Can anyone help me with these Key FOB and DRL issues?
I changed the value 0423997 setting to value 0424125; so i added thee 128. I hold the unlock button down the windows open as expected. However when i hold the lock button down the windows wont close. Why would only half the function work?
The Seat belt chime worked fine 0065263 to 0065203 and the SDS mode worked great.
Another issue i am having is with the DRL. I changed the last bit to state a different country than the US. From 0013123 to 0013122. I basically tried all country codes but the DRL still go off when the driving lights go on. The MMI setting is set to DRL on. Any one know what i am doing wrong?
0xxxx?x: Daytime Running Lights
0 = w/o Daytime Running Lights
1 = with Daytime Running Lights (not selectable via MMI)
2 = with Daytime Running Lights (selectable via MMI)
0xxxxx?: Country
1 = Rest of World (RoW)
2 = Northern European Countries (Sweden/Finland/Norway/Denmark)
3 = USA
4 = Canada
0xxxxx?: Country
3 = USA
4 = Canada
OK, learned something the value for the adapation channel 061 of the comfort system control module
was 10, added one and stored 11 now windows close did the same for the sunroof and added the values to open and close it(added a 12). It all worked except for the opening of the sunroof. Will have to check my math when i get a chance.
However i have had no luck with turning the DRL on.
Troy H
TT (Mk2) Discussion
10-05-2008 08:34 PM
05whtaudia6
VAG-COM Discussion
05-11-2008 06:11 AM
