2008 A6 4.2 shifting issue, slamming into gears
I have a 2008 A6 4.2 sline, 120k and started noticing especially when the engine is cold that the trans slams a little changing up, and sometimes down. Maybe its less noticeable when the engine is warm. I also see a 4oz fluid leak on the ground at the end of each day, all the way up front by the drivers side front headlight location.
Could it be a transmission cooling line runs up front and is leaking? and its slipping cos Im loosing trans fluid? Is there even a way for the owner to top up the trans fluid, or check the level,or no?
Thanks for any advice
- when, if ever, was the transmission fluid and filter changed on your car? If the answer is IDK, then I'd start with a ZF fluid change
- With any leak, you need to determine where it's coming from...then get to fixing it
- You can't simply "check the level of the tranny fluid" and here's a GREAT DIY on how to service it: So you want to change your trans fluid??? - AudiWorld Forums
There are four types of fluid leaks that could occur near the drivers side front headlight: Power steering, transmission, head light washer fluid (if you have that option), and engine coolant. It would help to identify which fluid is leaking and go from there.
SFG
01-16-2004 01:01 PM
