Need help with a couple of issues on my 98 a6
Hi. I just joined this site cause i just got a Audi. I'm more of a BMW fan, but decided to try out a 1998 Audi A6 2.8L Quattro. just got it 2 days ago. its got 119000. Its its very good condition and i got a very good deal on it. I am very pleased with it at the moment
But it does have a couple of issues. I consider them minor... but still.. Since i don't know a lot about Audi's any help would be appreciated.
1. Burning oil smoke coming out of passenger side of engine. (just read online that its the valve gaskets possibly) Anybody know how much it costs to repair? just labor, i can buy the parts... Don't wanna go to dealership.
2. When i take a turn at low speeds, i hear a ticking sound , very slight.I notice the sound when i take a 90 degree turn and accelerate. My guess its the axle assembly... but not sure.
3. The Brake pad sensor lights up the dashboard. Brakes are good though. The car does has 18 inch aftermarket rims and drilled rotors in the front, but they all look fine, plenty of life left on the pads and the rotors. Is it just a sensor thats bad?
4. Should i do a tranny flush ? I don't know if the previous owner did it.
5. Any other common A6 problems I should be looking for?
The previous owner took care of the car. I can see that its very well taken care of... the ABS Bosch module is brand new, timing belt new, etc. but i just want to make the car in perfect working condition. Thanks again for any help
1. Not sure about the 2.8
2. CV Joints, I have the same thing. You can pick them up off ebay for ~50 bucks.
3. Are the sensors hooked up?
4. I would drain, replace filter and refill - not an easy DIY
5. Control arms, CV joint boots. Judging by 2. your CV joint boots are busted.
1. Assuming it is indeed the gaskets, my indy quoted me about $600 to do them P&L, but this is something that is best done in combo with the timing belt service since it involves the same disassembly to get to them. If you can definitively diagnose the smell as due to leaky gaskets, it should be tolerable as long as you just make sure oil level is good (mine has had leaky gaskets for about a year, but I'm waiting for the upcoming TB service to do all that).
3. Probably a disconnected sensor cable, as mine does this time to time after going over extended rough patches (such as the grated surface during resurfacing).
4. My understanding is that flushing the tranny is a major no-no...drain and refill as the first reply noted, but do not flush (there are several posts and info elsewhere about the problems with tranny flushes).
The sensor triggers the light when pads get down to about 30%.
When you change the fluid, the filter change a is a "must do"
The previous owner took care of the car. I can see that its very well taken care of... the ABS Bosch module is brand new, timing belt new, etc. but i just want to make the car in perfect working condition. Thanks again for any help[/QUOTE]
Lots of minor stuff.
Hey, noob, watch the talk about perfering BMWs if you want sound advice, but CV boots and gasket should fix your problem. Gasket can wait, do boots first. Your 2.8 is less problem prone than the Biturbo, so as long as you have all fluids flushed, espec. at 119K, you will run for a while longer. The brakes issue, I have the same rotors and new pads, check your sensor connect, could have popped off, or clean them also, if not, and still barakes well, drive on, see if you can have a friend reset the code.
Jon Brown
11
03-05-2018 09:02 AM
keithallis
10-02-2009 02:14 PM
bigfacebill
03-11-2003 05:07 PM
