For those who have done the output seals on the rear diff., is the special tool 2062 aka seal driver
Old Oct 9, 2007 | 09:21 AM
AUDIctivo's Avatar
Default For those who have done the output seals on the rear diff., is the special tool 2062 aka seal driver
a necessity? I am just wondering because I cant find it online anywhere. I tried ebay, zdmak, no luck so far. or if someone knows where I can get it please let me know! TIA.
Old Oct 9, 2007 | 09:59 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Did you try Zelenda.com?
Old Oct 9, 2007 | 10:15 AM
AUDIctivo's Avatar
Default No, I havent, and someone else said to try with Samstagsales. We ll see =)
Thanks for the tip.
Old Oct 9, 2007 | 11:19 AM
BernieBenz's Avatar
Default Why would one need such a tool? Don't mess with the input pinion shaft seal unless you're willing...
to mess with resetting the pinion bearing preload.
Old Oct 9, 2007 | 12:11 PM
donp's Avatar
Wwwwrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr.
Old Oct 9, 2007 | 06:24 PM
Barty's Avatar
New Member
Default First of all...
He is talking about the side seals aka output seals on the rear diff so the preload does not apply. Second, if you are doing the passenger side seal then yes you need the tool available from Samstag. The reason you need the tool for the passenger side is that there is no machined stop in the bore of the diff to let you know how far the seal should be seated. If you push it too far it will fall into the diff (don't ask how I found that out) ;-). The tool will only let you install the seal to the right depth. Plus it will make the install perfectly square.
Good news is the tool is only like $25 and will get the job done properly. Search the forums for my writeup. Good luck!
Bart
Old Oct 9, 2007 | 06:45 PM
BernieBenz's Avatar
You make funny noises! Please define as of no Audi content.
Old Oct 9, 2007 | 06:55 PM
BernieBenz's Avatar
Default Without knowing of or having such an idiot`s tool, one would position the new seal as was the old...
and of course polish the shaft`s/flange's mating surface to accommodate the new sealing surface. The alternative, snake oil is only $ 2.99 a bottle!
Old Oct 10, 2007 | 04:52 AM
donp's Avatar
It's Audi content. Gearset whining cuz the pinion is all wrong from botched preload.
Old Oct 10, 2007 | 05:57 AM
BernieBenz's Avatar
Right on, Don!
Turbo_Boss
Mar 23, 2014 11:07 AM
goohead
26
Jan 1, 2009 06:10 AM
tmaslar
Sep 21, 2007 06:09 PM
baudenfj
Oct 23, 2005 04:55 PM
Ben's e//S2
May 1, 2003 04:00 PM
