Replacing headlight leveling sensor...tips?
-Sean
. I saw it in the wheel well the other day, but didn't realize what it was. Looks like an easy fix.-Sean
*Update* Hardest part, as usual, was separating the connector. Pull the wheel off, then use a pair of needlenose pliers to hold the flats on the stud (behind the sensor arm) and remove the nylock nut, then a small hex wrench to remove the two small bolts holding the sensor to the bracket. A small flathead screwdriver will help release the tabs on the connector.
Easy fix, did it this morning before work, took maybe 20 minutes total from wheels up to torquing the lug nuts.
