A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Car wont start - Stuck in "P"
Old Feb 18, 2009 | 10:35 PM
  #11
Nitin's Avatar
New Member
Default Re: 2nd that, you or anyone else in your family had a new key programmed at the dealer recently?
The break lights work. There is no flashing yellow icon. It behaves as if there is no key. Also strange, when the key is inside the car, I can lock and unlock the car by remote. I think the car can detect the key is inside the car and disable the buttons?
Old Feb 19, 2009 | 04:49 PM
  #12
kemer1's Avatar
Default I had the same issue a couple months ago...
Went out to run errends and the car just flat out didn't do anything as far as steering unlocking, but the radio and all electricals came on. The issue with mine was that a sensor in the steering column went bad and wasn't reading the code in the key. You may be having the same issue, or maybe that one key is deprogrammed...try using one of the spare keys. If that doesn't work, then most likely it's the same as my problem and you will need to have the entire steering column replaced.
Old Feb 21, 2009 | 08:44 AM
  #13
Johnstay's Avatar
Default Whoa. Way overkill on removing the screws.
When Audi says "little cover" they mean tiny. When you remove the ashtray, there is a very small cover about the size of a US dime in the side wall of the well opening you just exposed towards the shift **** that can be pried up with a fingernail (it is sort of funny shaped but it does pry up). Then you can access the rocker switch. Removing the screws is not required.
Good luck
IntheQ5
Q5/SQ5 MKI (8R) Discussion
38
Oct 21, 2024 10:43 PM
carl viking
40
Jul 12, 2024 02:45 PM
fkaufman
A7
Sep 7, 2015 07:59 PM
zhaoweitian
A7
Sep 1, 2015 03:15 PM
aron56
Audi 100 / A6 (C4 Platform)
Sep 1, 2015 12:39 AM
