timming belt problem
Old May 15, 2013 | 08:11 PM
djblack124's Avatar
Default timming belt problem
I have a 98 audi a6 with 160000 on it recently i was driving and the car started shaking hard and then cut off on me. Took it to the shop the scanner said replace the cam postion sensors. so i put in new sensors the car started then cut right back off. Then we realize the timming belt was still on but missing teeth. everybodys sayin its a 50/50 chance the engine is still good
Old May 15, 2013 | 08:31 PM
raj99's Avatar
Tech Guru
Tech Guru
not sure as to what your question is? you should get a compression check to ensure you are good. and get to work replacing the timing belt as well as all the accessories you need to: water pump, serpentine, idlers, etc
Old May 15, 2013 | 09:00 PM
2.7Lturbo's Avatar
hate to say it but you killed the engine... you won the 50/50 the first time the car died, sounds like you lost the second time.
compression test is your only hope; good luck sir.
Old May 16, 2013 | 05:43 AM
Huskerbob's Avatar
I would suggest a leak down test which you do with a static engine. Compression test requires the engine to be able to crank over several times or run which this one evidently does not do.
Not sure you killed it dead but you probably bent some valves. If that's all you did it's fixable.
Old May 16, 2013 | 06:46 AM
GTA_Driver's Avatar
Tech Guru
He killed it the first time, pretty sure of it. When it skips to the point of shaking, the timing is off so much it will hit the valves.
Old May 16, 2013 | 07:30 AM
2.7Lturbo's Avatar
wasnt trying to beat him up too much
Old May 16, 2013 | 08:10 AM
Huskerbob's Avatar
yeah, he'll have ample opportunity to do that to himself as he proceeds.
Old May 16, 2013 | 10:00 AM
GTA_Driver's Avatar
Tech Guru
edit: no engine pull needed to replace heads.
The question is, how many valves are bent. If it's only one side, you may choose to replace the head with another one.
It requires an engine pull. More $$$ than the car is worth.
If both heads have bent valves, you may choose to replace both heads. Or get another engine.
Or, you may sell the car as is for parts. Don't know if you'd get anything for it, being a '98.
I am afraid these are your only options.
Old May 16, 2013 | 01:08 PM
Airbag's Avatar
replacing heads requires an engine pull ? never done it on my audi but i have pulled the head a few times on different cars and not once pulled the whole engine.
Old May 16, 2013 | 01:17 PM
GTA_Driver's Avatar
Tech Guru
Ooops. Thought he had a 2.7T.
