A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
2006 A6 3.2 - anyone do lowering springs AND swaybar(s)?
Old Nov 19, 2009 | 08:52 AM
DRS31649's Avatar
Default 2006 A6 3.2 - anyone do lowering springs AND swaybar(s)?
Still decicding about whether to install front and/or rear sway bars when installing Eibach pro-kit springs. Any experience or suggestions?
Thanks.
Old Nov 19, 2009 | 01:28 PM
am_ver's Avatar
I have Eibach springs and H&R rear sway bar. I did the sway bar myself, but took it to a ship for shocks/springs install.
I'd think the install of the rear sway bar is independent of the springs install.
Old Nov 20, 2009 | 11:33 AM
Jersey John's Avatar
25 Year Member
What do you think of the Eibachs? Did you replace the shocks with Eibachs?
Do you have pictures of the car with the springs now? What wheels are you running?
I had Eibachs on my B5 A4 and didn't like them at all. They dropped more than advertised and didn't help the performance that well.
Lastly, what do you think about the sway bar?
Old Nov 22, 2009 | 12:38 PM
V6UnderPressure's Avatar
I had the Eibachs in my 2001 S4 and they were excellent. Dropped the car the advertised amount. I now have them in my 2006 A6 and they also dropped the car the advertised amount although I would have them to drop it a bit lower. These cars are really high on the stock springs. I currently run the facroty 18" wheels in the winter and have a set of 19" S8 replica rims for the summer. It definately changes the whole appearence of the car with a set of wheels and rolling stock. I never really thought about doing the sway bar though. Does it make a real noticeable difference?
Old Nov 22, 2009 | 04:35 PM
am_ver's Avatar
I replaced the stock shocks with Koni's. I like this setup. Car felt it had improved handling and cornered better. The rear sway bar make the car tight around corners and gives it a more solid feel.
I need to upgrade my wheels/tires which I plan to do in spring. I have 17 inch all-seasons right now. I plan to get put 19 inch performance summer tires.
Old Nov 23, 2009 | 08:09 AM
2008A6's Avatar
I replaced springs only with Eibachs, and they are exactly a 2in. drop. I think they advertise them as 1.2in drop. I think it's a perfect drop, as I can barely fit 2 fingers bet tire and fender. They ride comfortably - not much diff than stock until I put the 19's on - then you really notice the difference.
Old Nov 23, 2009 | 09:23 AM
JPJ2007's Avatar
Doesn't the 06 have air ride? I only have springs on my front,
My rears have no springs... Does this mean I have air ride?
Was planning on lowering it but new coilover system wouldn't work
on the air ride system.
Old Nov 23, 2009 | 03:36 PM
KevinGary's Avatar
Community Builder
Air suspension was only available as a special order from the factory in 2006.
Old Nov 23, 2009 | 06:04 PM
JPJ2007's Avatar
So If my cluster has the lights for it then I have it?
Do the rear's have springs on your cars?
My Nav screen is out ( Being replaced ) so I don't know
for sure.
Old Nov 23, 2009 | 07:14 PM
jazznuts699's Avatar
your rear spring is seperate from your strut... different than the front. i would look again to the left/right of the strut for a spring... if you had air suspension it would be all the way around... not just front. let us know what you find... im curious
irelandbuyer
Jul 21, 2019 01:54 PM
AndyinMN
11
Mar 30, 2018 08:18 PM
BrianE
Sep 26, 2015 01:56 PM
beep-beep
Sep 23, 2015 04:13 PM
2005audia6
Sep 8, 2015 11:54 AM
