Vag-com code
fault codes
1 dtc found
17579- Throttle Acutation POT#2(G188): implausible Signal
35-10 ---intermittent
I checked the archives, Obvoiusly its Throttle Acuation potentimeters. I am not sure if there are 2 or if its a redundant single unit.
But the archives made no mention of the check engine light? Could there be other problems. I am 20 miles from the closest Dealer and 60 miles from the one I frequent(near work). What should I do. Can I drive it 60 miles and have them look at it?
How much is a T A potentimeter(s), I am out of warrantee.
What year car / what ECU pn / what build date?
My old '00 threw a sh!tload of codes about the Throttle Actuator, Throttle Position Controller, and finally Internal Control Module Driver Error.... Audi admitted to some number of defective ECUs causing those errors - ECU replaced (eventually) and (those) problems went away.
If you happen to fall into the "right" range, AoA may help out if they determine ECU is defective.
Good luck!
