Timing Belt Check
There is a cover at the front of each bank that is held on by flat spring steel clips. You can pop
these clips (the plastic cover is black in color) and see part of the timing belt. While I agree that you are unlikely to uncover anything via visula inspection that would be a reliable indicator of remaining belt life, IMO it's always a good think to check out as much stuff as you can on a vehicle, just in case. There have been a few cases of people finding flaws in their TBs or some unusual wear that led them to change it as a preventative measure.
I also agree that permature sudden failure of the TB is likely to be caused by a water pump or tensioner or pulley going bad, but visually inspecting everything might turn up a problem in time to correct it prior to ay actual damamge being done.
Hope you have smallish hands; it's a tight fit but not impossible to get at.
L8braker50
12-28-2011 04:56 AM
Well, the water pump went out on my 4.2. Might as well do the timing belt. Anything else to replace?
dano-oly
11
10-11-2005 08:40 AM
BukkakeRocky
12
07-15-2002 12:10 PM
LifeinAudi
02-12-2002 09:13 AM
