Anyone had the "24M4 Low Fuel Pressure Sensor Recall"
Car was in for a CEL, they replaced 06E-906-051-K sensor, claim that there was "no fault found" on the CEL, but the light's out now. Hmmmmmmm.....
BTW - 2007 C6 S6
BTW - 2007 C6 S6
Cat Herder
CEL = fault found. always. whether it's an important fault or not is the critical part.
local forum vag-com help will be able to tell you exactly what the fault message was (or buy your own cable from ross-tech).
steady CELs are usually less worrisome (you can still drive the car) than blinking ones (you must pull over) and I usually plug in my laptop before even bothering to make a service appointment.
What a coincidence! I got the same problem on Friday....
Low fuel pressure Regulation.....There is a known problem with high pressure fuel sensors, and I believe an updated fuel pressure regulator...
OrlandoDave
A4 (B7 Platform) Discussion
12-26-2023 01:19 AM
bostonS6
06-12-2008 05:40 PM
BlueS4orce
08-29-2003 02:50 PM
