Will a 02+ gauge cluster work in a 00?
Old 04-19-2005, 08:04 AM
Hues's Avatar
Default Will a 02+ gauge cluster work in a 00?
Will any 02+ gauge cluster with the rings work in a 2000 4.2? im assuming they will illuminate the same, white and red. Is it just a simple plug and play?
Old 04-19-2005, 08:30 AM
Ming rings in Minn's Avatar
how hard is it to swap out the gauge cluster? DIY? do U need a VAG to code it?
Old 04-19-2005, 08:47 AM
Hues's Avatar
Default Re: how hard is it to swap out the gauge cluster? DIY? do U need a VAG to code it?
the cluster is easy to remove, two screws to undo, the there are three connectors that attach with clips. very easy. i was just doing the chrome ring mod and while taking the plastic off, i cracked a corner piece off. i still glued the rings on and i got a small smudge on the info screen. anyways, it still looks decent for now, but i would rather just search on ebay for a used 02+ cluster.
Old 04-19-2005, 10:43 AM
Junior Member
Max_A6's Avatar
Default IMO you'll need vag com
to adapt the new unit. There may be an issue with mileage as well as with immobilizer.
Old 04-19-2005, 10:58 AM
paulroad's Avatar
Default a vag and the secret key code from the dealer will be needed.
instructions from Ross-tech<ul><li><a href="http://www.ross-tech.com/vag-com/cars/Immo2-cluster-swapping.html">click</a></li></ul>
Old 04-19-2005, 12:10 PM
saabSean's Avatar
Default Grapeking and I swapped my non-immobolizer cluster recently
See my sig for a link to the tech article.
Old 04-19-2005, 07:45 PM
Hues's Avatar
Default How do i know if mine is a non-immobolizer cluster or not?
can i just swap it with another 00 cluster instead? i thought the car's computer also kept track of the miles and it would adjust it as well. SO the only way is to get the vag com tool?
Old 04-19-2005, 08:04 PM
saabSean's Avatar
Default I think the digital clock clusters are immobolizer clusters
My car has the analog clock.
der_Apotheker
10-21-2005 08:42 AM
ATH
09-03-2004 08:25 PM
spikie1.8T
05-18-2004 08:55 AM
lukek
03-23-2002 03:52 PM
audi devil
03-05-2002 03:01 PM
Quick Reply: Will a 02+ gauge cluster work in a 00?
