Valve cover kits?
Valve cover kits?
I am tired of the oil leak, so I am going to order a kit. I was looking at the kits blauparts sells. Any reasons I need to get anything other than the basic kit?
Here is the link to the 3 versions they sell.
http://www.blauparts.com/products2.asp?cat=4313
Additionally, do I need any other special tools for the cam tensioners, ie am I pulling the timing belt off and hence require the the crank and cam locking tools?
Thanks!
Forgot to mention this is for a 2001 A6 2.7t MT car.
Thanks!
2.7t
Fixing the leaks. After looking over a few faqs on oil leaks for the 2.7t, I definitely need to change the gaskets as I have 2 or 3 of the classic tell-tales for leaks caused by valve cover gaskets/tension gaskets.
To do the tensioner half moons and gaskets, you'll need the tool to compress the tensioner. It is in the enhanced Blau kit, but they also include the chain pads.
If you look at europaparts, you can customize what you want to buy and they also offer free shipping. With the tool, it's $10 less than Blau.
I've used the Blau kit before, but the valve cover gaskets didn't last very long and I was doing the job again before the next timing belt interval. I used europa the second time around, and no problems yet.
How close are you to the next timing belt service? You're likely going to need to change the front cam seals.. and that's pretty the same procedure involved with the timing belt service.. so if you can kill two birds with one stone, I'd say try to get it done @ the same time.
Jason
I think what you mean is:
"This very reason is why we include cam seals in *some of* our timing belt kits."
Your basic kit does not come with seals.
The Ultimate kit does not come with seals.
One must buy the Ultimate Plus kit to get 2 cam seals.
And why only 2 seals? There are four cam seals total. The belt must be removed to get to three of them. Why not include at least the three directly behind the belt...and if doing three, why not just include the fourth one?
There's one cam seal behind the left cam and one cam seal behind the right cam. I've done this job more than once there's only 2 cam seals in the front of the engine. We also include the Crank shaft seal. Replacing the rear cam seals is a whole other job in it's self.
We include two cam shaft seals and one crank shaft seal in our Ultimate Plus Kit as a convenience or "might as well since you're there to save yourself some work in the future" - Thus replacing everything in the "front" of the engine.
Jason
Jason
Cliff notes: Three seals on the front, not two.
Are you sure you aren't thinking about the 12v engine?
