Rear Door Light Switch Location?
Old Oct 11, 2011 | 07:16 AM
spoon2000's Avatar
Default Rear Door Light Switch Location?
The right rear door on my '00 A6 has a glitch in its light switch (meaning the one that turns on the interior light when the door opens and sends a signal to activate the door open indicator on the instrument panel). The door open indicator will come on for a few moments, and then go off again (the inside light used to also come on, which was irritating at night, but I turned the switch to the "always off" position).
Where is the switch that's causing this to happen? Is it magnetic or something? I can't find it anywhere.
Thanks in advance.
Old Oct 11, 2011 | 08:43 AM
nickcarguy's Avatar
If the rear doors are similar to the front, and I believe they are, there is a micro switch built into the door latch mechanism itself. There is no separate pin switch. And They are prone to failure. I replaced my driver side front. Which obviously gets the most wear and tear. The latch assembly is not inexpensive, even online.
STFA for a write up on how to replace it.
Good luck.
Old Oct 11, 2011 | 11:44 AM
nm3210's Avatar
Oh I'll be nice: https://www.audiworld.com/tech/elec96.shtml
Old Oct 11, 2011 | 01:39 PM
spoon2000's Avatar
Originally Posted by nm3210
Holy cow. That's some fix. Many thanks for the link. Will get out the bucket of tools...
awdinut
Nov 15, 2016 05:05 PM
eldoj
Sep 7, 2007 08:01 AM
duglas
May 11, 2007 08:52 AM
ttuner333
10
Mar 8, 2006 09:52 AM
Alan S
Dec 14, 2003 07:29 PM
