problem after problem..... NOW THIS IS BAD
!!! but they said I replace one, I should replace ALL of them, and the bearings or some S***. They said it'll cost me and 1,700.00 exactly to fix it again. And the best thing is, my birthdays in 2 days and I have no vehicle because they said they can't get my car back to me until aug 27, cause there backed up. Happy Birthday to me right??........ my experience with my NEW audi. Hope your day is going better that mine.
Regardless of the mechanical cause of the over-heating, you should be watching your temp and idiot lights. Once the steam and water are coming out, the damage has been done. If you turned it off when it went well above normal, no damage would have resulted. That's why the gauge is there. You waited far too long. Sorry, but lesson i hope learned.
Now, with a motor that has overheated, had minimal oil changes, and a bad rod, would i fix the rod? No. I'd find a good used motor and put it in. And treat it better.
The Oil change interval was in fact too long. But that was not the cause of your woes. Your cause was ignoring the dash-board.
I just saw someone selling a 2.7t motor for a couple tho...
Incidentally - flushes are bull****. If you need to clean out a motor, change the oil with high detergent oil more frequently - like very 2k for a couple times.
G
personally ( my own opinion based on years of diag ) i think the problems started with the engine flush .. I would NEVER flush an engine .. rather use a high detergent oil with more frequent changes and GRADUAlLY decrease the sludge in the engine.. flushes are very bad as they try to release everything at once and can easily if not done completely and correctly leave sludge now floating around in the engine to plug oil galleries and squirters. I think this is what happend and you busted up a rod bearing likely. "needs a rod" is not very specific and I would be suspicios of the bearings and crank also .. sorry about your luck .. you could have them repair it and take our chances or invest even more in an engine .. the choice is yours ... i would be looking to cut my losses take it as a life lesson and move on ...
Good luck ..
I sold a '98 A6 2.8 to one of my buddies years ago. The car was ****, absolutely nothing wrong with it and drove great. I think it has around 90k on the odo.
Shortly after, he takes the car to Jiffy Lube(why?????) and they convince him he needs an engine flush. The car never ran right again. Idiot lights on all the time, hesitation, overheating, you name it.
The detergents are probably fine.
The others worry me. Thinning down oil means less protection. And dissolving it ... let's not go there.
But if we do go there, it sounds like running a motor with minimal lubrication.
Anyone know what is typically done?
G
for the record, i have used rislone on old motors with good results. I always drive kinda easy while its in there. H ave had no need to do so in > decade
I'm paying for all the bearings/rods to be replaced, but one thing I talked about to all the other mechanics around town is the purge. They all said its complete B***S***. But I do know the overheating was an issue.
Had no choice to drive it, only means of transportation. But now what the mech told me is that it wasn't overheating. Temp gauge was always in the safe zone, he replaced my water pump, said it was the pump actually pumping the water out.
Costing 1,700 to fix. Hopefully it works
Car-fax basically tells you what kind of shape the paperwork is in. A "clean" carfax doesn't really tell you jack about the car itself.
You can do a heavy-duty cooling system flush if you want to make sure the cooling system is clean, but it may expose (or create) more problems. Search for radiator wood bleach, and you'll probably turn it up. I did mine, it looked like the muddy Mississippi coming out of there. I'd probably at least replace the coolant cap, in case it's clogged up and holding too much pressure in the cooling system. Make sure all the cooling fans are working the way they're supposed to. When they fail, it doesn't set a check engine light or anything.
Start running Rotella T6 5w-40 (or other HDEO-heavy duty engine oil) oil in it, with relatively short changes, like they said. It's made for turbo-diesel engines, so it has more additives for cleaning crud and keeping it suspended in the oil. Make sure you change the filter every time you change the oil, at least for a while. Half a can of seafoam in the crank-case, and idling for half an hour or so before draining the oil will speed the process up, but the risk of breaking loose some chunks and having them plug oil passages probably makes it not worth it. After you've run good clean oil in it for 5000 miles or so, you might be able to do the seafoam thing without as much risk. Oil additives get to be a religious subject, so let your conscience be your guide.
Since it's been abused (running on worn-out oil, if nothing else) and probably neglected, you may have to work hard to get ahead of the break-down cycle. Sounds like there's probably several years' worth of maintenance that's going to need done in a pretty short time. Good chance if he didn't change the oil, he didn't change the coolant either, although I guess now that's been mosly changed, what with the boilovers and the water pump replacement. Transmission oil, power steering fluid, etc.
I had an A4 2.8 that someone had run out of oil (which I found out after I bought it, naturally), ruining the rod bearings, scoring the crank, blah blah blah. I had the rod bearings replaced and it ran ok, but the love was gone, so I finally gave up and sold it, with full disclosure, to a friend of mine. He puts heavy oil in it, and his wife drives it around town, and it does fine for her. I pretty much lost my *** on the deal, and that's what it took to make me more careful about buying cars.
After the A4 thing, I bought a Subaru. A couple years later, I couldn't stand it anymore and got an allroad, knowing full well that it was going to spend a couple months in the garage before it was road-worthy. I learned more than I ever wanted to know about the 2.7t.
So maybe the Marine really did give you a head start, by giving you a life experience that will shape your car-buying for years to come. You should send him a thank-you note.
I am though placing the car for sale. Probably sound stupid by saying I'm keeping the car and selling it at the same time, well I thought alot about this car and came to the conclusion that I'll price the car for sale for a couple grand more than I bought it for, so it has a better chance for not selling (which i love that car and do want to keep it
BUT if it does sell, then better for me, I'll be able to pay off the loan and the second loan to pay for the car's maintenance...... and then I'll buy a car... perferable a newer Audi lol.Did kinda learn a lesson in one way.. don't buy a cheap car, cause you'll have to pay more in the long run, do buy a nice car to start so you'll still have a good car by the time the cheap car passes you up in costs. Well thats the way I think about it. (Obviously a 500 dollar rust bucket fart beater doesn't count.)
