Removing the Headlight switch Help
I have a 2001 A6 can someone tell me how to get the Headlight switch out of the dash. Problem. when I turn on the headlights the 3 top lights (off)( parking lights) and headlights not the outside lights but the 3 little lights over the switch go out after I turn them on in about 15 sec.so I want to check the Blub out to see if it is loose.
AudiWorld Expert
I think that this is how it is done...
I don't have my Bentley manual at work, but if I recall...
Removal: press the switch and turn toward the right simultaneously, hold the switch in this position and pull the housing from the instrument panel.
Reinstallation: simply the reverse, but first press the light switch in and turn to right simultaneously, so that the locking mechanism is countersunk. Then you can re-install.
jitsu303
02-13-2009 09:18 AM
AudiSport4000
01-29-2007 09:16 AM
