Lambda sensor - correct functionality?
Old Oct 19, 2010 | 08:53 AM
podigoto's Avatar
Default Lambda sensor - correct functionality?
Hello all,
There are two fault codes in my engine ECU (Audi A6 99, 2.8Q Avant) :
16538 - Oxygen (Lambda) Sensor B2 S1: No Activity
P0154 - 35-10 - - - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
I cleared them, but they appear again. So yesterday I’ve connect my VAG Com in graph mode and it seems that sensors work properly. Just want to note that when engine was cold in first ~2 minutes the voltage from lambda sensors was 0.450V, but as I am aware this is normal, isn’t it?
I attached the graph.
Thanks.
Old Oct 22, 2010 | 02:16 AM
podigoto's Avatar
Any opinion?
Old Oct 22, 2010 | 07:02 AM
Just Me's Avatar
Tech Guru
Tech Guru
alas, no real ideas. I know hwo they work in theory, but have not seen enough operate r/t to comment.
I do know that until warm up the system operates rich, so that means the signal will either be hgih or low - not vary-ing.....(forget which way it is set up)
G
Old Oct 24, 2010 | 11:42 PM
podigoto's Avatar
Yes, you are right before warm up the voltage on sensors was ~0.45 V.
Thanks for the opinion!
Old Oct 25, 2010 | 07:22 AM
Peter Badore's Avatar
How old are the oxygen sensors? The heated o2 sensors on your A6 shouldn't take two minutes to go from open loop to closed loop operation. If there were a failure of the o2 heating circuits there should be a DTC set. With VAG-COM you could check the o2 sensor heating circuit resistances to see if they are close to being out of specification.
Old Aug 1, 2011 | 01:18 PM
podigoto's Avatar
Could be the failed O2 sensor be a reason for rough idle?
Old Aug 1, 2011 | 06:07 PM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
That heater circuit is supposed to give closed loop capability within 30 seconds.
Lots of people have had trouble with non-OEM sensors that weren't of the fast-warmup capability.
Old Aug 1, 2011 | 06:09 PM
Tech Guru
Tech Guru
I can't tell the horizontal scale in milliseconds/seconds, but it could well be you also have lazy sensors, i.e., they're incapable of making more rapid crossovers. Need about two/second IIRC at minimum.
Here's a short tutorial:
http://www.autodiagnosticsandpublish...or-testing.htm
Old Aug 2, 2011 | 01:53 AM
podigoto's Avatar
Thank you so much for info, I will check the frequency of O2 sensors.
Still wondering whether O2 sensor can be a reason for rough idle, later on I will post the rpm graph, but definitely there is a problem on idling.
Thanks
Ivan
Old Aug 2, 2011 | 08:00 AM
Tech Guru
Tech Guru
LOL---now the real issue comes out.
Rough idle is almost always a vacuum leak but could be a few others. Since you only have 02 sensor codes I'd fix those first...chances are an older A6 with miles could use new sensors.
It's also possible you got a bad batch of gas or contaminated/leaded gas in Bulgaria....stuff happens.
One thing you could try if you pull the 02 sensors...take a propane or MAPP torch and heat the sensor tips cherry red for about 20 seconds, monitoring the voltage output. Should go to .9v or more. Let it cool, should drop to <.1v. If this works, it doesn't necessarily mean the sensor will work in your car, especially if it's a lazy sensor issue but it's a start. For sure, if it doesn't go to .9v+ you have a dead sensor. The heater circuits are generally continuity...if they have continuity they're ok. They actually have a resistance other than zero which would be a short.
originaliowan
Oct 24, 2019 07:24 AM
liljoey99
Aug 20, 2017 10:27 PM
ajg617
VAG-COM Discussion
Oct 8, 2013 06:21 PM
AK_92_V8
Nov 6, 2008 09:27 AM
bredenoord
2.7T V6 Discussion
Jun 16, 2006 05:09 PM
