2007 S6 5.2 V10 Oil Leak
#11
Mark - Thanks for posting all the information on oil leak. I am about to have the seals replaced on my oil filter housing. I have ~125K on my V10 C6 S6. When accessing the oil filter housing, are there other parts you recommend replacing as preventative maintenance? Thanks in advance.
#12
Hello mark,
I appreciate someone who can work on these engines and willing to share.
I have a project S6. This one has about 90k miles and in rather good condition surprisingly. Just one issue, it pissing oil from the front divers side just in front of the wheel. I can't see it from the top and it seems to do it mainly when the car is driven and put into park. Then it drops about 3 oz and then slow drips. No smoking, no leaks from the top that I can see. I bought it to see if I could find the twin turbos and manifolds and was hoping to just work on the top and bottom without pulling. Not gonna happen now I guess....
Any ideas?
Any ideas?
#13
Hello mark,
Any ideas?
Any ideas?
#15
Hello raj99,
Hey Mark, I think I found the issue. Lets see if you can confirm. Crankshaft oil seal blew out. Possible pcv issue causing pressure in the crankcase? Any thought???
Thanks much.
Thanks much.
#16
#17
If it's leaking "like a siv" and as bad as you state, I doubt it's simply the crankcase ventilation and breather system...have you gotten the car up on a lift and washed it off and then determined where the leak is actually coming from? If not, do that as step 1, also use a dye-kit to determine, if it's too difficult.
#19
Yes, It is definitely leaking from the crankshaft oil seal. I researching I found that it is a 22 hour labor job (book numbers) $15 part and usually caused by abnormal pressure in the crankcase. The main cause for this pressure is said to be the oil exchange valve or PCV. The labor on the PCV is 20 min and a $40 part. I confirm the pressure issue as it only leaks after the car is warmed up and I'm thinking that is due to pressure and oil viscosity changing as the oil warms. No coolant leaks, no other oil issues, just that one. Runs great, no misfiring, no oil in the exhaust. I took off the oil fill cap and bingo....positive pressure.
I also nosed through this thread. https://www.audiworld.com/forums/a8-...2901607/page2/
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAOEAAADhCAIAAAC x0UUtAAAgAElEQVR4nOy9d5Rkd3UuWj3ToXLOOeccT66cU+c03 T15NDPSSBpJI2mEJCQhbDACSUYiCQG2cQIuwfjxrMsDjH0FFti ygGWD4ToBAmOlCd1dHarqvD/2zFF7BIYZhNT3vfrWb/Wq3FV1vrPDt/f+FYseYIDdDdab/QYGGOCXYMDRAXY7BhwdYLdjwNEBdjsGHB1gt2PA0QF2OwYcHWC 3Y8DRAXY7BhwdYLdjwNEBdjsGHB1gt2PA0QF2OwYcHWC3Y8DRA XY7BhwdYLdjwNEBdjsGHB1gt2PA0QF2OwYcHWC3Y8DRAXY7Bhw dYLdjwNEBdjsGHB1gt2PA0QF2OwYcHWC3Y8DRAXY7BhwdYLdjw NEBdjsGHB1gt2PA0QF2OwYcHWC3Y8DRAXY7BhwdYLdjwNEBdjs GHB1gt2PA0QF2OwYcHWC3Y8DRAXY7BhwdYLdjwNEBdjsGHB1gt 2PA0QF2OwYcHWC3Y8DRAXY7BhwdYLdjwNEBdjsGHB1gt2PA0QF 2OwYcHWC3Y8DRAXY7BhwdYLdjwNEBdjsGHB1gt2PA0QF2OwYcH WC3Y8DRAXY7BhwdYLdjwNEBdjsGHB1gt2PA0QF2OwYcHWC3Y8D RAXY7Bhz9VdD7jb56/1f++/9PDDj6S9Hb2lzr97ZputfvbW9urNN0j6Z7m52N3naX7tMb65ub nS26T3e3enSf7vXo7e3e9navv4NW29s9mqbX1jrr6xsbG1trax 3mrs7mRpem+zS98+823b/iFvh7bUztdDrdbpem6fX19a2trV/v23gTMODof4/eRmdto3ORprdpepume1ubHVh0n+53e6sX1vpd+uL51b/75rP9Lr2xvvnfvFa3+yrH1tY6QFzg3zbd3+hub/V7cLmzvdWl6deua+Bop9N5LS9XV1ev/pXeNAw4+t+jR9M9mt7u9zaBo8x65aWXwbJ97CO/JxZK7FZHJBSfm1n8yle++r3vff/ixbVut7+21nnllfNgNbe3e2trnU5nc6eJXV1d79P0Vne7s7mx3 euCpdzudTubG/3LhvOKdY0fo9f7P9GCAgYc/aXo0fR2d7vT720CO8HvA2V+95H3SkRSikhHwzG/N+R2+jgcntPpXl7e/7GP/f4PfvDPDB0vXlzrvSas7ffpPk2vddZX19d2EpHh6+vF0Y2Njcv/sX/hwoVrfZk3BwOO/lJcJiXdo+ne+trF9dU1utfvbfc/+uTHgv5QhsqmElgqgQX9ERylEnE0lcQD/ohKqZNKlCSRffg97/3Ot797Bdc2Ot3tLZqm6T5N9+j+5vbWLyLlr8lRYGdvx/mxuroK4en/KRhw9Jdga7Oz0VkDgnbWV7vbm0CWx9/7Ph6HHw3HCIz0ugPRcKKYr3hc/kQcTSYwFCFRhIzHEJfTp1Lq+Dyx2+V/2wO//d1//MH21quMW1/boi9f6/Z7G1ub6xudre7268jR9fV1+jW+vtPp/OJn7DoMOPpL0et1tyBbWr1wke7TF8+vfuJPPimTyCfHp7zuQCQ UT8SQcDAWjyCpOB70R2KRJJLEMYREU0QqgSViSCKGxKMpvzckF soUMvXRw8ef/uu/6axt0X36xRdf3ti4xJ6Nja1OZ3Nzc3tndvXrok8//6OffONvvvn3f/fcD//tR5Dk9buv30nwm8eAo78Ul7x8d3tza2OT7tOf+R+flYik4WAk6 A/hKBWLJHGUSsSQcCBer7SRJA4LQ0gSz6TJXDZdyGWK4WAsHIwl4 yiJZ7zuAHuUZzJYDx889ldf/dq///uPdv6/brfPsPbXx9rF9dM33SLgCUeHxywma7s5/sH3f+i7//C9/y9zdGtrq385Edje3l5dXWWcyPb2Nk3TV8Q6PzedhPBo5yPBGe0 STYR5z/1+f/XCxa2NzbWLq2sXV+k+/ck//ZRKoQ4HI5e4mCDQJAkLS1FYisKT5K++0BShkGs87sDSvgN/9Ief+NEPf9rv0XSf3trsM6Tp9+juNr212e9d/ra63S7zDrvdLnyNcAsoTRCDnjt3jqbp2245E/FHLXoriVAkQoV9EZPWPMwaUUnVd9569mtf/fqLP30JTsP+Jk336V6vt7Gxsb6+vrm52d+h8fb7fSao7ff729v bm5v/ndD2OuLa7SjDpwsXLqytrV1xI03T58+ff+2zzp07B3klfP6NjY 1XXnkFtOWd38gbj7W1NeYYbF/G6uoqEGWzs0H36Y8++TGRQJwmM2gKA45eQdCr5SieJBMxJBiIW i1OpUKr15mbjYmPPPn7//ovPzp/bg3+da/7KmU7nc1+nwZ+dLvdnbwBAFO3trYuXrxI0/Sjjz4a8oYD7mAykkqEkz6nH4mhWSIXDcRSUcRpcQ2zRsQ8yfL8 yh/93h9/7zv/RPfp/uUzAYgIlzudzurq6vr6OpwPcKTesMTrWjj68ssvwwV468w5vba 2BmTd2tpaX19/5ZVXGMqeO3fu3LlzDAs3Nzfhi2a+hX6/3+l0mKtvPHZahf9y4Pv0xnqH7tOf/tRnRofHPC4vhpCvYWcGS2VwJIsjWSJFXdWqlOq5TBFJ4tFwApb XHTAbbZPjM48+/Nj3v/fPV/jitbXOFeTodrudTmd9fR3SI/pynvT000/7/X6/K5Aj88VMKeyLuG0eNI4RKdLvCgTcQbCs8VDCYXaKuGKjxtSoNT/8oSf/+q//mjnE3ctgrjKv/4bZlKvm6M+18C+++GKv19vc3FxbW/v+97//gQ984KGHHnr/+9//4Q9/+Nlnn33++edXV1eBpsyn3draAkb2er3V1dU314juBLyTfr8PFy 6evwAxKJfNC/pDpUIZ0qBXDSeSvsRONEegOQrNXNUi0AyJZzCETCUwisiWCtVs upCMoxkqr1JouWwBRWQffvfv/t03n7t4fn1nvNjv93+uJbtw4UK32/3hD3+IIEgsEseTRAbPJiOpsC+CJwkSoWLBeNgXSWMZJIYG3MFo IIYl8IA76LF7SYQSCcQCgcDv9586deoTn/jEt7/97Z2+EXzghQsXLly48IYFZlfNUTiHGPFiJ2W/8pWvtFotLpebSCQOHz780EMP/dmf/dkTTzxxxx13NBqNaDQaCATK5fIDDzzw1FNP0TuE5V2Cra0txid ATEbTNN2nP/vpz0lEUqfdlYyjiRiCpggcBWqmGWoSaI7E8iSWT6P5DPKrrjSW RZNkIVuplpoZsgDRLZIgElE0HkEoPFcpNnAkrVboRXxZPlP+rQ ff+a1vfecnP/nJxsZGr9djTqeNjQ2IPjc2NjqdTqfTOXjwoNlszqZzyUiKSJCJ YBKNYgWyiMXweCBRpEo+ux+L4Vksl0YyeJxIBJNIBC1mSpFQNB wOR6NRn8+nVCplMlk2m73rrrueeeYZxmcy7u6NOYJXzdFut8u4 lU6nAxz91re+tW/fPhaLpVQq5+bmzpw58+CDD957770mk4nD4QwNDQ0PD6tUKq/X6/f7DQaDUCi02Wxf+9rXaJpeW1sDR//SSy+97h/vV0ev1zt//jycezt9/V984SkBT+hxeSulaigQddo9lVIdSeIEmiHQzE52UniBwgtZ9Oo WziRbSDpDFoq5apYq4ki6mKuSWDYaSoYDcbgrEkzotSahUExR1 AMPPPClL33pxz/+8RUpKRjX97znPTqdLpVKpRIIlsCLVCmNZLAYnkGzRIJMhlJUK p1GMjk8TyapZChFJMgcnsfjRMgbTsZTiUQiHA57PB6PxxMMBgO BgMvlkslkgUBgaWnpqaeegoyK/gVO9XXHVXN0e3ubMaLA1Geeecbr9SqVymg0WiwWJyYmpqenLRY Li8Xi8XgGgyEej+fzebjr5MmTZ8+ePXv27G//9m/n8/knnngCXgoICpH+mwWwE91uF776CxcufPazn3XYnMl4KhQIU0Qa R6k0mYuGkhmyABzdyU4KL1F4KYcVr2ohMYxCM4V0qZAuESkqHk omIwiFZtw2LxrHs0QejeNwSwbPpRIYQVChUMhkMun1+lgsduLE ic9//vM/+9nP4CP0er1PfvKTFovF7/fH4/EMlcWTBJVKo1EMiaB5olDJVvNEIY1kMmi2QBYLZDGL5TJoNovl iAQZDcQCviCKogRBxGKxSCSCoiiCIKFQSK/XZzIZr9c7NDQUj8cfeeSRnUz4jeIa7OilmOiFF16iafov//KvYrEERWWCwXA4HG3Umq1GmzPGlYplkVA0Go75PH6fx5+IJYv5 UrPeqlXqjVpzamK6VCi3m+PL+1Y+/vt/CNnAxfOrb64+t7W1dSmV3u7SffrTn/ofJoPZ7fRQRJpEqFAgSqRIJIkTKQpH0mksS2LZNJonsXwGK1B4 IYsXs3gxj5euatVLTQrNpKIokaKyRD6D5zJ4rpAuITEsjWXLuW olX8sSeTxJEikqS+QioWgyiWQyuXy+mEwiTqfb4XCFQpEzZ+74 8pf/8umnv04QVDAYrlbr4XAUSaIZPIsnSSJBZol8niiQSJpKpfNUEY mgyQiCxXASSeNxIhVFkQiajKTi0UQ0Go/Hk6kUiiBYIpGKxRLRaBxF8VgskUqh8XjS4/Gx2dzf/d3H3pjjctUc3eh04UB2t+l/+t4/41h6ZelgrdL0uPz5bMnr8I3tYRs1JrfNk4oiYV8kEU5iCRxPEq B92E0Ou8nhsrr3soa1Cp3T4tLItVki9xeff4ru0b2NPt1/VYrr9Xqve6a/vd3b3NymaRr+bm1d/jhbva2N7c3VjRd/+sJ/Pv+zJ973oYDbj8RSaSxDIhSZpNJYNk8UMngOi+HRQLxIlQrpUp Eq5alinihkiXwOz+fwfCldhlWkSrDAXF1xI7MyaPbnrjxRyBMF eM0sloOVwXNpMkcRWQJLQ5qViCGxSDIaTljNDpfDG/CF49EUU+VCkjgEEiSSxpE0pGjwN08Vs1QxS+RJLEsiaTRJYgki Fcfj0VQyjl6KuVGKKZXBVQJLpxJYhspbTHYeR/jZT3+epul+/1KrIVN62NrqPvvsc7fffufJkzc88cSTL7748s5v/mpx9dpTn75wvtPv0Rud3v6VIyvLhxfnVhJRNEvkrQa7Wqb1OQP NUiuDZvE4EfPH/Y5APJAgEiRc9Vi9Nr3dorUqRSoJVyrjy8UcyTBrRDAqvPWG217 4yYvbm5dyVSboeX1xqWvzssHuMya8R3/32//47nc8lAjHXRYHhRBhbxBPoGkkk0YyZJJCIihkHnmi0Cg2wT/m8HyeKBTIYpEqldLlcqYCj89iuTxRKKXLlWy1lq/XC43Z9tx0c2a8OtEoNsuZCjhcMkkx/Lti/UKOYlkSy5JYlsJzOxdEtBSey5CFLFXMUsUMWUgT+csxyaWnpIk 8LLgdR9JYioJELRXHU3E8GcMgdcORNDwRHpmMYeFAfLI9i6Uol 93ndQWVMq3FZL/n7vtfeeU885VCzezZZ5+z2RxDQ3sFApHFYms0Ws8//9P19Y3Xdn79Krh6X79Nr69t0336/vt+Kx5DF+ZXcCQd8sd8zgB/TOi0uIuZ8vzEQiVbLVKlPFFAIigeJyBz9Np8RpVJKVLJ+HKjyq RXGNQSjVljUYnVw6wRpUh16viN514+v7a2xgQ629vbP7cWcM3o 9eid31S3219f7dB9+sf/+qPDK4f8Ll8sGCVTOIUQsUAkg1Fg0iBuo1JpKpUukMV6oQGkuY KjpXQZuMvcBfcWyCJcZq6CES2ly3D1teuXcpQhGawsVUwTeeZ2 As0AIwvZSiFbyaVLOx8A/NtJX2ZlyAKF5wg0g6UoIG4yhgFxY+FUmsjrNWatymgxOiLBRCK GYCilVKrf+97HmeGCV145v7JywO32hkKRZBIxmSx794585jOfu zaC0tfA0bXVTbpP/+03v8XjiouFWjSSspqckWCCPya0GR2t6ng5V20UmxO1yZnW7Hh 1IoNm0SgWcAbNGotaolGKVBqp1qA02vT2sCcScofjgUS90Cily ya1eS9r+MMfehJIub29DfofVOeu8fP9PGxtdWmahu/05ZfP0X36u//wvXqpZtaZwr5QKVvMk9liOp/F01k8TSRINIqlwggeJ7JYDnw3Q8TX+mgySUHWDLaQsa+v9fIMT X/u+kUcJS/Ti7GLGbKQIQu5dAnoRWJZoGa11GxUx3eyeafJhOoDYyyZlwITi ybJZAyLRxBYiSgKDI6FU06b12X3aVXGWDg10Z6ORVPBYDgYDId CkX/913+nafpP//STDofLbLZGo/FUCnU4XCzWntnZ+Ws+XlfN0X6P7vfo+bllsUjhcvp1WrPd4nbZ fXqVMY1l56cWy7nq3Pj8wuTieHUii+WCrpDd4FBLNFKeTCFUWr TWoCvEHPLZ9tyJQyfvuf3eJ9/3kU9+/FMffOxDK0v7n3nmGfqKYs/rDXBM3W7/xRdfXr2w5nK497L2KCUKu8km4go5e8fMWqPH5nKYbEgEDXsibo vHY/VGfTEySUFwCTQFu1jOVKq5Gvj0Wr5ezdUq2SpEn8AzhtzM1Qya hajgajlKpCiwkRmykM+US/lapdiolVvN2kS11MylSwSaAeMHvjtN5IG4OJJGkyTclYiiiSgK jwHPzvCVqZ/tvJFAM7l0CUkQDqvH5w6Z9LZIMJEm8gFfuFZtFYvlZBIxGs1jY 5w/+7M/b7cnQqFIIpGCrMtqtSsUqmazDV1d13CwriUe/eY3nhtijXo9IYVcK5OqLUaHxegIesJoHIdUdGFyETQ5l9ltUpt 1cr1GqjWqTG6LJ+aPYzEcjjQaxcqZCgSvU43pO0+ffetd973vs fd/5jOfee6556Cs2ul0fvrTn77uGke322fi99M33TLE2iMXyWRCqZ AjkAokeqVWLpRyh9kijkDMkcj4coVQKePLBaNC/ohAxBbL+HKrzmY3ONwWT8AZjPpiyVAKi+FEgnyVT//Vvv4in361vj77XzmHJAjgHOOgU3EcKAgsxFIUgWbAslaKjWZtY rw5PdmeZQJZJkIFewy3MBEtgWbgX8C9aoVepzZ5XcFCtpIm8rl MEUOpeDyJIBhFZTQa3dgYJ5creL3+QCDkcLicTrdMpshm85/73Oev+WBdNUd7XfrsnfeyWCMatdGgt4qEcoVUY9LbPHaf1+H3O vxIDMug2Vq+fvzgCavOZlAaTWqz0+SK+eMZNAsRGJgQ8IlUKk0 mqVK63Cq366XGvoWlk8evP3vHXe9//APf+JtvQrD4+vY7Qvp5/vwlLTaVQMRCCWeYrVfprAaLVqERc4VirlAplkv5YgidvTZfwBl 0WzxGlUklVssFCt4wnz8iEI6JRGyxlCeTCxQKoVIpUqklGp1cb 9ZYnCZXwBmM+eNIBMViOJPg74xNd/LvV8yZgKM76RgLp6KhZCqOYykqTeSLuWq90m43piZaM5Pt2f1L hxdml1v1SagC2MwujdIgE6ukIqVUpJQIFWKBXMSXCXlSAVci4E oC3kg0lESTJLAWsqVoKImlqHymHPLHIsFEuzFVyFZ87lC13KiU G9lsPp3OBoNhvz9oMlnsdqfH48MwIhSKWK32cDj6+OPvX1/f6Hb7b5Ad7XVpvy8iEsrlMo1IKFcqdAqpRq3Qu23eoCfsMLvsJ mfQFbrz9Nm/+NxTfkdAJVbrFQavzUel0uPViYXJxZnWbLsyTiapcqZCJqlUGI Ekl0iQrXJ7sjnVqDUnx6eW962cuO7k29/2W5/99Oe+/dx3fhP9jltb3fX1jXe/6z1DrD1ahYa9d4w7wtHI1QqRTC6UauVq9p5REVss4UpVYjUE0I lgMuaPh9zhoCvkdwQ8Vq/D6LRorQalUSvTaaRatUSjEqsVQqWUJxOxxYJRIW+Yz93L4w3zR WyxQqg0qkwuszvsiaTCCNR+rkp7QuM4miQpPFfIVmrl1nhzemZ yYX5maXnx4NLCgYXZ5cn2bKXYINBMJJjwuoLcMSGPLRLypFKRU iHVaJQGvcZs0Fo0SoNaoVfJdQqpRiZWSYQKYOpe1piQJ7UYHZA hFbKVfKYMNtVqckJcS2JZ+O8YQsaiKZJM2+1OsJqxWEIoFAeD4 UAg5HS6RSLJ7Oz8z372wq9zmK6aoy++cI7FGhlijWrURqFAJpO qTXqbXKJWSTU6pcFqsPucAbVE876H3/+W2+7WSLXgE9NIZn5iYaY1O1GbnG3PTTWmm6VWo9is5esgxGTQ LBjUHJnPU4VSttwoN2cn5g6vHDl1/MbbbjrzkQ9+9O+/8dzGxc3+Jr293qW7l5qPoSun1+sx9WvAzibXKwqGq6vrq6vrzO V/+M4/DrH2mLRGuUgm5AjEPJGUL5bwRLwRjlauBo2Ms4c7yhrjDfNVYr XT5Aq5w3miALUZ0KTigUTMH48HEhFvNOQOB5xBn93vtnicJpfD 6LQbHA6j06a3m9RmrUwHyoaEKxVzJMIxEYQTKrFaJ9eb1Gb4xu wGR8AZhJMBi+Ggk2AJolqoz88sTY3PLS0c2L90eG5639T4XDSU tJldCqmGxxYJuBIRXwZ/wXz83KWS67Qqo0quA1Mql6glQgV3TDi6lwuLOyaUS9QWoyPoiy ZjWClfy1JFLEXFI0g0lIxHECRB4CiFoVQslgiFInq90el0gxE1 Gs0EQQkEong8+fTTX19b60Bk9QZpT3/5lf/FYo2wWCMqpV4h16pVBrVCLxbINXKd1WBXiFUqqSbsidQLDYvWq lcYLFqry+zOoNnp5sxkfQry/Yna5Hh1ol0Zb5Xb9UIDMgxwgkgMxRI4kSIpNJ2nCo1yc25yfv/igf2LB87cfPuHHn/ir77018//209epWn/v3Q6rq2tQYV2c3MTWqu2t7eBr71er9PpMO4Gxohpmn75xVckIq mIK5SLZFKBRMQVSvliIZvPG+FI+WKb3m7WWDRSLUi5IrYYLKtB aYQAhkqlGb6mwgh4djJJQRiDx4lUGIkHEmFPJOqLJYLJVBiBBc wOeyJBV8hr8zlNLrPGAnockFjGl4vYYs4eLncvT8QWizkSEVey lzUS9EVD/tjYMG+INWK3uNEkadBa+Bwxd0wo5EnVCr1JbzPqrGqFXi5R69Q mndoEVlMp08olanD0OrXJqLPqNWawoyq5Ti5RC7gSeIxUpBTxZ Ty2iD3CH9nDGR5iG3VWu8Ud9EVBE0jGsEgw4feGXE4fSabL5Sq GEXa702KxeTy+WCyRSKQ0Gt3tt9/5k5/8R79PX5t6f40c/fATH2OxRkZHeDKpWqsxaTUmsUAu5EkVYpVWoVdK1EqJOk8UtDL dMGskHkiYNRaf3Z9Bs41is15ojFcnwIhON2emGtPAWiBrs9Rql lokQmXwbJbIkQiFJXASoSr56mRzamVh/8z47PL8yh233PnYw49//tN//m8/+He6TzOaP7Cw3+9vbW0x47lgZfuXcflh9LlzF+DaxsbW6oW1u+ +6Zy9rj4QvlotkIq5QwhPxR7lCNp8/ylVLNFqZTq8w6BUGjVQrFyiEYyLuXp6EK1UIlXqFwW5wBF0h6M wA7YmRnzJoNofnIQbF4wSZpOAWkFqxGJ4KI1QqDcY45o8HXSGP 1es0uewGR9gTCTiDAWfQaXJJeTKw4gqxKh5KGnVWq8kZjyAklk 1E0XAgXsxV4xEk6IvazC5w5VaT02pyGnVWg9ai15j1GjPDVDCi KrkObgQ6gjXljgkFXImQJxXxZWKBfGeoOsQaGd3LFQvkeo3ZZf eFA/FUHMcQEsfSrdZ4vd4sFEoOh8vj8TkcrmAwTBBUpVJ7+umvw3cO et8bxNHH3vuB4b0cuUwDHFWrDNwxoUSoEHElnGGeRW+z6G0hd1 jKk5nU5pg/blKbg64QlUqDpl3L15ulViVbnWpMw5puzjBrpjVbzlXqpUa91C hmSniSQONYBs9WCzU8STQrrZuvP/3w7zzy2MOPP/w7j3zkgx/9i88/9Y2/+eazzz771a9+9VOf+tQXvvCFf/mXf4Ee9W9/+9u/93u/d9ddd/3O7/zOl7/85RdeeAHIysRGsONNt9un+/TXn/6bvaw93BEOuHuZQCLiCBQimWCMxx7iCEaFCqFSJ9dD3UEj1YLK K+PL+SMCeIBGqnWZ3RFvlFFGC2Qxh+eh8w2NYrV8vZavg8dgik xQ3fi5q0AWq7na3Ph8uzLutniEYyKNVOtzBrwOv98Trpaarfpk IVsJ+WMGrYXEsotzK43qeDgQV8q0YoFcqzJaTU6zwW7QWmAZdV aT3mbS28wGu9lgVyv0Rp3VqLPKJWogJRhOcPoQLQh5UolQAQGD TKwSC+Q8tgistVKmNRvsLoe3XKpXq3UMI8LhqNVqDwRCgUAIGg Yef/z9Fy6sglGANo9rY+pVc/TRRx4fG+XrdRatxmTQW5UKHXuELxEqhBwxb1Rg0lr0KiOEWTa9 XS5QGJTGgDMI3g0aFsGnN4rNZqnVroxP1CanGtMzrdnZ9tzc+H yj2ByvTkzUJhvFZg7PEwmSSJBUKl3N1SZqk/vnD5w6duOdp8/ef9cD77j/ne9+x3uuO3p8bm6uVqtVq9Wpqaljx4498MADH/jAB8xms0ajkclkcrncbrdPTU09+eSTP/jBD674OBsbW73t/n/+xwsmrXGYtVcmlIq4QsiZdAqNXCgVcySg7KrEakiJICuSCxTg/YVjIsjuJVyplCfTKwxOkysZShWpEniGaq5WpEoQeUO9ameldGd iBKIpVLOyWK5eaKzM7R+vTli0VuGYyGlyESkqjWVb9cmDK0ebt QkIEF12H4FmoP3UafMCmTRKg05tUsq0QESwpjq1SasyalVGjdJ g0FocVo/T5gVTKhEqpCKlWCCH/EnIkwIduWNCPkcs4EqkIqVMrIIFjxRwJXyuyGyyQ0nJaDSbTBa Hw0UQVLFYLhbL3/ve9+nLMh9Eouvr11KLuRaOslgjep3F7QqYTQ65TAMnlpAj1ir0 UoFcKpDLBQo4rhKuVK8weKzegDPodwSYgAyOQQ7PF6lSNVdrll oQA4A1nW3PLUwuLk7tm23PtcrtPFGABv94ZAcAACAASURBVMd6 oTFZn5obn1+Z23946cjC5GIlX41F4slkkiTJQqFQrVYbl3HzzT cfPXp0amoqnU4HAgGbzeZwOAKBwNmzb/mrv/pf6+sb6+sbl2LTPk336eOHrxthDYNKqpIoVBKFVq7WKTRKkUoh VCqESkZdUonVaolGxpfLBQq4yiTyYo6Eu5cHdtessQRdISJBVr LVdmW8kq1CtQlIyVRQXytIwaoXGu3K+Gx7jkqlNVKtRWstUqWJ xtS+2eVSvpYm8vVKe2p8LhFFjTorgWaioaTXFTRoLXKJWi5Ra5 QGrcrIxKY6tUmt0CukGvDsQp5UJddZTU67xa2S64COfI6YxxaN DfN4bBGYT8j6gbLsET6PLRIL5AqpRinTwkuJhTL2GF8mU9jtTr Vaa7M5XC5PNpsvlSoTE1PAyH6f7nb7wNE3KGf67Gf+nMUaMRnt yQRuNNhEQjkELmKe1Kgxi3lSCV9mUBoVQiVoMVqZzqa32/R2u8EBYg10gANZsRieRjLg1xrFZqvcBo+/OLXv8NKR6w4cX5nbX83VoOgPnM5iOTJJQYIS8oY9Lm8sFkulUv F4nCTJdrs9Nzc3OTm5srJy8uTJW2+99aabbtq/f3+1Wo3FYjabze32Op3uqamZP/mTT0AzxIVzF7c3u19+6ktCjkAjV6tlKrVUqZIoJDyRXqmV8mQg fzLs1Ei1GqkWiAsLZFH4sBatVSPVCsdEo6wx9hBHypOZNRaP1Z tGMhDqtCvj7cp4o9gspcs5PM/Uq8Cs1gsN8DATtclavp7Fck6TSylS4XFi3/RSvdTM4Ln5maVGdTxN5NEkabe4LUZHOBBHk6TXFdQoDWAUgaZG nRUM52uXRmlwWD1Q1eRzxJxRAdhLAVciESqUMi0ErzKxSsCVcE YFwFeg+Ksxq1AmFsklEplUKpfLlS6XB8fJUqmSyxUee+x9kJL+ Ouy8Ro5+/5/+hccVu10BisyrVQb2mEAh1SikGsiWVFKNTKgAc2LT29lDHK1MZ 9JaDEqjSWtxWzwWvc2mt6eiaMAZDHrCMX88FUWhoxFahCrZaiV bbZXbSzPLR1eOLc0s5/A86Dgus9tr80W8USilppFMlsgRGBkKhEOBMIlTFJGORxPJeCqf LVTLtXKxUilV52bmbz1924MPvP2OM3fuXz7gcXnj0UQ8mjIbLb FI8q333PfM1/+W7tEbFzeVEoVBbdSrdGqJWimWs4fYWpkW2An8g0gUhE/hmEjClcJdGqkWvL+UJ4OsHCIB4DdYXBlfbtZYYv442MhqrpbFc lgML6XLpWylkq1W8rV6oVEvNZulVqPcmmpMF9KleCChVegNSuN EY+rY/uuIFDU3ve/gytFEFHXZfdFQ0m5xW01Oi9HhcQa0KiNQBwJKqUipVuilIiXw1 aS3QSUzHIiD0U3GMDRJ+twhvcYMuqlRZx3dyx0b5rFH+OwRPmd UwCxgMPP64PrlErVErBCLpcN72VKp3Gq112qNmZm5hYV9P/zhjyH6BGcFGSqw9jfO0YsXOiSRczp8Rw6f8HpCI8PcsWEeZ1Qg Eyo0cp2EL+OO8MHwwAHTyHVmg91ucmpVRrVMq1UZLXqbUWd127 wuu8/nDPg94Yg/Fg0lkxEEiWHlTAXKVMuzKwuTi2SSCjiDEW/UbnD47H6Qe2Zas/MTC+A3M3gWS+DJSApL4DkynyPzWAIP+yIkQlFoOkvkKvnqzPjs 0QPHbrvpzD133vvxj/7hjSduIlKU3xXwu4J+VyAZQSrZyhf//P9ZmFzg7uWxh9h6hUEhVAhGhTK+nCGljC8HpiqEShA1oUDKHxH wRwQKoRIYLBcoYO00tBD2iDkSCVeqlmicJhceJ1rl9r7pJRJJp 4k8dHOWspVWfXJ5fv+Rg8dJJE1iWYveNsQaiQUTt996V73UXNl 3aGXfoemJeYfVE/RF240puUQNfNUoDaAZSUVKEEdddl8+U0YRKpUk4jE0HEr4vGGX 02+3eawWl8XsDPijE+OzCrlWLtNo1EatxqRU6OCqTKqWiJVikU IokAn4Uj5PwudJhAKZWKSQSlRSiUoklPN5Ei5HpFTotBojjyvm sAV+X/jMbWdbzck/+sNPXAMXXzeO0n36oXc9GgknT998e6M+wWKNqOQ6s8EuFym1Cr 1cpBRxJRCfyfhyrUKvEKvgBIV4CFQ6SDwNWovF6HDavH5POBJM JKIokiAyaBaJoFQq3a6M1/L1qC/mNLm8Nh8UVNEo1ig2Z1qzUK9qllowStYqt2v5OkznYDGcSUGoV DqDZotUqVVuz08sLM+u7JteOnvLXY+889H7zt4/WZ8CbTIVRjxWb7PUWphcTIURuUAhYovB+DGJPOPowWSa1GaD0q iWaICRoGgKx0RKkWpnCAsvAqZUwpUKx0SCUaGUJ9PJ9Q6j0+vw z00uTLRmirlqhiyMN6cPH7huZd+heqVNYlmrySkWyD3OAIFmFu dWDiwfyaVL7cZUlirWyq1GdRxJEBKholpqgqgJ7hh8sVqh97qC qTgeCSfDoUQwEPN5w25XwGH3AkFtVncwEGu3ptUqg1Kh02pMOq 1ZrTJoNSaN2gg3Qj+GVKKSiJXAVC5HxOWI+DyJWKSQyzRKhW5s lM/jinlcsVAgCwVjJ0/ceM/d9//sP17P0bRr4ejzP/5Piszf99a3X3fshpFhrogvc9q8Jq3FrLOqpBq5SKmT61VitYwv 1ykNUoFcJddplAaVXKdW6PUas0quE/KkEJLr1CaT3ma3uD3OgN8TDvqiyVAK6itYDE+GUg6jExr5tDKd VWer5mr75w+AFLB//sB0cwbajqDbKE8UQG6E3g7QfZAIikYxMklBk/xUY3rf9NLhpSOnT97yjvvf+a4HHzq8dCTqixXIIvRiL07tW5hc jPpiwDmtTGdSm6HwY9ZYoEokFyh0cj3QTi5QAGtFbDF/RLCzHArORMKVguYPzwWmghQg5Ij5Y0KX3Tc3ve/2W++6/vhNtXKLxLKlfM1ucZv0trFhHoFmlhYOVEvN40dvaNUncSRdLtS XFw8e2n8s5I+57L5cusRji0R8GQifIBhZjA6fO+R2+D3uoMcdd LsCTofPYffabR6b1W21uJwOXziUqNfGGYnGaLDptGaT0W402Ax 6q05rBm1RpdQrFTqJWCkSygV8KY8rBpsqEStlUjWPKxbwpXA7i pC3nL79C//X/3x9Z36ufr5+o0f36T/+o08dOXziI0/+wegITyJUBLwRJIaFvBGd0iAXKeF4yPjyS0GqXAenOCPaqRV6i NyhCgIiM8h4IXfYZXY7jE5Qs6FnyqQ2Q9G/lq/PTyxAOWCmNQstqpVsFSSteqFRLzTSSAbKP0SCxGI4GsUgeIW8J BlKNYrNpZnlpZnlI8tH7zx99oG3vO2+s/cfWDjYKDYTwWTEG82g2cn61OLUvvmJBaPK5DS5gq5QwBm0Gxxa mQ4SeZVYDbGmVqbTynRMPABhq0qsBipDsi/mSCBsBfq+ehdPKuHLhlgjQ6yRVBw/tP/Y4txKMoYZtBapSAnncCqOz04t1sqto4dOzEwupOL4iWOnxpvTS wsHculSKV/Ta8ygwEPGrZRp9RozdHlaTU6nw+dy+l+7PO5gLIqUSw2rxWUy2 i1mJ3PBbHIAU4G+GrVRozaqlHqVUg/2VSZVC/hS9phgeC+Hz5MoFTqVUr93DzuXLd1/39t/+pMX3mSOwoZEdJ/+0Ac/8n9/4YvFQnWINYwhZKPczBI5p8WllKgMSoNeoZfypCKu2GqwQ8EDUi vw+6CMQHZ5RfHDZ/eDxQJnCofWqDJ5rF6mdxPGLUrpMrh7EFnHqxOMGAmtVSA0MnO6 8FwwukzuvDC5eGT56A1HT91y/a0Pvf3db7v7wYnaZMQbhYABjWILk4vtyjgeJyxaq2BUyB7iSLh SOHOgwg4FTHD30Me9045C5iThSnnDfMGoENRW8P7A0dEhtoAr4 bFFe1ljEqHC5w4FfVGoUg6xRqANj8Jzx4/ecPrGM1mqWK+077jtLY3q+NT43PzMUoYs8DlindqkkuugpGk1O V12n93itpldDqvH6wn5vGGfN+z3RQL+aMAfDQZiwUAs4I8mE3g 2U/K4g3abx2H3QqhqMTuBpsBRsKYatVGnNet1FrhFpdRLxEo+T8Jh CwV8KYSzLNZIpdy4760Pvu57m139nmQ7tsv6228+98X/+ZUh1rBGpS/nKq1qm0iRNqPdpDYBR/ljAr8rGAkmQv6YxeiAsxxsKnMZ+MrYUafJBb0XwANIU/QKQ9QXY4Qn4ChYOyirgoOeaky3yu12ZXyqMc30AIC+Aw0r4PGB slD4KVIlGDZamdt/YOHgqWM3vvXO+956530nDp1sFJsw4pLD89BmUM5UAs6glCcbZo 1ANxN/RABFUZAwPVbvL8qZoOAOOj+wFurvIq4ESjtjwzw+R6zXmKFHB1 SkWrmVIQvLiwc/8PiH7zxz9/zM0oljp06dPL2y79Dy4sHFuRXwReCIoHTkc4f8nrDN7LJb3AFv JBJOMisaSTErEk6iCEUSuVAwDvEABKxMMADW1KC3Ai/hAhhUCFuNBpvZ5AgGYuDxWayRmemF+976YHf7zeZor0u/+MI5hqYXL3RuvOE0e5TnsXvH6xPzUwtYAncYHXqFXi6Qi3kSj9 2HpahiroojaZ87BOe31eS8wstDOcSos5o1FrPGAukIozuqxGqv zZcMpWBIjWlXq2SrjWIThNXJ+hR4/8n6VLsyPl6daJXbjWITLCujqhapUiqMRLxRIkHCTAs8Eoi+b3p pZW7/DUdP3X3mnjtPnz1+8ARMhkAJPk8UwAzX8nWD0ijjy8dY7DEWWy FU2vR2h9FpUpvBs++UVJnTTCfXM8rUpXRKqNCrjEKelDsmBDUH Kjpmg10iVECTfIYs3Hzqtgfvf8eRg8dvPnXbHbe95Zabbj9y8P jpG89MtGY4owKryQmBvs3sAjPsdQWdNq/PHYqFU/EYCisWRRh2RsLJeAzFsQyKUPEYGvBHfd4w5FUQvLqcfgheIcFi vD8w1WiwQUTrcQeRFCmTqjls4RBr9Mjh4w+/570bne5G5/Xcruya9s3r03SfXr24sb62Rffpi+fXCSzNG+W3qu0brjvVrLR8 dp9OrlMIFXKRwqyzEmhmZnJhanyukK3ASA2aJF12n9PmtZldFq MDCiHg9LUynUFp1Mn1kB1D5AdxnlFlAkExGUqlwghUSqE+DvUq 8ODQ8rezYQWYCmYVDCf0DADdy5lKo9icbc9B9yBY4sWpfccPnr jp+M1nb7nr6MqxRrEJ5fUcngcdFypAZo1FLlBAScmqs4EOxbTb gXqqVxjgE4HyDxEqzMTKhArRjrI4lM7ZI/zhIbZeYybQjN3irlfapXwtFk5VS82ZyYXbb73rnb/17vmZpXvf8kCt3JKJVRBEaVVGvyecjGEBb8Rh9XhdQeigSybwR BwDjkKOHwrGg4FYMoGTRC6VJJIJPBSMB/xR+AthgN8X8XpCHnfQ5fRDsmW1uGxWt9Phc7sCjD5gNjmkEhWf J9GojVyO6Ph1N3zkyd9/83091LX6fbrfp3s9enNzu7O2sXphLY1RvFHuRGP84x/9g2MHjkATu0qqVohV+Uz5wPKRqfG5NJGPhVMHV44uLRwoF+oUn oNpB4jAoKMRGoohBRaOifgjAilPxpSsjCoT1KsSwSQ4bkiJoKW IqdZUc7WZ1ix0A+7kKDMBV85U4GEwhwS1A7gMVhl6BibrUytz+ 4+uHLvh6KkTh04uz67UCw1QuNAoVslW58bnZ1qzGTTrMDrFHMk Yiy3mSASjQhFbrBKrTWqzRWs1qkw6uR4aRuETCUaFIAgoJWreq AAEoyHWiEZpUMq00NsRDSWjoWQ+Uy5kK5PtWZihK+VrGbKwOLd y+613zUwuGLQWhVSjU5v4HLHPHfK5QwFvJOiLgkofC6fiESQaS cWiCCzGpibiGCzGvgJ9w6GE1xMCdoI1dTp8sNQqQziUsFndkXD SZLTbbZ6AP+py+jVqo8XsZLFGpBLV9Sdv+upfPn1p/9Tdw9GtrW5nbWPt4jq91X/7fQ9yhtkBt//Rdz18ZOUQZ++YgM3fyxpOE/nZqUWd2uRzh7AUBQHWZHt2Zd+hhdnlfKYcC6fCgbjb4deqjHaD w6Q2g+4IsiIjQILr1Mp0MInhdwTCnkg8kID9tMCmAk3BNEKaD3 NwIE5VczVoAoSm1SJVgvCUSqXhWcw4fLPUYkLbmdbsvumlY/uvO3XsxuMHTyxMLtYLjXggAe0HOTwPvYVQbpBwpfwRgU6uhzem k+uhAx8kKjjZ5ALFpVZUrkQl1cjEqiHWiFKm3cMaBXdvM7tsZh czKY+lqIXZ5fmZpYnWTD5TlggVrfrkeHMaSpQivsykt4UD8XAg HgkmGHZemmqKY4k4lkzgqSSBIhSGpnEsg2MZisyTRI7AsxiaBp 0fLK7fF4HsCsJTm9VtMtohJB3ey3E5/SajHegbjaT2DI3lc5V4DGWPCThs4Znbzn7t6W9cyqrfVI52mYl N2Hy5s7YOexxvrXcuvPzKH//Bx+cnp9/5tre/6+2/PTo0spc1DNrK8BAbMiT4QtuNqanxuYXZ5cW5lYnWTC5dgqnFeC BhNzhAmoGsWS3RCMdETJoME3DgQ01qs9fmY8iKRjHoVoHGfnDl kM4zZhJqrSAL7JzV3LmPA/NgqJ63ym3ImUBYvf7IDadP3nLT8ZuXZ1eKVAmmR8gkVcvXJ+tT BbLotng0Uq1Nb/dYvQalEdIjo8qkECrBiCpFKohNJXyZXmUc3ctVyXXsEb5MrNrD GrVb3D53CAYvCTSTz5RxJD3enJ5ozcxN7wv6ogatpV5pmw12vc ZsNTlNehuM18GCcVBmMYYzmcCRFAk0hYUiFJIigZ1gUHfa2kg4 6fdFHHav0WDTakxeT0gu00D6b7O6E3HMZLQrFboD+4+GQ4nREd 6eobG7zt77989+Z211s/+6jvRefc60YyQDGoo31jtrF1c319Y3VtfWzl/obmzCFMeFF1/+5+/978cefnxqfG6INWI22K0mJ2dUoFUZpSKl1xX0OANokpwan1vZd 2hqfA5qJxBlhtxhk9os5cmEYyIoQjK1K8iLmWY5s8Zi1dmcJpf P7od5I/D+aBTDYvjOzmJoNYLJYHD3QEdYV2zQwMwQV3M1MMbA7Fa5vTy7 cuLQybtufcvdZ+654+Y7jywfreXrIMSCdACvj0RQl9mtVxhkfD lvmA+fApR/9hBnhDUqHBOppBreqEAl10HCJORJbWYXFN4gFgKClgt1HEmniT yOpDVKA3Q0c8eESpnWYnSE/LGgL8qsgDcCy+8J+z1hJEUyC0UoZpFEjiRyFJmnyHyaKjArky6 SRA5JkbEoEgzEvJ4QWE27zePzhtUqQzAQI/AsilA6rXlp38FTN9xiNNj27mGrlPq733Lf8z/+2eZGb3Pj9STpr8vR7e3tjfXO+ura6rnz5196+fxLL2+urdNb3 f7GVn9jC8h67qXVqfE5jzPgdvjtFjco+dDjaNLb3A4/gWbGm9P1ShtNklONadDh44GE1+Yzaywg3DC6N5RtICOB+iSkWQ xTg64QEwNAdgWlJiyGYzEc/DLkVcwUPNMa93PHiMHK1vL18erEeHUCNsyZG58HrerMjbffesN tx/ZfN92cAWrCKcFY9EQwadZYYMgE2kwviaMcCX9MyBnmGXVWaNew GB3xCOJxBhJRtJCtlPK1cqEOBpXCc4koKpeoYUpTLJAHfVEeW+ T3hOMRBIY5mRULp5hF4Flw7rAYIwpOn8CzJJEDamYzpVy2XMhX KTKfiGOQ5vt9kXAoEYsiXk8ImBqPoVOT82qVIZnA33rvg2+990 G9zsLliNJU4eyd94Dw1H1dN+m6eg3/v264vL29vdnZWF9do/v0+oWL250Nuk/TW931cxc2L671N3sbFzfpHv23zzx3/OgNxVy13ZiChh2X3WfUWaFh1qC1uOw+t8NvNTmFY6JEMLk0s3x 46UgtXw+6Qg6jE7wnJPjgOneK4UyoZ1Aawaza9PaAMxh0hULuc NgTiXijMBAXDyQYS3mFT9+5Z9jOnk4QU0vpMqRTIKlmsdxkfQp C25nW7KF9h2+87qbTJ285ffKWk4evn6xPwe4mwOwiVaJS6agvZ tXZJFypYFQoFyggKuWNCtQyrZAnFQvk7BE+lqKgHamQrYB6Hwu nMmQBS1EklnVYPVqVMZ8pS0VKUJcjwQSWogLeCEwwQwwKihWzf QPj5TE0TeDZNFXIZkpAR1jZTCmTLoIRpcg8cBSSfb8vEgzEopF UIo5FIymvJ4Sh6XZr2unwyWWam2687Q8//ol77n7AbHLweZLx9szpm8/Ar0+9yXb0Co52u93NzkZnbX1rvQPr/Esvv/wf/0lvdeke3bmwTnfpjbUu3aMf/90P3nj9LbNTiziShv2DgKYmvU0l10GPrVZlVAiVcBQTwSTEf+V MxWlyuS0eSKcYBYcRw0EYv6IHGZgK/SjQOQWWFS5A2wpwCMpUsLnIzlCVqVdBSwA0A6SRTCVbhcdDagV Pn23PLc0sH1w8dOLQyVuuv/W2U2eOrhyrFxpIBIV/B6XaSrYa9cXkAsUwa4S7l6eUqKUCObRvRoIJq8kJW99Uig1IJQ PeSL3SxpE09C/HI4jL7hPypEwVyusK2swuvyfsdvi9rqDfEw4H4rFwCibjcCSdp gr5XKVSbo63Z+bnlg/sP3rs6PUnjt94801nbjx168kTNx05fGJl+fD83PL01MLkxFyt2 q5WWqViPZspEXg2lSRAtLLbPOFQolioNeoTHLawXht/9JH3vf99H15c2G82OYQC2eTE3L33PABy5Juc1/8ijp5/5Rzd63c3Ns+/9HLn4mp/a5ve7tKXC6f//P1/R1PE9MS8y+GNBBOxSNJuccejKTRJet0BtUIvFSuguH8pmeBKOX u4/BGB3eCoFxonDp1Eo1g8kICiOSj8kEWBTQXFceeC4M+ssTiMThg BAMEo4o1CPg4JFvRNlzMVJv1naApMZWpUoMJCYzI8cecuOsxqF Jv7ZpcP7Tt8YN+hG46euu2m25dmluOhZCqMwO4Y0CdKpCib3i5 gi0ZYY0OsEb8rmIxhHrsvFccXpvclomieKhJoplqoE2gGiWF6j dnvCsI0iNXklAgVtXILOkdj4RSMayIJAoZGirkq7K7TbkwtLx0 6dPC660/efMftdz/4tnc+8vDjH/rgRz/6kY8/8vDjD73r0Qff9s633HXfzTedOXb0+v0rRxYX9k9PLczO7JufW5 6bXRpvz+RzlVSSAEmVIvPLS4ccdq/PGz51wy033XibzepGEcpmdWnUxsWFlY999OO/id95et1+Qwy2Yd9Y73TW1mGtr66tr66dP3+x09mk+/SxY8clYgWfL9w7NCrki6wGm16lC7iDQU9AJpRLBRKzxqwUvVrj BqGRN8zn7OGyhziQpEPnns/uB4OqEqthHEUhVIL3V0s0BqWRifxgHMCkNkPA4LX5vDafz+6HS ADmiSEMYFSqnQYVyAr1esiKSulyFsu1K+Pwfq4QBMqZSjFTrhQ b7drERGtmbnJh/9Lhm06ePnv7PdcfO1WvtNE4Hgkmgp5wIoqWc9VasYHEMLfN67X 5XFZPnijAjm5oHK/l6xSaqWSreaooGBXGgoksluONCqAdx25xw5YhQV80Fk7BhmFAz anxuYnWzOzU4qH9xybbs6kkQRK5SrmJIpTD7tWojRy2EMpCLNb I3j1sAV+q1ZhsVjejhoKMHwzEmo3Jqcl5As+WS41kAj965GSl3 BSLFM3GZDAQ4/MkWo3JoLfY7U6hQHrkyLGXXz4How30L2hnvrYf5njdOLq1tbV5 GRuXwcyz/+M/fm/fvmUWa49QKDbojJwxrpgnGmEN2022PJWLB6NmrdGg0inFcsYQM sPs0MnG2cM1ayxYDC+QRUj8oTPfaXLBIyFC0Mp03L086HxjapK gAOjker3C4DA6IXKAGCDkDoNlhewKZleYmieI//VCA4oFzPaOzJ5kV+7tmK1Mt2cnWjOt+iRI7pVio92YmplcOHHs 1J1n7r791ruOHT45O7VIoJmQP4YmSWbmLhVG4ATIoNlUGIF9XC rZKmyHVqRKSpFKKpDrlAajzuqy+2DKPuCNRIIJJEFMtGbuv/ftN5+6rVZu1cqtuel9SwsHJlozuWw54I+ajHahQCYUyKA31GS0 azUmhVwrEsrhdgFfOjbK3zM0Bo3MSoVOrTLotGalQpeIY+98x3 veeu+DCrlWpdT7fRGrxTUyzLXbPEqFVqc12e1OFmvPc899+zIT rvhpnj6o6df8A5OvG0d7l8H8og/svwB709VqDRZrj0KhstkcQr5IJBBzhtkmrbGcK43X28lw3Gt3u 61OlUTBBJrMgsRIJ9ePssaGWSNygSKNZKYa01ks5zK7VWI1FsO vO3A8EUwKx0RqiYa7lwfb9F2xgPpQmTRrLDa9HYZPwKa6zG6P1 Rt0hWL+OBrFdpYDQLGCzUKgWABbPDAT9K8O0KVLlXytVZ+cnpg fb06XC3XYc2ZqfG68OX1w5ej1x286feOZIweP40g64I3Uyi1oG 6gXGmgUg43cmMaXcqaSDKWkPNlse07ClVp1NiFHbFCb7BY36Ep QWALpfqI188H3PXnXHfdmyEIpX2tUxyvFRqs+efTIyTRVMJscX I5IKJAZ9FYQ4Q16q1ZjUin1sG8XtI9o1Ea5TMN0MfN5EhZrRCi QLS7sf/yxD5lNDpVS73EHNWoje0zg90W0GqNeZ3a7vSaT5amnvvj88z/d2upubm5fuLC6tdW9ePHSL8vBBDN9eX/6N42jrwWz7cLi4tKePcMqlSYWS5hMFq1ap1Zq5CJZKprcN7s4P zWXIzJZPE2mcLvRalAaof2C0UTB+4OMrxSpeMP8YdaIiC2O+mL QPArccppcsDMKe4gDu31ArR/qtSBgCQAAIABJREFU/jv74aFVRa8wmDUWu8EB7IQwwO8IXBEDwA7U0DFdzlSggRpkV2a jB8ag5sgCEsOgSRl2qAPtfaI1szi3giPpqfG52alFGCPOZ8oZs gD9rGkk47X5wIqTSaqSrTZLLTJJCcdEZJJymlzcvTyzxmJQmyx 6Gyj8AW/E6wqCNfV7wmiSPHHs1PTEPI6kS/kajqRTcbxWbiUTuEFvlYiVHLZQJlXbbR6nwwc5u9PhMxnt0H2n VOhEQjmHLdRpzTKpGkZBVEq9WKRgsUZGhrl8nmRkmAt9zVaLCx 7PYg0L+BKFQuV2e1msPRKJ7Nix41/84pdWV9evcOswYv8GzddfLb7whb8YHh4lyXQwGFapNCKRxOVwm 40Wk9Zo0hrjoVi71to3s7A4PT9Rb+fJLOyU5DK7Yc89KIrC3Dr UaUZZY2MsNphMk9rsdwQgvwm5w9Ab5bP7uXt5TE/xTrIqRaqdAQBs6wBylc/uZxbwFVbAGYTEHPJ6cMewSQ4Y1J1MhR9dSERRUIWqpeZ4c7pWb mWpYrM2ceP1t2TIAmdUoJRptSqjUWetV9pZLNcqtyPeqE6uD7n D8Hs0cKNeYfDZ/WgUG2aN2PR2/ogg4A45zK6QPwbbkzBGFJiaiuMhfwxapWDju0K2AsK7SChnjwn kMo3T4YMOUYvZqddZYEMkmAkRCmQctpDHFYuEcrFIsWdoDCJO6 LFXyLXDezkwNDI6wlMqdLEo4rB7dFqTVCqXSGQs1h6ZTBEKRVi sPSzWntOnb/3+9/83TdOwtdb2du+ll165Ngr9xjn6wQ8+wWLtmZmZo6hMJBIzGEwi gVit1NhNNoNar1fpnBZHKpKoFSqz49NzEzMw3QEb6TuMTqPKBO NEIH1DqQl2s2EPcdhDnGHWiE6uRyIo7B/htnisOptVZ4Pdb8AeM93vMPsG8QNTqdLKdDq53qK1wmZgDqMTL KvP7vc7AnaDA+QqKCvUC41ypgI74UAdaydT01g2RxYoPAfaZJY qVkvNyfbs3PS+/UuHw4E4bM2gkuuMOiv4a9g6wKqzyQUKn90Pk/iwt7DT5MoTBTFHolcYoLvP6/D7nAEIQFNxHDZZhhJohiwkYxgk+GBKJ1ozSIIw6K1gAkeGuR53 cG52aWX58OLC/kMHr1uYX2k1pwr5KoFno5GUy+k3GmwwcKdU6Dhs4cgwF2aV1Co DxAAwmicRK80mh98XEYvkZpPdYrFxODyj0RyPJ91ur1Kp9nh8U ql8aGhvOBx9+OFH/+Efvgv7aTL7kV8VfiMc7e/AuXMXRkfZbrf37Nm3HDt2vFgsO2xOnUbvMNt9Tq/NaJUKJDKBxG11EkksT2bBq8LPsQWcQTCosGc+47V3Zv1amU4wK hxhjYo5kjxRuPnE6ZW5/akw4rX5YNoE7DEQ/Yq+450LGlWhBwCEVQgAHEYntOXHA4mQOwyb+iIRFGpXUHdlaEo iaTSOp4l8pdhoVMebtYnJ9uzy4sFjh0/WK22FVDM2zLMYHXaLWynTwmaLbosn5A6Du3CaXKC8xgMJvcJQS pdhX3aIf5wmV8QfC/uisD8o7EIKcn2GLNTKrWKuCmo/DOVVS02X3Wc2OSA94vMkHndwYX5leenQ5MQcReaheRSq+czgaM AfNZscFrNTrTKIRQoBX7p3D5vLEUnESt3/y957h8dx3ueiy4K+vbdpOzM7M7uzMztlZ7Z39MJOSuyURBWr2b KKFcvdObbjFtvp8U1u6klyctNOHNkpciyrUewgSAAkSLD3XgCi 7v3jR21oWW5KLMex55mHDwlBUMGL7/uVt/hxs8nR2NDm92EwjYrxUjQikiTt8wWg2Whubm1tNRoMCxsbmxcs WGS3O5uaWiwW26/92hd+9nf93bi8u3+q1Wpf+MKXzGarzeZQVe3pp59duXxVqVCmc SroCSDeYITmojQXcPncVicRwGDABDkeYNMVIaMswdUpmHB9g6Q YitRGQxNMxRcbGsCZFij0d5/HYKpYlyLdXaRCR1XnI99dAJBBKkJGFV4Fjb/AiMVUaWn3MtD411esdZjmkoV0IpuQU2k939e9dPOGB0CEVC11G VusFMHSIQ6cP0DXgSMU4Q9FyKjfEYCpWSVb1UTdY/UmpVQYY8BVKhQgvTYfg7PlXFUREoBRiGEAN9COSg/sTrOpYrXUNdC7vFLslEXN50aaGo0+Lwqu8DFeXrVy7epV67q7B irlrnyuktRzQIySJR0qVD4qQc0KmhAMpWAU4POiUKQiwVBdXCr E5DAdcbu9DMO53V6DYWG12vHRj378G9948eWXX/nYxz7BcVGr1e5wuJqbW++5Z229efrZYPSHPBcuXCII0mq1RyI8 x0VLhfKmDZs/8Nj7u6tdmB9121yYD0E8AbvRamxsBbZohIzCjB0QUEyVEoImMC IZpKBnr6/s68NUc5MFhqlNhuZGQ1MYY7KJHHCcU3KaQmjUgxH+EKyjYBcFe k5bqx28mN0WDzRSIFGCHwOvzVeX3cGmCqxGYXeliTr0T+DhqAg JXU51Vntz6dK6ezatu2fTZz79+U3r729Y2ALsWLjoQQXv96Akz vgdAZbgCH8I9xFuiycppQLOoMCIhD8E8lo4QUU2LkeVeFRWhAT 8DIAfPnjYlgsd4Cne3dEPtW9Xe9+df5w76POiOEbHeDmTLlbKX eVSJ2w76zSoVDKvJTKwTxJiCh+VgMUMOieWiUU4saO9l2MFEI4 SeJhlYnExIcRkAqcDAYQgyIULF3/hC1+C7/j09Ozv/u7vf+MbLw4NHfjwhz9iMllgPvXEE++HT5iamrpx48bU1NTk5OS PDD74qWMUjve/+qu/NhgWMgxH00wmlXXYnKVs8Zn3P/3R5z/SUWr3OTx+pxfzIQ7THb8k4AhHyCj4HoI9iRSRwfEwjDGQoVPnZ 9TnqWBZD62Vy+wGzbHP7ofPBAeHehkKJyvUuKDso9EwFAlkkAo 4g1ADgIsq3P5cKAJz2buZAOALlJLT6US2nKtmU8UtG7euXrH2i Uef+vCHPsaFY6ZWG6i16uI4h9Vzp3PyYHBLIG7UY/XiPiJCRpNSCuoTj9WLuFHIEdDjSU1KalJSVzOwTyoXOuA0BUOy FUvXJBPZSrFzxdI1DBV1O/xYkHQ5/RhK8VEJ1u6ZdLGjvXfpklWwta8v63PZMkhHYPkJ/FHgOwPvKZMuAk8vRDDAgRIFlQlHUSTEspHm5tYXXvhorVY7f/7i5OTU1avXf+M3fmvDhk3Llq24fv3mBz/4jNFoRlF80aKGXbt2AaXzxw/fei/O0VqtdunSlc7O7oULF6Mozkdiclzx2N2IN9hd7XrhuQ9/6Klny9miz+GxtprfVnS6zG4aDcPqEhyTpYjM0zFY3xP+0N13dx 2vtlb7YkND84IWwGvbYiNUBcCUuxumdYERnJcAPvBiBh/x+kAA5gBg+RuleDBrrvf+Cq9m1GwhXequ9iYT2bVrNq5ds/HTn/hsPlMG96UQFkb8BBhhwAu2IvAFA84gSA8szda0ksnrBfh3AwMp no7BgZ3Rchktd3dWGKTV5DPlcqGjWupqL3evWLpGEhJOm5fEGX ObHZobXcsm9RyQ7VPJfKXclc2U8rlKudTZXu1pr/ZUyl3Aysuki4qcBIAKMSUuJmK8DEcp6JtBLgL1KIqE+Gg8GETN ZuuePYMwEL127cbExO3f/u3fffLJD3zkIx/bs2fw+PGTBsNCkqQbG5s/+clPTk1N1Y2Lf5znPcJorVb79re/YzAs5HkhhJMkQaXUpC5rLMlgfrSjWP3Icx9+8pHHRS4GwLojpb B4YC9va7UrvCpHFThKRTZef0MBkvCHQIBfd7OBcxEua2jk4UT0 OwL1HWndXQwuffgg4kZpNAyY00QdjnAKoYH3CdYP4OoDB2oYY4 C2Av72GS1XSJe62vuirPipj39m47r7mhuMWJD0e1AsSIL7ksPq gX0m+LXgPgL0JODFF3Qheb2QEDTEjUJxAj82CUFLK5mMlit+bx hIPdqmXOjIJAub1t9fKXY6rB4sSCJ+orXJHAwQHCukU4XOjr7u roH2ak8hX61T8Svlro72XuA66VpWlvRctixLOmiY+KgErGdZ0l GERBGSCfOghJYlPcbLHncgTEdIkjYYFp4/f3Fi4vaFC5dmZuZgubh9+84XX/zW669v27VrjyhKOB5qbTWuWbOm3q78mMj5qWP09u3puj9qX9+A wbDQ2GoK+pEIzUVoTpc1RZADLh8bCm9Zt+nLn/viM088m03k2hYbGw1NdbEvwAhU9nDrJQQtzknQx4AdH1ScdZjC PV6XEQP7xNhggnMUpFGAD6gF6+cl8KYhjQnGotlETo4qkOMD96/H6oWOClYAcJTGOSkeleWY2tu1pKdz4Pd/5w/BDTmEhcHSGwyvoRIFRzuX3Qc9O42Gga0Hd0UoQMIIDA5sqCg0U dflVDlXrUOzHl4DmTWrV6zt71kGPwAESrc1WyKMUK10V8pdpWI HXOjAay7kqyBlTqjpdKpQyFerle7Ojj4gPeVzFRA2CTFFVVLAj 0aCIRyj4YoHUmk0Eve4Aw67R5ZVkqQ/+clP12o1GIJeuXINYlumpmZmZuZefvmVlpY2k8nS0tK2detWAA bszH8cCP3UMTo5OTU7Ow+DscHBIYIgTW3mlqZWn9NrM1opjEwq uirIAstTaMjY2ProA4999hOfe/rxZ2JhATafuI8AN1o4xkIBkgtFYCEEMXlyVIEBPo2God0B45D6 rB4udFAa3V1fwmIJ3rojfcAZhNYeJlB3Ck0lk5RSUkRmcBZxo2 6LB+apANMwxjA4yxIcS0bAX+0f/vafNq67b4GhgcQZoMkaW6zGFqvF6HDavOB1BVJYmOOyBBd0Iag HK2cqLMG5LR5IfoJiF7q0hKDpcqqez1SPToRbftnAqhVL1+AI5 bB6fG7EYnRw4Vgp365r2VKxo7dnaU/3knSqECIY2HA2NRoXLWyGaANwjifwcIQT+3qXdXX2l0udmXQRF E7QXYEbjyiosqQD9znCiUiQKOQrghBn2ciiRQ1f+9pvwnk0OTk FGJ2cnDp4cCyZTDc2NmMYYTAs/PrXv/4WMCYnJiZgCvTD7/2fOkbhRL9x4xa49u/bt//Zp58ztZnNLaZFhoVNCxsDbj/iCURpLqdndCnhNLlCAXLdyvVf/uyvP/XoB0MBcrGhAfPidR9acFTEvDgXikDXcneUBxeKMDjL4OzbdMN3 b5vAnAfaI56Oge08nM1SRAZ3PsA6NFJkkIpSPEzyFV6FlAWW4O BHAg5CmKrSOBMNx1Ja7q//8u+cNq/b4acIFvETYOFZD/rwOAPgf+F1BesXOubF4b8iFCA9Vi+UHMAn1ONJ+A34ONdjQuGK 76j0dHf0b1p/v8grFqMDDYRsZlfAi/X3LCvmqt1dA1oiE/DjTY3GBYbGxoY2SCzyeVHwbli8qGWBoXHRwubmJpOxzRbj5VQy 39He29XZXyy0QwulKildywoxRYpripzkWAHE9TTF2W1uyBLP54 sNDU2SpPzZn/3vS5eunD599sUXv/WZz3zOYFhIUeF4XEYQzGBYWLfSnp6erg8of/i9/17Uo/BDMj9fA+LW3Mz8vr1DG+/d4HV4FhkWmltMbpsL86MRiiWCoQjNe+3B5oVG3E9tXvvAZz/5hfvW3Y958brazmt2B2w+1BkkPBjhJ3ia55lYLCzEWFFk42JEk iJyPCpjXhwPhEIBMuhBgTEESj3wDYUOCU5KOAKB9AS7eIjfBXk qHKuIGyX8IZbg4pwEtBIIaAQlHfDqQwGSJbigB31462MZLdfcY CSCJEvzATdiM7uMTWaH1ROEeZDdZzU5HWaXx+4DiQv0fzktb29 zQNoTzE2hDIUXTCiAzJrRcmk9n82UyqXOrs7+3p6lS/tXEiiNeDG7yYl4sWqho73YWc5V+3uWxWOq1eRsWNhibLHCdLa5 wdi4qLWl0WRqtVlNTrCLMrfZ21qtDYtbUYTMZcu9XUvay90pLa dKSUVOlkudspKUZF1WkmGGJ0IMxwrRiGi1OFuaTSEirCpJmuIU JbFoYdPixY3Nza0Gw0KaZjQtKUlKKERZrfbOzu7vw8Y80I9+CH 5++hide8t7Z25+dnpm8tbE9avXrly6XJuv7Xhz+4MPbDW1GRcY DE67A/H5mxpag36aColUSHTY0EWGNpcdWTlwzxc/85WBziUiGw/YfF6Tw9VqdbZYXK1We4vZY3e7nZ4IHZXjCZ6JRTlB4uUwxfGME CYjLBmhQxziIewWr9cepFAWeqa6j73L7A4FSOjQ746lq59e9Vk pjGOhqYpSPOwIYBkG5n4gZVF49X1bH8O8eJhgySAF6QCLDA0+u 9/r8NNo2G3zBl1ICKF8dn9KTsM8y2vzQQu42NDA4KzP7q+LsaDSg B1BUSsUlezq7uUxMlopdXR09nb0Dqxau7FvyUqX08/SvNcaaDG0due6+4p9ebXQV+63tTitre/wuiw+h8ljbXWam+2WFofd6HZb/W6Hv6XVsrihpa3FnEsWOgqd1WxnVi3k0hVFyah6PlPskPWMnEj rmXxcSihqkgnz9TVpjJcVWY/xMhOOppI5UVCkeAKIUV6vPxBAvv71P3gXCHqvMXp7YvLGtetXL 1+5cO78zNT0/Ozcm29s27xxU+PihgUGg9cd8HlCPh8dwmNhSvJ5qMZF5sWGZku L49EHHnvmiWdX9iwPeRBXq9VvcaB2d8gXDCGE1+0L+hEcJdAgw TG8nkhrago8EWAnHiZ5NEAFfSE0QMEA1dxkgeo26EKgqa8LS0Q 2fqdBiSehBq1vqqB2hGYLamJgSEkRGZIaodGpZKuQiYN5cRAMh gKkJup+R8BpckkRGXx4UnIaTAJxH7H53i00Gm5Z2MqFIvXUh/oqC/ZYeb1Q1Ar9uc68kOwudKaTuc7ega6lyzc++AgnyB53EPMTrjY3 5aWWVJZ0Zbs6sp0xUrC1ON/xdRo99laXpclubrSZG23WZofT6HFZPRazc+GippYmYzTMdxa72 nNdpVQ1rea1RE5Vs+lcVdEyspZKZgtSIqnpmUK+g2VEk9G5wND csLg14MdLxY77tjzU2dGbUFMedyAuqgiC+XyB1avvuXjx8rtA0 HuI0fna3Mzs1OTtWzduXr96bfLWxKULFy+evzB9e+r2xOS3/+2le1avWbRgsdPmd9oRu8VvMXrsFr/XHrQb3Y0LmtsWG3Efcd+6+/7XC59e07+K9GPuNpu1yWgzWm0WOxJAqRCNBgk0SOAoGfChwFsD kaQsJmMRhUAZlz1QJ1LBBQ3tP/CqINqUDFIswcFWSY8nYTGrx5N1PNX3ltB41U9fWDjBOKwe8Af8 FZgPbFl736qB1QqvAhm0kq367H4uFLl//QMbVm+0ttjcFg84rcpR5e5da52xWtKLnelKOZHvLXVXSh3lju5 NDzxU6uhxuAM+N+K0uN1GVzlZWtmzopQuV/NdzQuN9lbXO762Fqe12WFutBkXW0wNVoCptc3utHkXLWxqamxz 2NyFbAWCGDUpmU8VNSkJlL+Emspki2oyk8wWCoXOCCf5vLjHjU KN29piaWxoMxltCwwNixc1A1Hf6/X/wR/8v+8OQT91jM7PztVhOj87NzM1PXlr4ub1G2MHD924dn369tTVy 1dAVnry+Ilv/N9/ai92IF6sZXGbzxlAfXhbo6l5UWvAjTQamkyN5sWGxbgPf3jLw8 8/9fySriUyH19sWGRqM3vdPqfd1dTQ2tzYFvChfEQEIrAkJFQpqS lZJZ7CkXBrkxVYGpgXRz0YuIYA2mCKfrdjT4SMCoxYT91NyWk5 qkTIKJBUcB8BcU2wnYpzUjaRg8B6yMWD2TtE4spRJaNmv/r5r33qhU9DVV1Kl+HrLO9d8bEPfZwMUqZGcywsmJssoQAJY6+3 AbSYKlVS5Uw8uapneTlT7u7sW71m3ap71zvcAY87GPSg9jYH5S eXdixZ3rsily4JomowNNnafhhG6+fonbfJ4jC7WpqMzU3G5haT GE+Uyp35XCWdyPYUu1MxPS9nc0o2qaSymaKWyacL5UKhM50qqU omxqsUyVEkp2vZgf4V0YjIMnw0Igb8WDwub9y4uR4i/JM+7ylGa3PzcJRO3pq4evnK1ctXLl24eOHc+SuXLt+emJyZmp6 emBzaNfiVz3+5kCzY2+yWZovX5nWZXW2L2zA/bmm12oyOpoUtiwwNLBnZuvmhDz7xdLXcLsbiLoe7rcXotHv8Xs Tj8tutLsRPUAQLUkmRT0RZyetCFxlaWhe1ucx3tjv1G/zufDCYVcHingxSAiNKERnsemB4Wd/HAgMQaChg7AikEy4UAaBzoYil2Qp02JyWv2/d/aV0uXlBi8jGk1LKaXL1VHqfeeJZhVedJhcMB0B3BUyruofF3Uz qQiLXX+nt7ejr6ep/8KFHSYo1GW0+TxDzYkG7PyXqvdXe/q6BfKHi8AYa2yxWk9tufIfXafbC6zB57Ea3tdVpaXFYmq22Jqv D6GhrtTS1mQMkXWzv0pPZaqH93r5VRV4vC6mKnM3Ek5lUXs8Wk sWypuWzmUq10lsudYMVFIZSEU6Mi2omXSBwmqY4SVJeeunfa29 xSX/S56c/e5qZvfu6h6MUYHrpwsWzp89cunDx2pWr58+eGz985NDwyPljx2 uTt08dPPKrL3yMJ8PmZqPX7sZ9uLHJ5DA7LW8lsxgMDQsMDVw4 9tT7n3ngvq3lYiWEky6H12p2OO0eHCW9riD47YewMIEyQV/IanIvXtAKa33YssIpCEt8OFkBr8Aohdv/7o7+7rRPluBgzwSOvvWcT5CgwIwW8+LGBhNIrzqLXVJEtjRbYQ 0Bo9DHtj7eVeoG2jUANKNmuVDkbZS/uiKlkq12lbrKmXJ/79IN67fksiWT0eZx+b0OHx0gWYTuzFa7Sl2d7T3lju4mm93i8V nMznfEaMCFBVxY0I0H3bjfiXpsAafZ62hz2xosXrPbbLK3mG3e EFns6VXUZG9792P33N8ZS3dGU13xXJbX0olMIp1LFEpaqhgXdS GW0BK5dKoAs6qEmubYGEWyAT8mS9pzzz0Pk8f3KEPsJ33mZmbn Z+fuTvOem5mdmZqG30/cvHXqxMmTx0/AsXr25ImTYwePjwxfO3Vm7sbN4Z27Pv7crwhspHlho8Nsd1pcb offZLQ3NZpdLsRu8xkMDQsMixOK9ugjjz391DP3rF4X5QSn3YM EcHCIBrdop81vbLG3NlmNLXaYFgFDCjonWIoCKN+2fMK8eH2eW ndBg3F6nVMC6y7goLgtHrBMg5QmAD2IpwvJIgxus4kchdBqLPH kw+9fv2qDrdUexhhjgwnz4pqoa6LO0zGwSq1Tp+vhjtVce3uxs 6dzYPWKtcuXrTEZbUgA97sCAZsvitISFe1Ml5Z19Xe2d3X29jl xtNlu+0EYJRGGQlka42iMIxEG85EBF+azBT1tLleb02pxNrSaq LhQHehXVK2v0vEr9z++RMz2RZJLpFyOU5NSUklm5Ww+RPOioOW y1XKpW0tkWCYWjcSTek7XMgRO4xilJdIvvvitGzduzc7Ov0fZN z/p8/0YnZ+dgyEU/PH2xOTli5fOnz138viJw6Mjh/cNXjw2fmbs4KHdu8+NH7lx/sK/v/jNZ578gKXVbGw1GVstdpvH7QmaTK7WVrvd4TW1WZsampsamuW4 8uTjTz31/mcyqbypzQq+xhBjYmp1LF7Q2txgdtr89cE+cPzqrLw6FmG9CZU AGaTg6ofUbgqhWYKDFRdwXDRRhzh7uNBhLwBcvoAzGMYYKSL77 H4QTHttvoya5ekY4Q89tPnhpx79YEbNAknAZ/fD7gBAD27AbztEq7n2aqEjly6tWrn2/U8+gwRDZpOdCjF+hz9o80ghLhGOlZX0+mVrujt7egb6GVkwNDZ YLS6HyfP9LxviOTIWpcUoLXJkjEJZzEciLhyzB+2NVrvVZVjcp GQzXcsGdF3vyRc/9chTK+Tc0oi+PJ7Ps6oeS0haOp7OqnpeFLQYr8I5qiopoJsE/BjHxliGf+oDz0IlWpfg/aTPT7+vn/9R79x8vZG6efXKufHDZ8ZGTowMHd2/b3z/vvHh/cdHDx4fG/uXF7+5acNmh83Z0mxyuf0Wq6uhsa25xWxqs7Y2tzUublq0YLHZ aItyQjZd0BNpCGe3W9zmNruxxW5ssZvbnFaTu67pg/a8zpmq/wZG/dA2MTgLZj5QD9TbeTJI8XQMNrHQ3MCaCnilIIwmg5Tb4oGvA1Y/oLQGBfbme7f0VHqNDSZITakLqRVeTSsZMJ6oJ9sWU6WMmq1kq7 0d/T2dA1sfeJ8oqHaHF8coi8nus7rSMVWjYxodzUalVd393ZX29vZ KMp82LDSYjHa7xet2BF32gM3ssVu8AS9BERGek1laoIhImOQjT JwLiyGMRVy43+gTyZip2Wy1OHsGlmRy2aym9efyn9r6eD+n3CM XViXKZT5Z1PKRmMwrqVSqlM1UIpykKplUMg8W5tFInKa4uKgWC 9VXX9n2nwm5q/13wCgcq1Ch3r5548qZk5dOjp87cvDkoQPHhvePDw8dGT0wPjp6 8uj4lQsXv/lPL/b29re0tJkttoAfs5gdbS1Gh83Z0tS6aMHiliZjw6LmpobWgA+t hwcbW6ymVofV5HZYfW5H8G6Mvk3qVKflQwEA7X+dOQrsJzhTCX 8IEAwOKPUdVU7LY14c9xEswZFBClp4mAAALdVj9YKtaVepG8wr AcRAjrkboxk1C8ZSYB4N9pRLe5ffv/mhSrnL6fJbrK5gAHc7fYQXURmhIKgSSg1kSgP5Um+p3NNR6eio BlFk4YImp83v9+A2s8dp84cwFgvSFqPL60IDXiKEsVFWEvkESw s+N2ZutvvN/qA1iPuIGMvn05kVPb1LSqUeTf/8Ex9cIiQGYlpvTM9xclErCIImKKl0upxQs3xU0bV8OlX4jImmA AAgAElEQVQAn+gIJ6JIiGNjX/vqb9fmazMzc8DA/2961//IQ3R+dm5uZnZ2emZ2emZu6vb09asTly9cO3Pq/PHxk2Oj4wcPHB7ZPzY8dOzwwdH9Q6ePHztz6vSf/+mfFQoFY6vJaXcF/YjFZPV5/D6Pf4Fh8QLDYmOrpamhtZ4m2NZssRhdTpvf58YC3jvr9bthCkh 9W5wSwAuiQmBdCQuhOvcZEAz7T5GNQ1BvOVOhEBrWAagHgywRM kglBI0LRdoWG9VYYuOaTQOdS6DButvvFwpcwCgoujoKnXm9oMe T4EnR196/ae2WTeu3Ymi4pdVisbrsDg+OURzJcEEyH1NSVPSxVeuiHt99y1 d05TKr+ns7yiVjq8VkdDrsfo8btVm9zU2Wlmarzeq1mN3GNkdb q91idrtdSMAfCgZIxE8SbsrR5IhTwsrOgf5ccWWx3COpz6xb/+mHHu2Pqx3ReEVQckKilC5L8SQvJhNqVpZSupZX5PRb3ZJAkRx FsgP9y0eGx2rztVu3Jt9dRw/PzwyjczOzUKreGU7d6f3nanPT81O3bt+4cu3i2XMnj544cvDI6 IGx4aF9u3fs37tr3+4dh0cP3L557erFc7/3W7+Z1hILDAuRAOp1+0xtZr8XsVmcCwyL21rMkHsJK2mb2eOyB 96G0TpS4a3nKt0txncYnXXKCCApSvGEPwSyadSDoR4M6lRQCkD TE8YYQHD9TI1zktfmK6XLW9bep4l6NdcOQgMoeWFlAOQYNZYAj EIAGvhBwNRpee+KrRsfTCk5u8Xr9SBWm7vNaGUZPhqOUD4szYl LkvnlqdzGaqeG4PcNLFlZLt/b39/T3otjTHOTxWb1+n2E1eJpabaajE6zyWU2uawWj8Pu93qwgD+EB Ck0QDlMvqJWWlbqW5KurE4W70nm1iWzv/crH36op6/K8+2KUk2mS8lcOVdNyJm4kBJiCVlKlYpdMV7lo1I2U+JYAcfoC Cf8yR//74lb07cnZ/8zAK39DDE6Oz1zp526azJ1B6bzM7WZ27dvXrt26fy5U8dPHD10 9PDI8OCuE0cOnjl+ZPzggeHBXaNDe44fHj1zfPw3v/JVSZQbFjV6XF630wezJ6v5Tjaw1eS0W9xOm99lD7jsAbfjPyZK 8ALOoJ0H2NXFfYBXsDeD0xQadnA5ZXAWtp11YTEUBpqogzqFQm ioUCmEDrqQ9nzH+lUbHtr8cDXX3rbYiHowkIPCVwOGqBxV6hjt KHSqsQREUmUTuSVdSzes3thV6ka9IavJ7fdhVpvb5vKGmSgVom VO6EkV8kysEo6+sOE+1ekbiMubytVlucLKnuXFQifLiA6739jm sJjdFrO7rdXu9xFuF2Ixu1uarc1NFpPR6XYhSJCSxPTSrhXLct 3L1eKD2a5VjPRcz5K/+MQne0UhGwmXUlqxkMukstlUMaeXiukOWUzGeDWbqchSKi4mdC 3LMrEYL69aee/lS9fBQw8GT/Dru3h+dnc9nJ1vB2itBr66tbm52duTE9dvXLl46fypc6ePHR4Z Onpo/5HRfaODb44Ovjk+suf46OCRA/uOHxkfOTD66U/+KklQZqPN5wnaLM7GxS1OmxfiHr2uoNeFepyIyx5w2vx1jMIRC Aq7u8mgFEKHAmQdfPX0b+h74EAFqwgoUiFKqs79g/koGaTga4IVihxVuss9S7qWylEFKFegp4MSAgx8wB4ViE6A0bpv DxzA61aux30E4aPsRrexzWZz+lAyjJHhUIhqzxb6soVCONLJCl 109Lmlq8Rm0/KosCqZXdYx0NuzvLNjIJUshukYnJdkKMKEBQwNO+z+lmZra4vN 7yOkeLJc6l6xYkN3pb9bKa6OFx5WKo8rpd/a8sjzS5YVwqFMPJLJalo2GVcTqpIqp9v7y0tTWoEJC6KgZdLlV DLPR6VoJF4udf7rv/x7bb4GVo8TE7ehbXp3lk8/63r0+9//MAacm5+fnZ66NXnzys1rFy+dPX5yfPT0+PClk4fOjh8Y3fP6/u0vjw7uOHl0fHT44IljJ3du3/WBJ58O+jFTmxUNEpDADrF6QCjxuTGPEwGM1gFaRyeclOBYBjlm wA1F3CjwQuBArS9R75Ca3/JFg89HPZjT5KLRMDChoAyIc1I1166JOsy5bK12zIs7TS6wq6hb pGuifjdGYQebTeSquXbI5UkrGY/Vi7oJh8ljMjpRIkxxPEqG45JSyRXygrS+0qm7kZTNt0nNbJL1s su/Sk5uXLa2vdpXLnWvXLFu86aHVq1cXyn3pJJFKCJz2Woh31EsdL ZX+5YMrF69emO1c+nyvtWrcr0dAf7+sPZHmx7/nbVb1caWQjiU18VkMSEXNDGpy0qyqJWqyQ5dykjxZIxXk3pBS2 SEmJLLlvt6lwE6r165WZuvgQFE7ee1Z3pb/zQ/Pzs7O1ebfwuuc7Xa3OzM5MzkzZnbN25euXD+1PiJsaGD+7bv3/Xa6J5tR4b3Hjqw7/DoyPC+wUPDBy6cOTu4a/eHnn4GD2Bup8fnCSIBnMAoCCmFgEOfGwl6UMRDoD4c91NEkAwh FInSdaMywCgQOkF9ChN+0BvBTgi2qRRCwykIEisgWVtb7sROk0 Gqs9i1vHdFRs2CDzXhD5mbLCALEdk4NPs8HYNdqybq8CtgFHzR soncyv5Vjz7wWF4vOIzOMMaYGqweWwBF6LikhehIKMyVy1VdSl QT6c54soONpz0oajC8sHL949U+xe5DLc6sll61dOWyvqU97d19 Pf1L+pd2d/b09fQP9C3p7x3obO8q50qlbLG70rmiZ8mGgVUdfKLkox5Sil9d ef/XVt3XbQvqZmeGCeczml5K6ZVCsljWtWxaSEu0FKGEUrEroWbhB E3quRXL7+nq7BsdOXzj+mTtLru8ycmpdzeEeu80d/+JB67+6Znp2xO3bly9cuHc2ZMnjh85OjZ6+OD+fW++Orzr9bF9 u44ODx4d2T8+PHTowODIvj33rlopxXiXw+m0O5xOt9vtJXA6ys d9PgLDmGAwjKJhmhT8PgImMiwZCRMsjdIUQjEIHSU4kY7JbzlI AmQhqxdmVUBTgpYoFhZAqkqjYXAXq+baP/LsR5954tlYWGhe0FIXT4NenvCHILQ3SvF1NUick+KcBP5n0M6D B+raFev62vth6RD0oA6rx+tBcIwG5XuMl5NKqpgq5uR0b6a9Ry sJvpDVsMhraOmOpT60aWs6TFMuc9hna8/IG1b2rlrW0VlJVkqJro70sv7yyqXtK/sra/qrG5d1r+2trs2ml/qCDxDsx/Idv7/xwc8tW5syOlSbV0VonZfjoirKuqSl9WQupRUyUlaPJUv5zmymp CopmooocjKXLb3vkScMhsVf/cpv1d5SrtcVdhMT/y339f+Fz9zc3NTU1M2bN69cuXL+/PnTp0+fOXH06PCeowd2HhnaPrZvx9i+HYeGdhwa2nVw/94LZ05+8x//fvWqFXabxW614TgeDAY9Xn8QCyM4E8RYguAYRiLJKIaGQxgbZc VoOMaFuDAWDmNhDmP4UCRGRuv6z7uLVJhV1U146iYRclSJhQWY 6rMEB58GdtL10gJSG6FU4EIRNZaA3RI0THo8mU3k6ubR61dtWL tincCIMF4wNVvcrkAgSFAkx7ECELvAMSobT1eT5apekgje02Cz GlppG5ILC8+vWf3CmmXrkirbutBrMAhuY5Ej8iwyoIs9Kten8C s0oZdnCkF3OehbTZG/3tX752vW/8GadR9MZtvdwYTLH3Uj4QAZi0iiqCtKTtOKuppLytmUlE1J2Vy 6lNRzoqDqWpamuAe3vi8aEU1G24c//JFarQYE+7pcaXp6+l1833+eMFqr1ebm5mZmZm7fvn3r1q0bN25 cv3bl8plj548dPHFw36GhXSN7tw/veXN0767RoT0njx6+dO70zauX/vH//m2pmG9qXOywWzEMC9PRQJAIhwUtkQnTMbPJ4XEGRF6JMAJL8xw VZUIcE+LqUiew0YMzEnog2MIDiQQyJIC1BHt5YDfD+Kkedmpvc wiMCAHjMMCCkT5gFD4OKyuAKfiPtuc7tm58sD3fAaWt0+Qyt1j RQIgMsSDalIREQk7BZxaUXClRKMjZBB2n7Kh7sdVqaPUbGjpan R+IyF/tW/07q9Z/vmf5h9KFh6PyphCzHgs/k8x9pmvpr1Z7PlXs/krvit9fsfH3Vq7/+rpNH620b+aFgt2FGRZKARQxuyJkhAnzoqjreimZLCfkjCok7x jJ6Hk+KqVTBSGmFAvVlSvuMbZZrRbn6tX3zM7O361R/vEF9W97fs4wCjLCugHvzPTtW9cuX7t49vypY8cPj44N7xvZt/vA3p379+wY2rPz6NjooeGh40cOnTt1/C//7I97OiooEnA53G6nD0NCGBJCg0RcUBRJC/pwOsSBtiRC8zwjCFw8HlElXgEA1dV8MKIHsEJ6OZSqdQcKCqHh fAWkwoIAWvu6OUAdrHUmP1jlgPoUiNWldHnD6o1LupbCuQthpB QWDpORCCeC9i0hp5KJbCld7ix2VVLlslbMxdNKOB7x07jZ72ty YAZjwtCUMhh6FpofpeO/ohaeTxS/2L3yrx/+4P/3yNM7Pvu1fV/+vW8+9ZE/2fDwH9279as9qz8gZ7bEFcVkJAyGsNEUtjuZABZwBiQhEQpFeF FLp6vpVEmJp+SYmpLT5UxFU9LgKyEK6orlawJ+zOdFLGaHqmog Bq6fnWD+9S6enxuMzt71zN31TNy6MXnj6s2rl65ePHfu1PGjY6 Oj+weH9uw8dGBwz/bXx4b3nThy8NjYyOVzpw7s3fm1L32+ms/jQcRhsQY8XsQbZEJhXdYyWjbCCBFGiLISz8lvvWqUleJR+e6WC M5UluBgDgCQBdmqucnSvKAFhvNw1sKKFfcRcHYCKN8WysPTsZS cBkkqxEmCvK6/Y2DtinVRivdYvSDuw7y4IiR4Lh4XE5CtCKZ5EMtbTVfKyVJezq qMxAbokB3BLH7K4kUMiwiDATMYCIMhtri14Az0h7jljLCCFdeK 2hYtt1nP3SMmekg27fByLUa0pZl2uSi3G3W6MF/A4/ILMSUaVbAQFxX0VKqUTpVUKa0IiZSaKecqqpTMZkrRSLy3Z6ko KG2tFgwl/T4Ux0Mgsax75vziYvT27dt3TPgnb924fvX8uTMnj44fOTg8PLj 7zPEjI/t2b3/t38dHBk8eHj5+aP+18ycP7x/81Ief1wQ+FAzifr/P5caDiMDF4oIiCQlJ0OOiHotqEVYJUyIdism8drdFSv3KJoMUv HCmQjvltfkgKhy6Ipi2wm9AgAoqKDg1YdIksnEwCdTjScgvTSu ZSra6amB1Sk6DAxTswJJSimeEeExVldSduDotB84lHYXOolYoJ 0tFNa9FVMZPBS0+n9EdNLoDRgvpcoXsDs/iRteCRViLMdRi8i9oEFw+xY/KQSzmC/C+AB9EaI/HYzI6zWYcxXy+gMXq9HiDZotTlFMUI+AkH40mEomcrhfACzKlZ wu5ciqZlyU9nSr0dC9xOrxulx9FQjTFIQgG6qU6NP/nY/T7nzs+kvO12bnazOz89PT0xMTEjRvXrl29fOXy+QtnTu7d8cbQ 7u1njh48Ojy4f8ero3u2je7ZNn5g7/S1i0eGBj/x/LNyhPXYbIjHR+MUG45GGCHGq3FRl+OZeDwtCOlYVFOFJPTdIK6 Xo0pdZFffNoErL8xZ6ySpoAuBSZbAiEkpBWQo4I7UncxANZ9Rs 5qolzOVFX0rwSFwSdfS9nwHaJswL25rtfsdAYER8UBIFjVwwc0 kC+lENp3I5lPFcq56hyolpWVWYoNhzIH4zV6v2W1qM7a1tVgtJ p/LibrcfqvNb7biNqdCMUVVKyS0CBHCg4EwTVJUyOFxu/1IQ6vZ0NBmdvi8gZDNGQgGwwwj0bQYiajxeFJVs3oyl0zlU+l8 OlNIpwoxXu7tWSrFNRQJ4RjFhKMETtM08zb3+1lIb/jJn59jjNZqtflabbZWm63VZmZrk7enJyZu3759e3Z6Zn5u5saV i5fPnzk2NjK8583hXdtGdr8xumfb+IHdY3u3j+3dfmxk38UTR/Zte/1D738i5PMvNhj8Lh8SwMNk5A6lPF3NZrvy2c6EmIItfELQ6mCF zqbu5wNdP1So9VU+uEYiblRk42klAwfw3aF78GVL6bIeT0oRua +9f+OaTRCZcs+ye3k6BnuvuueFtcUWcCOJuA4YTev5lJpJqZms ni9lK+35jpyWVyMKH4pyGMsgYSZAE8GQxeFstZrbjGabzeZ3+T C3L2jzeIxWhRUSESEVT2iyEgpRbRZzs9ls9fpNdu/CRpvNgRFUzOcjMYQ1tblZOs6FJY6Nx3hVltNaKp/MlfRsQUvn4pIGAXlCTKEpLsZLMV7yeZFYTDx//uLd3yy4A9/Fd/l/AkZn3kLq/F07qqlb1yeuX7l28ez5U+MnDw8fPrBndM+2AztfG3rzO2eP7D8 xMrjn9ZdPHjpw++qlV//tX97/vvc5LFYkgNIkS5EcRUajEVmSMppaSMpZKBYheQxUTZqo3/1HNZaIUjzIm4DDD+1U3ZcPjEWhPQJhPpSnMKjva+/vLHbds+zerRsfFBjR0mzN6wWgAoKDEOhb3BZPg6FJFTVZ1EReK WQr5VxVFbWkkk4q6YyWSyeyaSWjiXqck7hQhA5QqA/3uANOl8dp97itTr/Fg9q8IXuQdgYFhBFxRiAisRBLo7TfG7BanC2tlpYmp82C+N006 g0HnSTiokJ+hsF4GmGVmJ5Jl/VkLp5IxZMZMZXhVV3Ts+AbFY3EhZgcDOARTmDC0VQqMzs7Pz09/cP9HX6c538CRmffAaO12ZmpmcmbkzeuXr907uKZE2ePHTp5ePj 46OC+N797eN+b40O7Du598/DQ7jNHRs8dO3Lq8KGXvvnNzes3uKxOs9GG+AmfF8XQsCql86ki 5DJm1Czc9QqvwgvyJiglYTIK8nywSYPuKowxUI+Cb39C0CAaL5 vIJQQto2blqMISXH/HwMNbHukqdUfIKIOzoFN1mlzGBhPwsMBhymF0mlusUVZMablSv r2YKeeShfZiZ1bPg+1jWsnAv0yE5mk0jAdCPi/i9gTcTp/H7vVbvYjdTzgR0o0pZCxO8gIZjeAshdFokPD6EI8bdZtQxEYTb oZwhlErgdlwyk1zCJeIavDjEZe0eCKlZgtqviinc5lsCUjNipw kcJpjY2E6QlNcd3fv7Oz8zMzMuy5D68/PN0Zr77zwh2fuLVXKzckbV29euXD90rmrF86cOzp6bGTv+IHdx 0b2HhrcuW/Ha4f27blw4tiZY8cunz3/z//4TysGlnvs7qAfY8NRxItqoi4woibqPZXegc4leb0AQo56OA6Ul fV6AEzyweMESlgg3enxJHhXLTY0CIzYVequ5tpBqJRRsxvXbNq y9j44jAVGBEcdvyNQ9/UFjDpNrtYGYzQcgyteERLxqJxLFjJaLqvnAalJJa0IiQgjMCEO x2hfkHAHMKcPcbgDLnfA60ECXgzxE6gP93tQjzvocPosdo/J7jY7PDabj3SzjCtKOxnSSuJmNGRFGQ8VRdmMlJajCs/FJVlPZsrJQnsiX1EzpWKpQ9eyEU6Miwkco0RBCdORYAB/6KFHZmfnf6SX04/z/NxjtPYWLt+pGgcd1SzsUaenJmcmb545PnZ6fHh8ZPDgvp2Hhna N7d+9f+ebb7787cMj+w8PD589fvzkkSN//ed/sXrpctTrd5hsQVcQhPZgr7yka2lfe//dXVS9uKx7ioDsuI5UwG4sLGTUrBSRwafX1GjGfURHofOBDVtfe OYjTzz0ZCFZhHwpsJeCkRawWICIDRqp5kWtkHYnx1RdTokRKav nK/n2XLIAbzKRVaWkEJVZmqdIDsPpAEr6A7jXh3q8iM+PBQMEEgxB 2qIYT8QlLS5pgqhGYnIsorD+KOviKBtNmImQFQ27iRgekRkxEV VEVpRENZctVyq9mXynmiwlkqVUqsSxgizpNBWJ8RKcoy6n74tf/PLMzFw9o6v2izPD/wHP3B1S3/f+T4A/AQFwdq42O1ebm5u7ceXi1M3L1y6ePTwyNDy4a/zggWOjB0b37tq77bWRPbuGd+8c3r3z5NjBsaHBP/it31gzsIQMkuBpSvhDIHuHGDGQbtYRWf84fPBupMJbzlSSUkpg RFgjAevZY/WuWXrPR5/72Ja198HMNehC7G0O3EdANAUESIN7ChSaPmfAaXFb2+zRcOzOC ZoqJhPZutsjWIlIcY2PSlw4FsFZDg3TATLkxTEvhvtwwk+QQZJ G6QgZUXglJacyUkrjVZHiOYRh3GHSTuEWDLUilIfgCU6NxlPxR DwiSHw8qWVK+fZ8rj2h5BUpn9KrEU4i8LAiJ8N0VIonODZG4HS ICL/44rfeliLyIz0cf9DzPwCjc7XaTG1+rk48hY/WSaoztdr0fG1qvjY9V5uZna/V5mq16ZnbN65fOgeM6cP7B8eG9h4d2X9o356hN98Y3PbK6O6dp w4eOD9++OyRw1/7tS+v7F8FImbg9bEEBzES9Xi7euYnBPe84wsRo/B3QWdTTJUGOpeAFVQ2kQNBKZCtwMUXtNTARg1jDIyoStlKOpFF fbjH7iNRWpOS1VIXROGAX24uXYJQG1FQxYgUJ/k4HuGDYcZPkj4iFAiRQZJEKRKleJrX43pJL1S0Qi6myyE+4qdJ F4U5CMSG4G6MwZl4VNRkRVMTiiRraiKlp1NaThWSIqer0WxWra ABCqzH42KCY2OioKBIqL9v2ZEjR78vOPRd3vs/7xidq83P1GrTtfmZO+/3YhS6/ulabbJWuz1Xm5qrzc3NTNy6dvPGlbmpibmpiWuXzp86OnZs9MD I3u3Du7aN7d15YmTw6P69ozteO7x7x+lDo1dOXxjZO/rVz39NjyftbQ4aDQPDA+ykQcsByndI7am/pXQZXoAvKOn62vurufaEoHWVuu9f/8B96+43NZpbF7UhbjRCRoFxwuCs1+YDoiBwAIDVCgOBcq5aylb CBGs3OS2tthBCVYqdfd1Lwc0ZxkCZdFHXspKsS0JCZkSJivEEx yB0CCFxlMRwCifoEMmwXEyOJ1JqOiOlEhGZx1jaR1J+GvEQiBf DUZLjOFES4rIoxGMJXU0mk3oiqYpanE0oYV2h9DiZwHykFNcSa lqIKRwbi0ZEjo396qc/Nzs7/zbi/czMzC8wRu9+vw+jdZhOzdem7vzFmVptrjY/PTN9e3rixs2rl65eOHvzyoUz42OHhnaN7tl+aHDnocGdB3dvP7 Rn1xsvfXv8wOiti1eO7B/50q/+mi4oXouT8BOEn2BwBm5/SLjLafm0ms8kCplEIasVc3opp5fyyXI+VSymSkAGrWSrGTWTVt Jb193/gYeerGQrmBd3WtwOoxP14SzBhRCK8IdYMuKxegNuhPCHeEZgCY 5nhPZ8RyXfnojruWQBKlGX1bPI0ID4iWQiCxiFkJBsppTUc6qS kkVN4SSZEflQhMEZEqVwjMJwCg3RXESI8nFRUOR4QuGVeFiI4i yDhCksjAVJFCEpkuVjYlyWonE+HGWUhKrrKU1NqaKmCZkUnxNw CbESYTyiKqlyqRPHaFnScIxKJXP/56/+tvZ94pDp6elfxPlorVa764r/j4u+/rwDkXpubm5upv7r/NwMvDeuX7186cLpUyeOjh0a3T90YHDvgcG9w4O7D+1588jebcc O7Llw9OClk+M7Xv73Tz3/oaKetBvNTrM9hJCJuJ5OZCVB1+LpQrazs315tbq0VOjLpjvTej mTrOTSlXK2I61kSulyJVUqJXP33bvxY0//yqqepT6rC/PjBEqbW6weZ4AlIwEvBiRRGmdCWJgIkjhCsWSEg14+VUwmskpc 7+temkuXcISiCHaBocFqckKsbT1mBBzygXGiRhTYcvF0jMYZIk hiQZKjonJMheA8mF3QAYpGwywZYagoF45FWTHGS6KgyJKmyLqq JBk6EmGEtJ7XpQzupwIOlCGiuprRtWyMlxNqWkukPe7Ah557YX Dvgf/Cb/D/AIz+ZM/cD3impqZu3bp1+fLl06dPHzlyZGRkZGho6MDg7v07vju8/dvD2789uvvVY8O7Th4aGj+wd//ONz/67NOZRMLSYvLYvRQWDvpwEudSWimf7ykUevP5nkyqI6lVUno5n 6lW811JKdXX3l9JlXrLnc8/8fRjW7aKFBuwe0iUIlDa1GrzuRGW5oMwEnIGGCrqsHoogpWERE rLJeQUHeI0JS0JiWyqCPlMpXw7iTNBH77A0GBqtZE4k0kWIFUM/mop3w7DMmAa8HQMqltQY0cpHrjb9dhpOabGWBHoNVw4FmGEuoc rz8UhQleIyiTO+NwIgdLxmCpLOscKoqByrMBH45s23v/Qg49evfJu8ux+0PNLjP5HDsv8/Pz09PSNGzcuXLhw4sSJsbGx0ZGh8ZFdh/dtG9n1yt5tL+347j/vevWlsX27zh8fPzY6/M//+I9PP/GEyEVdFgfmR5kQiwXJKCuJsaSmFgrZzvZyf2e1v7vS31nuhmVS KV1at3Ldk1sfz6kpe4s55EPDBIMFSXObHTAKGU4QgQdAYWk+wg jJRLaUb6+WuiAujKX5cqGjvdy9pG+FJCRCWLhxUWtzg9Fh9TBU FCb81VJXtdQFFTPEOcOGDFIuqrl2cKMY6FyytHtZNdeuxhJyTE W8WAgL81w8IadSWk5XM0pcF3mFpflYRIqyIhYk65m8CTlFhti4 mFCVFEVyST37xONPfe6zX5z/z45Ev+f5hcPo/A947v6Eqampa9eunT9//vSpY+dPHz55ZPDo6O5jB/ccGtqxZ9t3drz67T3bvjv45utnjx65eObky//2zx98/HGR49xWu8/pJVEqQvOKkID9ZCFdai929nb091b7FF7trfY+9ehT/R39focfcSM0SocJJuDFTK02l65NNSsAABQ0SURBVN0Hh6LL7gt 4MYpgK8XOhJwa6F2ez5R5Lg6hoKV8+wNbHoZGnqGiPBeHhokLx 2xm1wJDQ+OiVo8zQOIMxNyn1Ex7vqOr1J1N5CDcAma9YAQEqcG QQYW4USJIyqKmKWlIdkzreVVKxiISS/NcOEaHODQQ8rkRNBCKMEI8psZjaoyXpbhGhth8rrJl89ZyqWPX zsHJif/s/vPu55cYvfO8jZUDt//kxM0bV8+dPTl6dGzfifEDJ8YPjI3sPrB3+/DgjsMH9gzt2Da0Y9vJsdGLJ4+99tK/PPfkY3KENTc0O8123IdHqagaU9NKOq/ni6miKiZ6O/oe3PLwg1seVkUN8WJyTKUwmiTCPk/Q1GY1G21IAA/6MbvV5fMEGToiiSofEcvFdkXS+IgYYWOSqPJcHAuSEMHY1700p eVEXknr+a72PlVKYkHSbnE3NxgXGZpaGk1Om1fg4hktV8pWMlp Ok5LA5StmytFwTBU1KKa7Kj39XUv6u5asWX5ve7kbjup4TAVtA gAUAlICXozEGZ6Li7wiRGUhKueyZRQhcYy+/76HH7j/4fXrNl+7emv2vxKiv3gY/UEPdJ3fN2Seuz15/dq1c+fPHz99YuzIoaEDe7cP7nx9cOfr217+18MHdo2P7Nn75ss H97556eThI/t3fevv/s9996zJKaq7zWJc1Ih7/FpMTsUTcS5eSpe++NkvPfX40yKv+NwIFiRjEYlAaZIIIwHcYXO 3Npu87kAIp91On88T9HuRQq68cvkaAqNokv34Rz9VzFcaF7e0N JqEqAy8J5FX1t2zqVzoUOJ6pdiZTRUTckqIynSI83tQm9llbrM nlXRWz+dTxayezyUL1UJHb0f/QPfSe1eu27L+/o33bl6z/N6VS1ZX8u1iROIZAZAH1zpDRUmcwYJk0IfDBjVMRuIxVRY1+Jx 4TKWpSDQSX7N6/dYH3pfLlra9sRNUy/+Fzy8xeuepR5p/76h5bmLy+vTMrdm5ycmJa1cunzt3evzYkeFDB/bs2/HKjlf/Zc/rLx3c+8bBPa8NvvHSgR0vnzy498rJ49/4y798aN0GgaKDdgfu8XM4GaW5nmrXJ174ZE97n9XkdNr8fh/BhAUyxDJ0hCZZNEgARmPROBokkACOo2RCSXIM77R7BvqWnT976 eL5K2+8tv2fX3zpkx/7XwsMDZlkYdnAqmyqeO/qDVA1JuSUrmZSWg6u6XhMpUNcT3tfPlWUeCVC80yIo3EmTLAgi REjEktGKCzMM0KMFWOsqElJ6JMijMBQ0RAW9ntQ8B4M+vAwGYl FJEgZ0NWMKiWjrEiG2HVrNz/5xNMd7b3ve+SJ2nxtbvadF9Pv+vklRr/nmZ2dBVZ/PXT19vTk7PzU7NzticnrE7euTdy6evnC6aOHD5w8Onz22PDRkZ 17t700+Ma/jg2+Njb42t7X/+3U8NC1E8fPHhz9hz//8wfXro2RFOp00UEsSnN8OGI3OQiUjjAChobjoh6mo1FO4CNimO KMrZaAD00oSZpkCYyqljtxlGxpMv7RH/7pkbFj+/eNnDx+Zvr23CvfeePv/+YbJ4+dZWle5JXeriUrl93T0zkg8kouXaoUO5OJrMgrSlzPJAv FXLWYKcdYEfXhiBcDM4EwwfKMQGHhGCvyjMAzghxTo+EYESRJl I7HVIaKwjFsM7v8HpShovGYShGsEJV5Lg6jho5KTy5dIlB62dL VL3z4E+VSZ4yXx4+cmJ2p1eZrv6xH39NnrjY/V5udnZ+ZnZ+am5+anZucm52szd46e/LQyaP7jx7cdXDojZE93x3e/fLBvS8f2vvqgW3f3f/6K2O7tp8+NDo+NPg3f/onm1evCfn8LovN0mJyWZ0cw2dS+bSeh3kNG46qciJMMbGo4HF5 I2yUYyL5bIENc3ar49e/9JV9e4emJqcnbk7W5ms3r0/euDo5PTn/+7/zh9/4h285rJ5MsrB2zcblS1arUlJXM5qSVuK6pqQhpjGfKUNLjgZCb ocfAskDXgwLkiEs/I4vZEaaWm0OqwfxExFG0NVMPlMO+vAoKypxXRY1noszVFRT0iu Wrnnyiacz6WJSz/3Ob/8/83N3ADp1+7+ysf8lRn/EM1ebh3d2fmZubmZ27vbc7O252clrl89cuXD83KmDp8b3jY/uPLTvtZE93x3Z9cqhXW8MvfbdwVe+M/Lm6+NDg4cH9+x+9ZXvvPjNnJooprPLevsf3LL1iUceX792Qz5b YuhIXJDEWDyppYJ+xGaxF3JFRVI5JhLCyaAfOXPq7N/9zd9fPH/p6uVrU5PTZ0+fGz98/NDI+Njo0d079q1ds1ESEmvXbNywdksp397btaSrvS+bKuYz5a7 2vmKuynPxupk1pJE7rB54wYXd50YgGxLiId0OPxSdsqjB14Gej KV5hopCAnk8pkZZMZMsLF+yeut9j5RLnUyY/+xnvjhxa2bi1vT01HxtvvZLjL6nz/x8fRQwOz83Mz83BRidn5mYnbo+efPS9cunzp8+fGJscGz/9pG9rx/dv3ds7+79b76x59Xv7vrud4a2vX5o757jI8OH9u199V//7Y9/9/c+8eGPvP99jz143/3r16xb3r+so9peKhQ7qu0kEbKYzASGs2HG7/UF/YGt9z9waPTgFz//hZPHT4wOj2zf9ubQ4P7jR0+98PzHX31528vffu3pD3zonlXrAT rFXDWXLgGw8pmypqQZKhr04Raz0+nwBfw4gYfJEItjdMCPez2I zep22L1uVyDgx+uuJxFOVKUkHJaSkBB5JRaReC4eZUUuHEtpOR JnwmRk/b2bH3rgUYiXRoKh55594fSpC7X52ixwe+Z/WY++x8/3uvy9tTudusNlqU3Pz0xM3rx06fyJU8dHjx7aPza4Z3z/vmMHhsYG9+x/843dr35396uv7H39tdHdu46OHDh5cHRsaHDHKy//w1/9xa994pMPbt68ad36gb7+WJTXE/9/e2ca3EZ1B/AvnemHtMxAy5WEkKSJHdnxJVv3ZR2WZFmSD1m2EzsQaA6gSToB 6rYGhpRQSvuhCTTctAwQOkM7wzDNtJlC2oaBJL6QZEl2bMmyLV m2JMdaaXcl7SGtth9e4iiHU3BivGXebzSeHXnt2dX89N7b9/7v/xeWlW79/qrvrbl3dQ2/+q4f3vl0z1NDTtebr7/hdXtcDqdj8MvITHR0xB+dmf/JIz89+3n/C4d/V10psja0qORafoVQW2vQ1hpA12wyWKvKBd/9zqq1azZs3FAM4uRFQrlQIKvmiysrBKA2OKhXC4org/3QUpFSLJAL+BLgKHh+Bz/X3rteIVX/eOfeDnuXyWDVqY1V5YKuzoeCU7Nsnk0m0uCzSuEkdPQbJF8QCA DiU5h8PsfkmWzBL7J5hiIJHEPjyflYyDc6NToy4fX43C6fy+lz Of1DTv+Qc+jcmZHB/vOD/d6+c+cH+/0ux3B/b99//v3qyy8d/f2RV4+9MuzxTgYmXjpydMP962v41XKpTFBd4x/znfrkU+eXjsjMbCwS9bqHR0f8U4Hw9FTEPzrZZGltttolQkWj2 Qbc0qmNHfau9tZOmVh13+oNt626464719xz931r12zYsL5o86a S4qKtvC3lJbyKivIaUFyhbCu/tKSyhFfB21LO21IuFSnBBBavqIxXVFZeyhfwJVKRkl8h3Llj1+ 6HHzUZrGCVFRR79nrGKDLP5tkszeayLJNjKZJhbnZ7yBVAR29I/sp4lUuaXnwVwLD5LJOjaTqDoUg0GvaPT4x4x71un9s1Mtjv7j3 rdzlGv+xzn/vc8dmnrs//NTpwZtI1MOFxTgcCg/0D4dD0XDSWiCMuh7No02aFTC6Xykq28I6/9z6WRKeDoeDkFDIfJ9IkjmbGRgIZnH7t2FtSkdJc32RtaOEVlY GV+ocf3NP9RI+tqX313etuW3UHr6hs86aSTT/ibdxQDPr64qKtpSWV5WXV5WXVQNPCNrWaLy4v5YOJJzBvoJCqw dTBQw/sbm3u4FcIJUIFmPN6ZPe+2ek5YOfF3NyX9pRh6E0lbr4K6OgNy ReqeeUxSJV6KcI/e2nTH5PNZQkyk8Sw+fl4JBKdmpga8Y46Bof7z44MnPM7eqeG+i ddfb6BL8Z6Pzvf/4V/xDPs8eIoNhmYmA6GpoOhtlY7v7JqW3uHVq1Zfc+9fz7+QSwSZf MsmSHiF5BMiorPoc8+fXjzRl6j2SYRKjQqvVggN+gaftn9zHPP vtBkaS0v5csltTq1saZKvKW4rGhzKRiJ3r9u0/r7NwNZy7byQTZG3pZycA6wuWJrtVgg12tNLY1tHfauDnuXram9 0WxTSNVSkbLZatdrTVKR8vVX3s5RbJZkQSN6lanwmekbJH9N6B 9zyVGWZVk2x7AUnSMphswxWfby7qksQaZRLB6Lzk5NTflHJ88P B4bdo45Bn3Ng0usIeh0TQwOhYWdsyj83O5NEEsh8HJT3RRPJN1 57/b41axUyuVFv0Gm0YqGoa3vn22++1d/bN9A3eOzl16zmZrVK12S11fBFKoVGr6tvtLQ8d+jXux7eK5MoN 20srijj63X1ZlOjTmMwNzQ3mJrqjVZ9XYNWY6xV1SkVWoVco5B rlAqtulav09Yb9GZTfaPF3GK12Nrt29tat7W2tDc3tjbUW3Uag 1KulooVtUptndZYVVHT0dZ59os+lmGz1GU7KfJiCa5Mhsykl5I c7wZAR/8XiySbvu5ZCyxUmEYTSSR+IT4/F54ORqZDsZnwhUg4HptNzsfQ+ByGxEFhKjbP5nMMlkRxFOs71/uL7p8XbdpcXcWXS2USkVhYIxAJhFUVlVuKiuVypUajU6nUGo2u rs4gkcgslsbnn3+hudkmlcpvv/0HSmWt0WiSyRQSiayyki8SyjRqg9Vis7V0NDXazQ3NVoutqdHe 3tbV0b5j+7YHO7fv7Ny+c1vHA232TnvrNpvNbjSapFJ5TY1QLJ aq1VqTydzY2FxczGtpaX333ffj8QTLsrlcfmmFFZcAdHRZYBiG pmmCIFKpFIZhKIrOz8/H43EEQZLJJI7jqVQqk8kQBLHgfY7OJuIIlkTHff6/fvgXs6lBJpGKBMJapUqlUNbwq0UCoV5XJ5FIhEKhXq8Xi8VlZW X79u07fPiwXC7/6KOPEAQ5ffr03r17161bx+fzbTabXK7UaY0KuQZEeZbwKoQCmd FgabN31qrqtBqjQW82Gix1OpNSoRUKZFWVgpoaoUQiUalUarVa qVRKpVKJRCKRSI4fPz42NgbujiTJqw6WFejoradw6T+bzdI0DX wF6dNAWoTLwSuXqlbk6CyWRBNxJDIzO3Z+9NjLf9i7e49KoRQJ hJpatVFvsDSYbc0tDQ0NHR0dBoPBbrd3d3e3tbXt2LHj1KlTfr 8fhGYTBOF2uw8dOmQ0Gnm8UqVCo1Roa1V1dTqTqb5xod/XqA0KuUYokIE0kVKJSqsxmuqtOp2+vr5er9cDNXft2vXxxx/H43GCIMD1gvyvS96IvASgo7eYawNSC9+/9nwcxRamYEFTGpoKTgdDQ07Xb3/zot3W2m5vs9taa5UqTa16R2eXxWKx2Wz79+/v7OwUiUQHDx50Op2xWGxkZCQajYbDYRy/WCYew7AzZ8498/Svdu96rE5nAkuv5WXVghqpRKxUKXUatUFf12A0WEBTWquqU8jV AoHIbDb39PScOHEiHA7ncjmaplH0YpZGcMCyLPgGLucHeRno6C 1mMRcXI42nCke6KQyfDEwEJ6d8o2Mz0+FP//kJaE1tzS07OrvqDcY9e/a0tbWZTKYDBw6cPHlyYmJibGzM4/EgCJLJZEBypWw2e+HChUQikUxibJ7FMWJyYrq/z/GPv3/ypz++9/zhFx8/2L1/38HHHj3w6CP79+87+FTPs0ePHPvg+Icn/nZyZiaSSCRAq59KpdLpNLidm0/btGSgo7eYr90JLqxjXerxY5FodDbicjhdDufEeGA2PNN79txLR 44++fgT3U/+rKen55133jl9+rTX6w0Gg8FgcHJyMhKJRKNRoFE6nV5o4SiKS qeoFE6mcDKTpimSoak8kcmmcDIWjcfn0RROgjdJIpfCSRTFURR HECSRSBSONSmKQhCEoqhcLpfJZBbS3n4z4kJHl5frdv0LbzIMc +2kQRpPYUl0Njwz5HT19/b5Rsemg6Fxn3905PzEeCAUCjkcDrfb7ff7PR6P3+9PJpOpVArH cWAMTdP5fP6yPQX/maby6RSFYwSOERTJAFkxNINjRDpFkUSOpnPJJLZwtQRBLIwcAI X9O8j2vqyfHgA6ulxclbr/uifk83kinWGyucIiVRRB4ihGEeRseGbY4/W6Pb7RsXGf//zwiNs15PV6A4GA3+/3+XyRSARFURzHwQMNaN4KrWIYJpu94muQpS+GfaRTFEUyCyEge YalSCaTIa9K07CwIbHwFmiaTqfTSysSsgSgoyvNIhXVcBRDE0l kPj4Xjc2GZ0JTwYnxQMA/HgqFwuFwNBpFECSVSoFWc6XvYXmBjq40izhKZgginQH9fiKOzM 9dAONU8BxDEARN0zefNvH/AujoSrOIo6BqOpPNZSmaJimKIIG1K325KwB0dKVZxNFFX4V/WjDkXaGr/yaAjq40i7l43cLp+UVrAK30bSwj0NGV5saOXmMqWEr9dkt5FdD Rlear9O9gm0qOyeeYr7uO9S0AOrrSfMVhKJMHj1BXpQCCfT0Es vJARyFcBzoK4TrQUQjXgY5CuA50FMJ1oKMQrgMdhXAd6CiE60B HIVwHOgrhOtBRCNeBjkK4DnQUwnWgoxCuAx2FcB3oKITrQEchX Ac6CuE60FEI14GOQrgOdBTCdaCjEK4DHYVwHegohOtARyFcBzo K4TrQUQjXgY5CuA50FMJ1oKMQrgMdhXAd6CiE6/wXadzHbnfl0VQAAAAASUVORK5CYII=[/img]
#20
I've been fighting oil and coolant leaks on my 2007 Audi A6 4.2L engine and after replacing the valve cover gaskets, oil filter housing O-rings, throttle body adapter and oil separator I was able to stop the coolant leak but I still had a oil leak in the valve covers which was dripping down on the cats. I suspect that the valve covers are warped since the dealer doesn't sell just the gaskets for the 4.2L engine.
I ended up using two bottles of AT-205 re-seal, so far so good, I will need to give it more time to see the long term affect. I mail ordered the AT-205 re-seal since I can't find it in the local stores.
Might be work a $20 investment if you run out of other options or are feed up with a oil leaking Audi like I was.
