PIAA H3's came in, going out to put em in... hopefully its as easy and quick as I have read it to be
that was about as painless as it gets, slightly different though...
from others that I have read. The back of the lamp housing had a cap which only needed to be turned to access the bulb area. No additional screws at the back of the housing.
1st one took about 10 minutes while I gently tried to remove the grill - until I get fed up, and found the ***** to use a bit more force.
Left side took under 5 minutes. Grill popped off, 2 screws, unit comes out, twist cap, push wire clamps off which hold bulb down (down and to the sides), remove bulb, replace blub, twist cap back on, 2 screws, grill pops back in place, done.
Just a bit longer then it took me to write this post with my chicken pecking typing. (j/k)
Dunno, I read some posts that mentioned additional screw on the back...
of the housing which need to removed to access the bulb. And the back cover was not a cap in those pics, but a cover with a rubber gasket for sealing.
Different year I guess.
We have the same year and car though, same color to boot.
LOL, I know, but take a look at this...
<a href="https://forums.audiworld.com/a6/msgs/90940.phtml">fog lamp removal on '01 2.7t</a>
Interesting that its different, dont you think.
Kgnast-Nemo4.2
NY / NJ / CT Discussion
06-30-2003 06:25 AM
BlueS4orce
10-18-2002 11:54 PM
LI-S4
11-16-2001 11:22 PM
