Last edit by: IB Advertising
- Audi A6 C6 How to Replace Upper Timing Chain Tensioners<br>Step by step instructions for do-it-yourself repairs.
DIY - A6 3.2 Upper Timing Chain Tensioner Replacement
#451
No crank after timing
Good afternoon,
I have a 2008 A6 C6 3.2 @ 117k
This past weekend I manged to find some time and replaced the upper chain tensioners. I've been having an issue with timing the tensioners and finally manged to get organized and complete the job. After running VCDS I was reading about on 0.0 and -0.1 adjustment on Banks 1 and 2 so the timing was in check. I drove the car into town and back about 15 miles and the car was running running perfect, plenty of power etc. Once I got back home I shut the engine off to get ready for a final oil change and thats whens my nightmare occurred. My car wont start! There is no crank or turn over. I'm still able to turn the key however and power the electronics, lights, MMI, windows, radio etc. When I turn the key to start nothing happens.
I didn't see anything major on my VCDS scan and have attached scan / log.
I believe this is now an electronics issue.
Please help I'm very desperate
Thanks,
Karl
Thanks,
Karl
#453
Sverige,
Thanks for the reply!
Unfortunately, The battery is the first item I checked. Its a brand new battery I connected to the charger still gave me no good results. Afterwards I set the charger to cold start 200 amps and absolutely nothing. All the electronics are definitely getting power so that rules the battery out...
#455
Good afternoon,
Thanks,
Karl
Thanks,
Karl
yeah as "Sverige" said start new thread!..
cheers!/H
#456
Reuse camshaft adjuster bolts
I noticed on the edge motors video they mention using new bolts to install the camshaft adjusters. Also the eBahn manual mentions this. I haven't noticed that being done in this thread. Can the old bolts be reused? Does anyone know where to get them?
#457
Per the Bentley Repair manual, the bolts should be replace because they are stretched when tightened to the proper torque value + 90 degrees. You can obtain them from any on-line dealer.
#458
I did not replace the bolts. I torqued them to the spec and they are tight. I cant imagine them ever coming out.
#460
I kind of expected the answers I got! By the book -"replace them" and real world - "I torqued them up and they were fine". Both answers are probably correct. Main thing I was worried about is the bolt head snapping off on the second torquing.
I checked at the local dealer and they wanted about twelve dollars a bolt which meant I was going "real world" then I checked ECStuning and they wanted about $4.50 so I guess I'll go by the book although my gut tells me I would have no problem with the old ones.
Thanks for the replies. I'm sure I'll have more questions before I tackle this.
