds. that Porsche tends to use.
The technique my Porsche tech friends & sales friends who've driven them in competition for years use, and which the Porsche factory uses, is --- when they're wringing out a new engine on, e.g., the Autobahn -- is to lift every time they go under a bridge, even at full throttle. The resulting vacuum sucks oil into the cylinders and keeps them well lubricated even when the new engine is running hard.
Old 11-25-2001, 09:03 AM
Muhammad's Avatar
Default Take the Porsche example....
While Porsche does have "hard use" break-in at the factory (couple mins engine dyno, plus a drive on the autobahn ---remember a 996 can to 110mph during owner break-in ) I read on CFG's forum something about improperly broken-in GT3s producing up to 30hp less than their properly broken-in twins (under 4,200RPM for 1,000 miles) ... something to consider... personally, I'd stick with easy driving for 1,000 miles.
Quick Reply: I'm beginning to think this whole break-in period stuff
