Nav Plus Install Update
I consider the A6 board my brothers....some of you know I'm doing a Nav Plus install....hard to do when you had a Delta single DIN radio.
Anyway....I'm almost done....a few of my posts from today:
<a href="https://forums.audiworld.com/a8/msgs/48908.phtml">
The Nav Plus unit in action</a>.
<a href="https://forums.audiworld.com/a8/msgs/48915.phtml">Installing the GPS antenna</a>
It is so cool!
pw
It is so cool!
pw
Fantastic, really. Your sig pic (Doc Brown) couldn't be more appropriate.
Thanks for posting over here, I occasionally look over on the A8 board, but not often enough.
Do you have any roundabouts nearby? If so, go sometime just for the crazy symbol that the Nav puts up. There are not many of those crazy circles out here (NorCal), and I encountered one the other day while using the Nav...pretty hilarious.
Which firmware revision do you have in it ?
I believe you are running an older verison of the firmware ?!
Quote:
"You get the idea of the center console. But while all this is going on you can display on the Nav:
1. The same thing as posted above.
2. The map of where you are, it's moving with you....or:
3. The radio stations. "
In the newwest revision from October 15 2001 (as i recall...) you are also able to see a compass rose as an option.
Besides that the map resolution is down to 50 mtr. instead of 100 mtr, and you can key in stopovers.
Let me know if you need any info on it.
A6Fanboi
03-15-2007 06:58 AM
?PROXUS?
08-16-2005 05:38 AM
