A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Enabling window roll up and down via remote with VAG
Old 08-30-2011, 12:59 PM
  #11
NR04's Avatar
Originally Posted by capjones
While we're talking about it... what's the code to disable seatbelt chimes?
It's pretty much the same procedure but you need to enter the instrumental code. Here is more description. http://wiki.ross-tech.com/wiki/index...Y_2008)#Coding
But in this case, instead of adding the code, you simply replace the bit with the corresponding number. If you have trouble, I can post a pic as well but it will take time.
Old 08-31-2011, 01:29 PM
  #12
NR04's Avatar
Originally Posted by jmallred
is it possible to activate the needle sweep on a 2008 A6?
I haven't checked 2008 but 2007 did not have this option. My guess is that this feature was installed starting 2009.
Old 05-31-2013, 02:31 PM
  #13
LoganS6's Avatar
thanks for the write-up, worked great on my 2007 S6 for all windows up & down with remote.
only 1 caveat, the sunroof will still not open and close with the remote.
maybe because it's the solar panel sunroof?
Old 06-07-2013, 08:28 AM
  #14
kmongru's Avatar
thanks for the details?
How can we do all those other things that are suggested for long coding???
Forgive my ignorance, but is there a trick to it that im missing?
Old 03-14-2014, 12:46 AM
  #15
royclark's Avatar
Originally Posted by Ynnekdude
NR! Thanks man! I borrowed someone's VAGCOM to do a rear brake install and I just ordered my own. I was looking for some cool stuff to do. Glad I came accross this. Any chance you know of any more good stuff? Transmission? Throttle? Steering?
http://www.vwaudiforum.co.uk/forum/s...p-Pre-Facelift
On my A6 avant, hold down the unlock button to open windows then hold down the lock button to close the windows.
make sure that your key battery is ok.
Old 07-11-2014, 06:18 PM
  #16
Trekie's Avatar
I have a 2008 A6 and there was one other thing I had to do. I had to use the key to open the windows and close them. After that the remote function works for the windows but sunroof doesn't open but will close.
Old 07-13-2014, 08:50 AM
  #17
t0kie's Avatar
I had this feature in my Passat before thru VCDS, cool. It's very helpful especially during a hot summer.
Old 07-14-2014, 02:25 PM
  #18
Trekie's Avatar
Can any one confirm if they got their sunroof to open with the remote or manually by putting the key in the lock? Thanks.
Old 07-15-2014, 07:07 AM
  #19
NR04's Avatar
Yes, the sunroof opens with the unlock button and closes with lock button.
Old 07-16-2014, 02:11 PM
  #20
Trekie's Avatar
Thanks, I'll take another crack at it.
Quick Reply: Enabling window roll up and down via remote with VAG
