55 - Headlight Range adaptation channels
Basically, I am looking for what the adaptation channels in the Headlight Range module of the A6 C6.5 are for.
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000026
Channels 1 through 11, 17, 18, 20, and 23 are available. Through hours of changing things and looking for the differences, I have discovered what most of the channels are for. I am, however, still looking for help with channels 3, 5, and 6.
Channel 3 is protected by security access, can be set to '0' or '1', and is default at '0'
Channel 5 is protected by security access, can be set to '0' through '3', and is default at '3'.
Channel 6 is protected by security access, can be set to '0' or '1', is default at '1', and causes a slight upward adjustment of the lights. I should also note that, when this channel is set to '0', enabling Tourist Mode via channel 23 does NOT aim the lights downward as usual.
To (hopefully) help some other searching soul, below are the channels that I have found a function for.
A01,0,Cornering Lights in Park
A01,5,Range - '0-1'
A01,6,0 = Cornering lights NOT active in Park
A01,7,1 = Cornering lights ARE active in Park
A02,0,Motorway Function
A02,6,0 = Disabled
A02,7,1 = Enabled
A02,8,No description
A03,0,(SA) UNKNOWN
A03,5,Range - '0-1'
A03,6,
A04,0,Swiveling Light Restriction
A04,5,Range - '0-2'
A04,6,0 = No Restriction
A04,7,1 =
A04,8,2 =
A04,9,
A05,0,(SA) UNKNOWN
A05,5,Range - '0-3'
A05,6,
A06,0,(SA) ? Enable Vertical Adjustment
A06,5,Range - '0-1'
A06,6,Default = 1
A07,0,(SA) Static Cornering Lights
A07,5,0= Disabled
A07,6,1- Enabled
A08,0,(SA) Startup Self-check type? maybe more...
A08,5,Range - '0-3'
A08,6,Default = 1
A09,0,Cornering Light Behaviour
A09,5,Range - '0-2'
A09,6,Default = 0
A10,0,(SA) Swiveling Light Function
A10,6,0 = Disabled
A10,7,1 = Enable
A11,0,Fault Warnings
A11,5,Range - '0-1'
A11,6,0 = Fault warnings NOT Active
A11,5,1 = Fault warnings Active
A17,0,Cornering Lights with Turn Signal
A17,6,0 = OFF with signal
A17,7,1 = ON with Signal
A17,8,Changes whether static cornering lights are affected by turn signal.
A18,0,Cornering Light Reverse Function
A18,5,'0-1'
A18,6,0 = DISABLED
A18,7,1 = ENABLED
A18,8,Activates cornering light function when in Reverse gear.
A20,0,Showroom Effect
A20,6,0 = DISABLED
A20,7,1 = ENABLED
A20,9,The Showroom Effect function allows the dynamic cornering lights to be
demonstrated when the vehicle is at a standstill.
A23,0,Tourist Mode
A23,6,0 = DISABLED
A23,7,1 = ENABLED
A23,9,When driving in countries where driving is performed on the opposite side,
the headlights are changed over to avoid blinding the oncoming traffic.
Coding: 0000026
A01,5,Range - '0-1'
A02,6,0 = Disabled
A02,7,1 = Enabled
A03,0,(SA) UNKNOWN
A03,5,Range - '0-1'
A03,6,
A04,5,Range - '0-2'
A04,7,1 =
A04,8,2 =
A04,9,
A05,0,(SA) UNKNOWN
A05,5,Range - '0-3'
A05,6,
A06,5,Range - '0-1'
A06,6,Default = 1
A07,5,0= Disabled
A07,6,1- Enabled
A08,5,Range - '0-3'
A08,6,Default = 1
A09,5,Range - '0-2'
A09,6,Default = 0
A10,6,0 = Disabled
A10,7,1 = Enable
A11,5,Range - '0-1'
A18,5,'0-1'
A18,6,0 = DISABLED
A18,7,1 = ENABLED
A20,6,0 = DISABLED
A20,7,1 = ENABLED
A23,0,Tourist Mode
A23,6,0 = DISABLED
A23,7,1 = ENABLED
TmS4
9
09-21-2006 12:08 PM
YUM18T
VAG-COM Discussion
06-29-2006 12:41 AM
kday
VAG-COM Discussion
06-13-2006 10:16 AM
mxp
03-27-2003 06:51 PM
