Turn Signal Relay?
Old Feb 20, 2010 | 06:44 AM
rcblackwood's Avatar
Default Turn Signal Relay?
Turn signals stopped working on 2001 A6, some of the posts say it is the hazard switch, but local auto parts guy said this car has a regular turn signal relay. Does anyone know which is true? I havnt been able to find a diagram of what the different relays are under the dash.
Old Feb 20, 2010 | 07:03 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Hmmmm...local parts guy versus a wealth of knowledge and BTDT on the forum. That *is* a tough call. - lol
Go to the dealer, buy the hazard switch, install it.
Old Feb 20, 2010 | 07:08 AM
Default thanks
Just bought this car and I was hoping for the $9 fix!
Old Feb 20, 2010 | 06:38 PM
Audi42LV8's Avatar
Hazard Unit, $ 40.00 shipped from PureMS and fix the issue. Not a relay.
Old Feb 22, 2010 | 08:17 AM
JohnK@PureMS's Avatar
Former Vendor
I wish they were that cheap still
<a href="http://www.purems.com/products/product.php/II=2492">Hazard Flasher</a>
OP, drop me a line, we might be able to work something out.
Old Mar 8, 2010 | 01:14 PM
mattn625's Avatar
rcblackwood,
I am interested in the same part. Do you have it cheaper?
-Matt
Old Mar 8, 2010 | 04:32 PM
Winstuun's Avatar
I have a 2000 2.7t
had the signals stop working. Here is how i trouble shot and fixed the problem
1. check fuse - it was ok
2. Searched audiworld forum - everyone said buy relay
3. saw that I could order part online but went to stealership to buy hazard relay to see if that was the problem. With the plan being that if it corrected the issue I could then retrun the part to the stealership and order it cheaper online.
4. No joy - new hazard flasher relay didn't fix the prob - returned it to steelership.
5. back to boards - some had replaced the signal staulk entirely....kept reading.... then I found a posting that indicated that the problem was because the wiring harness inside the steering colummn had come loose because someone had recently adjusted the steering wheel.
6. So back to the car with my tools....Easy to disassemble plastic trim from around the steering colummn, and sure enough - loose wiring harness was the issue. used some duct tape and reinstalled trim around the column...
cost - my time and a piece of tape - how is that for cheap.
let me know if you have any questions
chapman62083
Jan 25, 2012 10:51 AM
Mar48
May 29, 2011 03:46 AM
bronxnativ
Jun 23, 2010 09:39 PM
will_it_dude
Mar 6, 2006 09:11 AM
Bernie
Nov 19, 2005 02:19 PM
