timming belt problem
Old May 18, 2013 | 05:41 AM
  #11
jseklund's Avatar
GTA - even on the 2.7T an engine pull is NOT required to replace heads.
My mom's 2.7T had an oil issue and the cams ground down and I replaced one of the heads, but wound up pulling both - never pulled the engine. It wasn't easy, and an engine pull would have made the job itself easier, but I could get the heads off in 1-2 days I bet and I'm a slow worker.
A new head I think is about $500, and he should probably do a leakdown test to see what is going on....maybe he is super lucky and only bent a handful of valves on one side or something....in which case a valve job may be cheaper...
Old May 18, 2013 | 06:14 AM
  #12
Huskerbob's Avatar
Originally Posted by djblack124
I have a 98 audi a6 with 160000 on it recently i was driving and the car started shaking hard and then cut off on me. Took it to the shop the scanner said replace the cam postion sensors. so i put in new sensors the car started then cut right back off. Then we realize the timming belt was still on but missing teeth. everybodys sayin its a 50/50 chance the engine is still good
Hey dj, have you had a chance to figure anything out yet? Let us know what you come up with.
Old May 18, 2013 | 02:08 PM
  #13
GTA_Driver's Avatar
Tech Guru
I could have sworn i was reading in Bentley "with the engine removed..."
Plus several other people talked about removing the engine to replace the head(s).
But i have never done that.
So i stand corrected.
Old May 18, 2013 | 04:42 PM
  #14
jseklund's Avatar
GTA - no big deal, I just wanted to point it out.
You are actually correct, the Bentley DOES read as "Step 1, remove engine" - but it is not necessary. The issue is that you can't get the exhaust manifold off the head while the engine is in the car - but you can get the manifold off the turbo, and it can then be removed with the head and then removed from the head once it is out of the car....
Like I said...no big deal.
Old May 18, 2013 | 05:05 PM
  #15
Huskerbob's Avatar
Step #2 Repair
Step #3 Replace engine
How hard can it be?
Old May 19, 2013 | 04:21 AM
  #16
jseklund's Avatar
Huskerbob- that is correct. When I did this job, it was all new to me. I was pretty mechanically inclinded but it was my first timing belt job, and if that wasn't enough to have on my plate I found myself replacing the head with no knowledge. I almost threw up when I saw the Bentley, and it really was something like, "Remove engine". Of course, it had a reference on where to find instructions for that....but it scared the **** outta me.
Old May 19, 2013 | 05:01 AM
  #17
Huskerbob's Avatar
No kidding, sometimes I think it would be a more accurate, and much easier, instruction to say "lift body off vehicle."........
Old May 22, 2013 | 07:16 PM
  #18
djblack124's Avatar
nope nothing yet the timming belt never broke its still on pretty tight its just missing teeth so it wont catch. but before the car stopped running theres was taping some people say fix it some people say its not worth it
Old May 23, 2013 | 06:19 AM
  #19
GTA_Driver's Avatar
Tech Guru
It's missing teeth? Your timing's caput.
Even if it wasn't missing teeth, it can still jump several teeth.
Do the compression test to see how many valves are bent.
Mac D Beats
14
Nov 27, 2013 12:51 AM
clinton c
Jul 27, 2007 07:03 PM
TTS_4_to_A6
Mar 26, 2004 06:19 PM
SCarGo02
14
Jan 25, 2004 09:57 AM
UofM_Audi
Audi 100 / A6 (C4 Platform)
Mar 21, 2002 11:26 AM
