RE Tip Chips: Does forcing the car to execute shifts faster cause more wear and decrease longevity?
Old Sep 17, 2002 | 06:22 AM
  #11
GIACUser's Avatar
Junior Member
Default Yes, I believe slow shifts are more punishing, fairly common knowledge.
This is a mainstream upgrade. I have not seen any posts regretting the upgrade. Nor have I seen any post attributing damage to the upgrade. Suggest you drive one. I am fairly cheap and conservative when it comes to upgrades. I like upgrades that make a significant difference, are safe and are reasonably priced. The tip chip by itself did not meet the criteria of "significant difference". I would not have purchased it if I had not done the GIAC engine chip. The massive increase in power causes big problems with the tranny. Those problems are addressed with tip chip. I have driven a car that had an engine chip but no tip chip. With an aggressive engine chip the tip chip is an absolute must.
Old Sep 17, 2002 | 07:08 AM
  #12
Potomac-Greg's Avatar
Default Let's be careful about this. In the "old days" a "quick shift kit" would...
... make the old Hydramatic 3 speed slushbox shift quicker, and it saved the transmission from the wear and tear of excessive slipping (which smooths out shifts).
Today's transmissions are more complex. There is a lot of programming that slows shifts and retards ignition so that the torque delivered to the transmission is lightened up at the shift points.
So, I agree that there will be less slipping and heat; but I think there are other factors to consider, specifically, whether the tip chip does away with software that is designed to protect the transmission (and the rest of the drivetrain) from peak torque or torque spikes. Unfortunately, we'll never know the risks unless we kidnap a ZF Transmission engineer.
Old Sep 17, 2002 | 08:41 AM
  #13
GIACUser's Avatar
Junior Member
Default I don't have the technical knowledge or reference....
to understand all of the control factors in the ZF tranny. I tend to look at the mods like this one, on how they fare in the real world. If a lot of people have used it, are happy with the results and have had no real downside then I will put it on my consider list. Everybody has their own way of evaluating mods, to each his own.
Old Sep 17, 2002 | 09:36 AM
  #14
April's Avatar
AudiWorld Uber User
Default The quicker shifts may help the tranny live longer, but snapping off shifts will
cause more driveline wear and tear. It's a trade-off as with most things.
Old Sep 17, 2002 | 04:32 PM
  #15
S6greytness's Avatar
New Member
Hey Brian, is that Finman's plane behind the 4.2?
Old Sep 17, 2002 | 04:33 PM
  #16
Sarge's Avatar
Senior Member
Default Where do you have the Koni's set?
Reportedly the fronts are adjustable on the car, the rears have to be removed, so it's a good idea to get it right the first time in back.
Shox.com has the setup for $101.50 each for the shocks (f&r) and $235 for the springs. Sounds pretty good? Rear bar ~$100? How many $/hrs for the installation?
It would be great to see your car in person, but I'm a little far - SF north bay (Sonoma). Thanks again for the input!
Old Sep 17, 2002 | 07:57 PM
  #17
brian 4.2's Avatar
Actually that is Air Force One, no photoshop but ahh... Ikes plane.
kujo
Jan 9, 2005 10:50 AM
ColoQuattro
15
Nov 22, 2004 06:28 AM
HDClown
Mar 8, 2002 03:35 PM
Bobby Kinstle
Jun 23, 2000 08:30 AM
mudd
Mar 26, 2000 09:45 AM
