Question for those who have changed their own brake pads ( to non-OEM): did you recieve
NEW bolts with your replacement pads? I'll be replacing my rear pads soon (probably go with Mintex) and need to know if the bolts come with the pads, or if I should order a set of bolts from the dealer.
Thanks,
Jeff
Thanks,
Jeff
You might consider using loctite medium/blue.
look on the bolt threads you take out...if there is a colored bit of stuff on the threads chances are they were precoated with an adhesive. The adhesive is only rated for one use so you'll have to replace it.
FWIW, I've never heard of these bolts backing out if they're properly torqued, so YMMV.
Interesting, I had the dealer replace my stock S6 brake pads with Mintex pads...
at all four corners and nothing shows on the invoice for new bolts. They did void my brake warranty though
Maybe the bolt replacement is model specific?
