just a note when comparing data logs from K04 car with K03 software that ran 13.66 and,,
Craggy Old Man
the K04 car with detuned K04 software to the K04 car with new software.
The new software in 2nd gear alone was .48 seconds faster between 3300 and 6400rpms than the car with the K03 software that ran 13.66. It was also faster than the detuned software.
Need to get some more data logs and then head to Carlsbad for some slips to compare.
I was Vag tool to do the timing with blocks 003 and 115. Compared them to the same blocks taken for each software change.
Wonder what this all equates to at the drags?? Could it mean the car has the potential to turn 13 flats or better? DOnt know.
With your set up.. you should be able to run 13s... even high 12s.. DrkAngel should be running
lower 12s... if S4s with similar set ups are running 11s. I guess the difference is the weight.... How much heavier is the A6 2.7T than the S4?
Craggy Old Man
not too much difference maybe 100-200 lbs. .2-.3
man I thought when I ran 13.6 that was good, this could be 13 flat or better. On 1.16spikes and constant 1.0bar program
heh.. you need to run more boost.. at least 1.2bar with spikes to 1.4.. then you'll see 13s.
if your car could hold 1.4.. that would be ideal. I believe the Map sensor won't allow more than 1.5. Have you logged Timing correction factors.. log that.. the ideal setting for this motor is 3-5 cf factor... up to 9 cf factor is safe... I'll email you tonight w/ some more info...
