Problem with rear windows.
Old Feb 10, 2005 | 11:45 PM
Melange Still Races's Avatar
New Member
Default Problem with rear windows.
I'm having an intermittent problem where my rear windows don't want to come all the way back up. They will make it about half way, act like they are binding on something, and then the anti-pinch mechanism kicks in and they go right back down. This has only happened a couple of times in cold, damp weather. Well, cold for CA, around freezing. Naturally when I took it in to the dealer, they worked fine and on two different occasions no less. Anybody run into this one before?
Thanks
Old Feb 11, 2005 | 02:37 AM
DaveyKid's Avatar
Default It happens to me sometimes when I'm driving at highway speeds. I suspect the force of the wind,
either blowing in or out, causes the anti-pinch mechanism to kick in. It's always the last window to roll up as well. Never done it for me at slow or stopped speeds however.
Old Feb 11, 2005 | 05:16 AM
arob's Avatar
Default had the same problem...
...ended up being the plastic clips that hold the window in the guides. They eventually will break off, and the window will drop and not come back up. STFA, and I believe some people have replaced them on their own. I took mine to the dealer. ~1.5 labor hrs.
Hope this helps.
Old Feb 11, 2005 | 10:14 AM
A6vanilla's Avatar
New Member
Default I had that "problem"...
See if this fits the situation. Is your sunroof open when you find the binding occuring? If it is open, then the pressure difference inside and out is doing it to you. Nothing to do but close the sunroof,then roll up the window. My fronts do this when it's cold. The rears do it whenever the sunroof lets in pounding wind pressure.
If not, then your cables need lubricating.Check the window guide replacement tech article (replace the guide while you are at it $5.00), and lube that cable well. The cold weather may bind the older lithium lubricants,causing themto solidify and chalk up. Try lubromoly 235 or similar cv joint lube grease (dealer and import parts specialists sell it).
Old Feb 11, 2005 | 11:14 AM
New Member
Default Re: I had that "problem"...
Sounds like it might be the lubrication. If it's cold enough, the problem happens with the car parked in the driveway. If it's warm, it works fine. Thanks for the tip.
greasykid
Audi A3 / S3 / RS 3 MKII
Jul 22, 2016 12:46 AM
rpickoff
Jun 18, 2007 04:19 PM
bla4ck
Oct 2, 2006 06:44 AM
celerywoof
Oct 30, 2000 11:05 PM
JAMeyers22
Jun 29, 2000 10:57 AM
