Well I get to replace the same control arm for the third time
This is so frustrating with this car. The original failed at 65k, the replacement failed at 95k. So I guess they are getting worse with time. I am so sick of putting front suspension components on this car. It has had three sets of tie rod ends and now 6 control arms. I bought Moog chasis parts this time instead of Lemfoerder. I don't know if they will be better but if OE failed that much how much worse could they be.
My wife's A6 has 116k and is still on all original front suspension....
in fact, virtually nothing has ever needed doing to it. It does have a very slight oil leak from the cam timng adjuster seals but otherwise is all good.
I know that does not help you, but it does show not all cars are as bad.
I cannot think of any other contributory factors to ball joint failing. If you have larger tyres and turn the steering a lot while stationary then that would make a big difference to their wear rate.
The problem is disimilar metals the ball joints are
steel and the control arms are aluminum. Something has to give. I asked the dealer and they just shrugged and said yeah that is pretty common. They make a mint on Audi front suspension parts. They quoted me $500 to replace front tie rods. I almost choked on my coffee on that one. The new tie rod ends out are only $109 at ECS tuning and take maybe a 1/2 hour to put on. Same with upper control arms very easy to install. Which is good considering they wear out so quickly.
Re: The problem is disimilar metals the ball joints are
Is there any other solution? any other manufacturers of these parts or other material. Am on my third set at well with 102k on the odo.
