Cracked Hose / Vacuum Line CEL
I recently got a CEL for a small leak P0456. After some looking around I found a line that is cracked, could it be throwing the code? What is that line called?
Got it. Was looking to find a replacement online, but wasntw able to find the part. Also, does the CEL have to be cleared via vcds or does it go away after the problem is fixed?
https://www.autozone.com/fittings-an...uestid=1188866
The CEL will usually clear after a given period of time, or I'd just go to any auto store and just get an OBD2 scanner and clear faults.
That vacuum pipe is probably P/N 4F0-611-931-CL, which lists for the low, low price of $118 (sells for $87.79) on www.genuineauidparts.com. Looking at the layout in ETKA 7, this vacuum pipe connects to the vacuum pump, and provides vacuum to the brake servo. Rather than buy another pipe assembly, I would try sealing that crack in the plastic pipe.
Mr.D-'97 A4q 12v
12v V6 Discussion
14
03-24-2004 05:12 PM
520
03-03-2003 06:25 AM
WoostaS4
10
08-21-2002 06:27 AM
