Rear Porsche calipers
Does anyone know of any Rear Porsche calipers that are a direct fit onto an 2001 A6 4.2? I am using the ECS Porsche front kit. In the rear I am using a set of stock sized cross drilled and slotted rotors with stock calipers.
before you do this....contact Allroad2001 on the allroad forum..(added link)
He did the front set up all is not what ECS tells you. It turns out there is a big problem when you need to have the brakes done 20K miles down the road. Tom will explain it better.<ul><li><a href="https://forums.audiworld.com/allroad/msgs/144567.phtml">click</a></li></ul>
Rear brake upgrades aren't worth the cost/labor, IMO.
Afterall, under heavy braking a LARGE majority of the vertical forces act upon the front wheels; rear brakes don't see the same punishment that the fronts do.
I'm sure there are benefits to upgrading rear brakes (besides aesthetics), but are they worth it?
BLKPERL
07-05-2005 05:31 PM
CP
12-15-1999 01:23 PM
