please help....CEL is on and here are the codes
4 DTCs Found:
18010 - Power Supply Terminal 30: Voltage too Low
35-10 - - - Intermittent
17521 - O2S: B1 S1: Internal Resistance too High
17539 - O2S: B2 S1: Internal Resistance too High
16826 - Evap Emission Control Sys: Small Leak
35-00 - -
I went over a bump and hit something (the car is dropped and i have an apr exhaust on).....thanks for your help people....i need the info now cuz i am goin away to college on weds......THANKSSSSS
35-00 - -
yeah, seems like you might have caused an exhaust leak...
but I dunno about that one.
Here is a list of things to check for 'evap' DTC:
vacuum leak
02 sensor is loose or disconnected
gas cap is loose
fuel filter leak
I think the 'power voltage one' is because you swapped ECU's. That can be cleared, no problems there.
Internal resistance codes - bad O2 sensors, I think they run about $180 a piece, but I understand that VW sensors work just fine, and cost about $25 a piece.
But ya still gotta get em installed or DIY.
I just did a search here on your error codes - I suggest you do the same.
vacuum leak
gas cap is loose
fuel filter leak
AdL33
03-29-2008 08:58 AM
1bads4
9
09-21-2004 07:12 AM
EasTTcoasTT
01-11-2004 11:42 AM
