Is this AMI suitable?
Hi all, I am new to this retrofitting stuff but my goal is to get some Bluetooth streaming on my 2008 A6 2.0 TDi Limited Edition. It has the more basic MMi option, but is colour, has the sat nav etc, cd changer. Is it the AMi with the part number 4E0035785 that I need to install to get this functionality? I have seen a few others dotted around with the same prefix of numbers but with letters on the end, are any of these compatible, for instance 4E0035785 F or A. Any help would be greatly appreciated, especially if I have this all wrong!
I had bought a couple of items to add to my 2006 A6 last year and this weekend finally got around to adding them.
1. A backup camera module (Audi MMI 2G HIGH rearview camera module) and sony ccd camera in Audi trunk handle.
2. A Media gateway (Dension 500 Gateway) which gives me ipod/usb and bluetooth options.
The backup camera plugged into the AMI connector and I bought the license plate backup camera which replaces your handle.
Installation couldn't have been easier, a few bolts and the entire glovebox drops down. I grabbed power from the backup light for the camera and filtered it to avoid noise in the picture.
It turned out really good. And was easy!
Do you happen to have the part numbers for the backup module and camera? And when you say it plugs into the AMI unit, where exactly? In the back of the unit or inline with the cable coming out the front? Or did you mean that it plugs into the Dension?
Thanks!
Thanks!
$41 on ebay Search for 'Audi A3 A6L A8L Car Trunk Handle Backup Camera CCDSony Parking Assisitance'
And the electronics to go with that:
$135 from Germany on Ebay. Search 'Audi MMI 2G HIGH rearview camera module adapter harness for Audi A4 A5 A6 A8'
Pull the glovebox (a few small bolts hold it in and up.) and it drops right down. The AMI module is directly above that and you remove the factory cable, plug in the cable hanging off the backup module so it is between the backup.
When you run the wires back to the camera you MUST isolate the power with filters or you will get interference. I used a couple of:
PAC CSS12 Passive Noise Filters
$13 on Amazon.
I pull power from the backup light in the rear for power to the camera when backing up and also sending power to the backup unit up front to turn on the backup unit. I also filtered my Dension as well. It plugs into the MOST (Media Oriented System Transport) cable. It looks a little intemidating but was very easy to install. You simple remove one side of the MOST connector and slip one of the MOST cable into the existing and which creates a Y and allows it all to plug in. The Dension could probably go in the trunk as well.
