Brake Light Warning ... but why?
Audi A6 2008 quattro
I got brake light warning for back passenger side. Bought replacement bulbs... open up the back light shell .... none of the bulbs are burnt! All the top 3 bulbs are on when I start the engine to test the brake lights. I step on brakes, the left side lights up (the side I didn't open) ...the right side that I open the 3 lights just stays on..I thought it would flash or light up when I press brakes. If all the bulbs are ok then what else can I check THe brake light warning still showing and still does not light up when I press brake.
Thanks!
C
Thanks!
C
Maybe wrong bulbs in sockets like a single filament bulb in a dual filament socket shorting 2 pins etc. Could find a bulb chart or compare bulbs with the working side. If a bulb fits in a hole doesn’t mean it’s correct 😉
Also, check for corrosion at the connector for the assembly. If there is high resistance in a connection then the bulb test will fall outside of a pre-determined range.
This is a common issue with the tail light assembly and is a result of connectors failing in the unit. It is not serviceable and you will need to buy a replacement assembly. Fortunately, it comes with new bulbs if I remember correctly but it's been awhile since I replaced mine
gtrucinski
9
04-02-2021 03:53 AM
DMLOJO
06-04-2010 05:28 PM
Audika
Audi 100 / A6 (C4 Platform)
11-24-2007 04:55 PM
