Wont go past 15MPH or 1500rpm in park 1998 Audi A6 C5 2.8L
#22
With VCDS check throttle body adaptation status. You need to see "ADP OK". My friend had problem with same symptoms, that we fixed by running Throttle body adaptation, as we scanned "ADP ERROR" message first. Please check and report, this fix does not cost anything.
#23
Bought this a long time ago but the software fore it needed older version of windows i was on ross tech and it said i can use a third party interface and download vcds lite. Has anyone tried to use a third party n the software from ross tech? I want to make sure i can before i buy the software....
#24
The limitations are listed here:
Ross-Tech: VCDS-Lite
#26
If your issue is with older version of windows, you should be able to obtain a copy of Windows XP. Just Google it. If you are running Windows 7, it is possible to run the software in "XP mode".
#27
Hi.
Just bought a US-spec 1999 A6 with the 2.8l AHA engine.
Removed the aftermarket alarm system. Disconnected the battery and the ECU in the process.
Put it back together and had the same problem. in neutral Revs start jumping at 1500 rpm and the car would not go over 40 km/h.
Anyone found the cure yet?
#29
Hi.
#30
Fixed the issue
Might have posted this on a diff thread to but the problem is deff ur throttle body needs to be realigned the are issues that can cause ur vag com not to work as well there are four or five sensors and modulars that can interfere with vag com not being able to talk w car
radio
Airbag sensors this one sux to get to
Instrument cluster
Abs
Tcm
And I think ur alarm modular can be an issues to
Unplug all or one at a time and keep trying the tests
https://youtu.be/2zrmhDw_v7Y
radio
Instrument cluster
Abs
Tcm
obyrne1
72
03-25-2021 11:31 AM
dbringle52
02-07-2018 07:14 AM
josepvillegas
01-04-2018 01:37 PM
