A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
ESP+ABS+Parking Brake Lights All At Once
Old 07-28-2014, 06:20 PM
schalliol's Avatar
Default ESP+ABS+Parking Brake Lights All At Once
Tonight I experienced an error I've never experienced before.
I got the ESP Fault message just after stopping from a short trip. Once I got going again a few minutes later, a parking brake malfunction appeared and continued to flash on the LCD. When I slowed down, the flashing stopped, and if I then got to a point where I was at maybe below 10MPH and then sped up, it would beep with a parking break malfunction error. As such, any stop sign would cause the car to beep within a few seconds of picking back up.
Turning off the car doesn't resolve the issue.
Does anyone have an idea of what this could be? Thanks!
Old 07-28-2014, 07:06 PM
ericA6's Avatar
My first guess is that your ABS module went bed. Our cars are known to experience this problem. If you're handy you can DIY. Not a hard thing to fix. I did it. There's a DIY video on cheap-abs.com.
Old 07-29-2014, 04:59 AM
schalliol's Avatar
Thanks for the thoughts! If that's it, it sounds like a cheap repair, which is great.
I plugged in VAGCOM and found three codes triggered during the event in the order they were generated:
Code:
Address 03: ABS Brakes       Labels: 4F0-910-517.lbl
Control Module Part Number: 4F0 910 517 L    HW: 4F0 614 517 L
  Component and/or Version: ESP 8.0 quattro H03 0090
           Software Coding: 0020895
01435 - Brake Pressure Sensor 1 (G201)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 150
                    Mileage: 181819 km
                    Time Indication: 0
                    Date: 2014.07.28
                    Time: 20:22:49
Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
   Part No SW: 4F2 910 559 B    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0030
   Revision: --H15---    Serial number:
   Coding: 0000000000000000
005715 - Please check DTC Memory of ABS Controller
               P1653 - 008 -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 40
                    Mileage: 181819 km
                    Time Indication: 0
                    Date: 2014.07.28
                    Time: 20:22:51
             Freeze Frame:
                    RPM: 896 /min
                    Mass Air / Rev.: 87.2 mg/str
                    Temperature: 93.0∞C
                        Idle
                    Load: 14.9 %
                    Speed: 0.0 km/h
Address 53: Parking Brake       Labels: 4F0-910-801.clb
Control Module Part Number: 4F0 910 801     HW: 4F0 907 801
  Component and/or Version: EPB  C63C0030   H03 0030
           Software Coding: 0005022w
01316 - ABS Control Module
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 3
                    Fault Frequency: 11
                    Reset counter: 150
                    Mileage: 181816 km
                    Time Indication: 0
                    Date: 2014.07.28
                    Time: 20:23:21
             Freeze Frame:
                    Voltage: 13.04 V
                    Count: 236
I cleared the codes and nothing else went off driving around the block. It sounds to me like something went wacky with the brake pressure or brake pressor sensor, which had a cascading effect on the other two, but I have zero experience with these challenges and only a bit with the car coding anyway.
ericA6, do you know if you had any of these when you had your issue?
Does anyone else have ideas looking at these codes? Thanks!
Old 07-29-2014, 07:19 AM
skimblzbvs's Avatar
In response to your PM's, yes, I had the parking brake error notice as well. And it IS the ABS module.
I did the VagCom scan (guy at work actually had one!), and it confirmed the module is pretty much kaput.
I FINALLY got around to removing it on Sunday. The right tools make all the difference.
I got the Torx E-bits from Harbor Freight and I opted for the 1/4" socket versions knowing it was a tight area. Using the smaller socket I was able to remove them a bit easier. But I will say this: To the genius that designed the ABS pump bracket, why in the hell did you feel compelled to put a 90 degree bend UP on the back side to make removing the last bolt a true PITA? Thanks... thanks a lot! LOL
I now have my module enroute to ModuleMaster. They be a bit more pricey than some of the other places that can do this, but they answered EVERY question I had promptly, have a brick and mortar shop and address with full website, and the 5 year warranty should get me through the remainder of my senten... err time owning this car.
Old 07-29-2014, 07:52 AM
schalliol's Avatar
Thanks very much for the info! After resetting the codes I drove to work without issue, so at the moment I'm hoping it was just a weird one moment in time issue, but I feel like that work is coming.
How long did it take you to remove the module? I've done a bunch with electronics and the car, but not a lot with major car repairs, so I'm a bit nervous about replacing the module.
Are you still driving your car with the module removed or skipping it? I understood it should be safe to drive but without ABS functioning, but it probably isn't advisable if another vehicle is available.
Old 10-22-2019, 12:08 PM
jasontaylor7's Avatar
Originally Posted by skimblzbvs
...They be a bit more pricey than some of the other places that can do this, but they answered EVERY question I had promptly, have a brick and mortar shop and address with full website, and the 5 year warranty should get me through the remainder of my senten... err time owning this car.
This was the funniest thing I've read in a while. Thanks for the laugh.
I have the curvy roads light, ABS, ESC, with these codes (misspellings are SIC [within the software]):
1. 01316:2D Brake Control Module, Please read DTCs memory Lamp OFF Intermitted
2. 01435:28 Brake Pressure Sensor 1, Signal Unplausible. Lamp OFF Intermitted
Parking brake constantly beeps (well it acts like it is beeping), yet it works fine.
Are these signs of an internal wire on the brake module being bad and in need of a refurb?
quattro2turbo
05-10-2009 06:05 AM
Peotter
Audi allroad
08-04-2006 04:57 AM
arob
Mid Atlantic Discussion
02-16-2006 09:06 AM
LaserK04
10-09-2000 07:02 AM
Quick Reply: ESP+ABS+Parking Brake Lights All At Once
